camber issues on 89 ford ttb - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 20th, 2010, 05:13 PM   #1
womenlikemfullsiz
newbie
womenlikemfullsiz's Avatar
Question camber issues on 89 ford ttb
pretty new to the ttb setup. i have a 6in lift on it and now the camber and alignment is going crazy. when i go in reverse the tires toe in drastically. driving forward causes them to toe out. bushings and everything look good. any ideas??"??
womenlikemfullsiz is offline   Reply With Quote
Old November 20th, 2010, 05:22 PM   #2
Drop pitman arm and set your toe. If you already have the drop pitman then have your toe set.
Your steering angles are forcing your toe to lift/pull down on your suspension. The steering linkage needs to be as horizontal as possible.
Old November 20th, 2010, 08:02 PM   #3
womenlikemfullsiz
newbie
My pitman arm has a 4in drop. It would need to be another 3in lower for the linkage to be horizontal and match the pivot points and front axles. Should I just try n find a larger drop pitman or should I change the front linkage? I'm pretty new to the camber and toe issues.
Old November 22nd, 2010, 10:07 AM   #4
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
The ttb is gonna do that a little bit anyway but it should'nt be to the extreme. I have a 4 inch lift on my 96 and i have had everything replaced and still cant get it to stop.
ATOMIC_BADBOY is offline   Reply With Quote
Old November 26th, 2010, 11:12 AM   #5
BOGDOG
BOGDOG's Avatar
What about the super runner steering setup?
Tags
alignment, camber, ttb
Page generated in 0.21294 seconds with 38 queries
