ignigtion module HEI - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2010, 08:07 PM   #1
84ChevyMuscle
BigBoysNeedBigToys
84ChevyMuscle's Avatar
Send a message via AIM to 84ChevyMuscle
Default ignigtion module HEI
What exactly make ignition modules go bad in an hei distributor? It seems as if ive replaced more of those then anything else dealing with the ignition
84ChevyMuscle is offline   Reply With Quote
Old November 24th, 2010, 02:38 AM   #2
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Too much heat will kill them. Are you putting the heat sink paste on when you install the new ones?
Old November 24th, 2010, 08:42 AM   #3
Cool parts peddler
Ironman Offroad's Avatar
Open wires or a coil with insulation broken down can cause secondary (high) voltage to leak to the low voltage side of the system. Very hard on moduals.
Ironman Offroad is online now   Reply With Quote
Old November 24th, 2010, 09:35 AM   #4
this is the number 1 thing that kills them...
Old November 24th, 2010, 06:41 PM   #5
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
weak ground or grounds in the ign system
Page generated in 0.15525 seconds with 38 queries
