Front axle suggestions pls - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 20th, 2010, 11:18 AM   #1
gofast
Default Front axle suggestions pls
I am looking for a front axle that can run stock parts. I originally wanted to chop down a ford dana 44 HP to waggy width. I have a trussed 8.8 in the back and would like something stronger than the 44. I want to run 36-37s with 5.13s. I don't want to run full width. I think a 609 or 449 would be sweet but that's lots of $$$ and not anywhere near stock parts. Maybe I'm kidding myself and the 44 is the best option that wont cost me too much coin. Any suggestions are appreciated.
gofast is offline   Reply With Quote
Old November 20th, 2010, 11:22 AM   #2
koochman450r
koochman450r's Avatar
a 44 with cromo shafts and 300m u-joints would be strong enough for 36-37or throw in a toyota hp and get longfeilds or dirty 30's and you can run 38-40's all day. I dont know what your putting it in but toyotas are p/s drop.
you won this battle.
Old November 20th, 2010, 11:46 AM   #3
gofast
should have mentioned this is goin in a xj so I need driver side drop. You think a yota front is stronger than a 44? I hardly see those for sale but maybe I am not looking in the right place.
Just seen you have rockwells going in.....not looking for something quite that big :).
Old November 20th, 2010, 11:50 AM   #4
rangerluc
rangerluc's Avatar
yota axles are junk
rangerluc is offline   Reply With Quote
Old November 20th, 2010, 11:53 AM   #5
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
HP D30 with D44 internals and RCV shafts, done. You can run 37's all day.
Old November 20th, 2010, 12:04 PM   #6
gofast
by that do you mean a 30 spline kit? Stil end up with unit bearings. Seems like a locked 30 ring and pinion wouldn't last long. I did see a company is making a 513 for the 30 but that pinion is tiny.
Old November 20th, 2010, 12:31 PM   #7
liv2mx
i like jungle gym's.
liv2mx's Avatar
all a waste of money.....
Old November 20th, 2010, 12:35 PM   #8
BigBlockBlazer
Axle breakin' 101
Google over on Pirate. But use RCV shafts.
I know but he asked...
Old November 20th, 2010, 12:35 PM   #9
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
It depends on how you drive it and what you drive it in
BAD93SBLZR is offline   Reply With Quote
Old November 20th, 2010, 12:38 PM   #10
bigbchevy
missmrgreenagain
bigbchevy's Avatar
dana 60 is the best way to go
H.o.r.e
Old November 20th, 2010, 12:46 PM   #11
liv2mx
liv2mx's Avatar
just figure how much you will spend on good shafts and joints and that will easily pay for a 1 ton front..do it right the first time and you will not regret it.
Old November 20th, 2010, 12:50 PM   #12
gofast
I'm not aware of any 60s that are not full width or stock shafts I could use if cut down. I would love a 60 though.
Old November 20th, 2010, 01:26 PM   #13
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
You'll probably end up spending almost this much if you have to get any custom shafts anyway. Just go for it.
http://www.polyperformance.com/shop/...K-p-24544.html
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old November 20th, 2010, 01:38 PM   #14
gofast
[QUOTE=jeepitupyo;2429751]You'll probably end up spending almost this much if you have to get any custom shafts anyway. Just go for it.
[url]
shoot $$$. I can build something for less than that. I better have a 609 under the rig for that kind of coin.
Old November 20th, 2010, 03:18 PM   #15
camccardell
tiger blood
camccardell's Avatar
just make a sterling like me
Old November 22nd, 2010, 07:43 AM   #16
gofast
Endless research has brought me back to a ford HP 44 cut to waggy width... 609s are just too price and I think the 44 will handle 37s okay.
Old November 22nd, 2010, 07:51 AM   #17
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
85-91 kingpin or a 92-97 ball joint ford hp60 but down ~5" on just the long side to make it 64" wms and you can get the shaft resplined for ~$70 and everything fits nice.
Hp44 is a waste unless running a 4 banger, just run a hp30
94 hp60 64.5" wms
Old November 22nd, 2010, 08:22 AM   #18
gofast
why do you say the 44 is a waste unless you have a 4 banger? I would eventually like to have a small block. D60s are hard to find for a decent price. where can I get shafts resplined for 70 bucks? I would imagine that would be heat treated as well.
Old November 22nd, 2010, 09:00 AM   #19
Jeepaholic
Jeepaholic's Avatar
hp30 only goes down to 4:88's so if you need/want 5:13 or 5:38's then a hp44 is the way to go. The weak point it the same for either axle the axle joint.
Don't even mess with half ton stuff with 37's and a small block do it right the first time.
There are deals out there you just have to keep your eye open.
Moser Engineering, last I checked was $65 might of gone up plus shipping there and back is not expensive. No you do not heat treat again.
EDIT; http://www.moserengineering.com/moser/shop-services/
Old November 22nd, 2010, 09:41 AM   #20
gofast
well right now I do have the 2.5 thats why I want to go deep gearing. Maybe I will hold out and narrow a 60 but it will make my 8.8 in the back look silly.
Page generated in 0.34347 seconds with 83 queries
