92 F150 straight 6 won't start now - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 20th, 2010, 01:13 AM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default 92 F150 straight 6 won't start now
So now my truck won't start at all. It was running fine today until I parked it for a few hours and now it just cranks and lightly sputters every so often, but won't start at all. It almost sounds like its getting very little to no fuel to the motor, but also sounds like it also might not be getting enough spark. I also tried spraying some starter fluid in the intake and it didn't change a thing, though I'm not too sure if starter fluid really helps with fuel injected engines. (I don't know much about fuel injection and I personally hate it)
I'm wondering if maybe the ignition module or something else with the EFI system could have took a shit? And would be the symptoms of a bad ignition module?
The truck is a 92 F150 straight 6 with a 5 speed manual for anyone that doesn't know.
chevyk10 is offline   Reply With Quote
Old November 20th, 2010, 09:59 AM   #2
chevyk10
FORD / GM
chevyk10's Avatar
Update:
Truck still won't start and its getting spark and I can hear the fuel pump.
Any ideas?
Old November 20th, 2010, 10:20 AM   #3
mprmn08
mprmn08's Avatar
enough fuel pressure? if theres not enough f.p then it wont start. should be a test port if you have a pressure gauge to hook up and see. not sure what spec is on those though.
Old November 25th, 2010, 09:19 AM   #4
likeaford
fuel relays replace both
likeaford is offline   Reply With Quote
Old November 25th, 2010, 09:45 AM   #5
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
fould plugs...had that problem on my 96 chevy ( know it's not ford but whatever)...would not start after sitting for a few hours, it would just spit and sputter..then finally it would start and idle/run fine. Needed new plugs
Old November 25th, 2010, 09:58 PM   #6
mikes06cbr
mikes06cbr's Avatar
where did you check for spark? from the coil or plug? sounds like a bad cap and rotor....
i had a astro van and i had spark and ran like shit cap and rotor later ran like new....
mikes06cbr is offline   Reply With Quote
Old November 29th, 2010, 11:22 PM   #7
chevyk10
FORD / GM
chevyk10's Avatar
I replaced the cap, rotor, coil, and few spark plugs, and she runs like new.
Page generated in 0.28261 seconds with 44 queries
