Help no oil pressure duramax<stranded - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2010, 08:10 AM   #1
beejers
always building
beejers's Avatar
Default Help no oil pressure duramax<stranded
My dads on his way to flordia and lost oil pressure on his 03 duramax.
we change the oil, filter and his fuel filter before he left.
his light came on that said low oil pressure around atlanta georgia.
he checked the oil level, its good.
he had a oil sensor go bad once, it was replaced
how can he manuely check for oil pressure?
Where is that sensor located?
Any ideas?
beejers is offline   Reply With Quote
Old November 25th, 2010, 08:23 AM   #2
95geo
newbie
95geo's Avatar
www.thedieselplace.com
Old November 25th, 2010, 08:41 AM   #3
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
So, you have a message on the cluster right? Does it say LOW OIL PRESSURE or LOW OIL LEVEL? Just trying to clarify, they are two seperate circuits. Also is the check engine light on and does he know the DTCs by chance?
BAD93SBLZR is offline   Reply With Quote
Old November 25th, 2010, 08:42 AM   #4
beejers
always building
beejers's Avatar
low oil pressure, we checked level.
Old November 25th, 2010, 08:51 AM   #5
beejers
always building
beejers's Avatar
Originally Posted by 95geo View Post
thanks, looking right now. was also googleing
it was on the first bar until he slowed down and then went to nothing.
lots of things pop up for a bad sensor
Old November 25th, 2010, 11:10 AM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
if it's a common problem of having a bad sensor then that seems to be a likely cause. the quick way i would check since he's on the side of the road is to loosen the oil filter alittle bit then crank it for a few seconds to see if oil sprays out of it. if you get good oil coming out of it then it's most likely a bad sensor.
Old November 25th, 2010, 11:51 AM   #7
beejers
always building
beejers's Avatar
Thanks everyone.
Another way to check for oil flow is to:
check your oil.
make sure its full.
start engine.
take dipstick out and clean off.
check oil while running.
there should be no oil on dipstick=good oil flow.
he is back on the road and headed to Flordia where he will change the sensor
i suggested the oil filter idea too.
Old November 25th, 2010, 06:21 PM   #8
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
one other thing to check. if its running and it slowly loses pressure is to shut off the engine and quickly flip the key on without starting it. if the sensor is bad it will read a negative number. if ts an analog gauge it will do back flips in the cluster. oil pressure will build up on the back side of a bad diaphram in a sensor and then when you shut off it goes into reverse. makes the gauge go nuts.
another thing to do is unplug the sensor running. there's no seal to prevent it venting pressure past the connectors on the sensor with it unplugged
Yetti
Old November 25th, 2010, 06:53 PM   #9
beejers
always building
beejers's Avatar
it did weird things the rest of the trip. He made it to Florida.
he would have almost no oil pressure when he stopped for diesel, when he takes off it read great. as he was driving down the road it would drop to 30 psi.
Old November 25th, 2010, 06:56 PM   #10
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
min oil pressure for that is 24psi
Page generated in 0.18143 seconds with 53 queries
