West Michigan Fabricator? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 18th, 2010, 08:15 PM   #1
curbdog17
Mini Van
curbdog17's Avatar
Default West Michigan Fabricator?
I friend of mine is looking for some one to make an adapter plate to run a certain intake on a motor he has.
Here are pics of what he needs.
Anyone do this type of work?
Old November 18th, 2010, 08:31 PM   #2
Tacker
Tacker's Avatar
Tell your friend to call CJ at SMRE performance 231-767-0483. He will help your friend find the parts he needs .
Old November 19th, 2010, 06:33 AM   #3
curbdog17
Mini Van
curbdog17's Avatar
Thanks Terry
Anyone else have any info
Old November 20th, 2010, 01:27 PM   #4
fabguy01
hammer down grabbin gears
fabguy01's Avatar
What is this for? unless it is some really custom engine its probably cheaper to buy the correct manifold rather than using what you have laying around. This is not a big problem, to make it would be very time consuming. And time is money. I think you are going to have $250-$300 invested. My opinion is to find a different option. But if you are dead set on using this set up give me a call 616-490-0717. Nate
fabguy01 is offline   Reply With Quote
Old November 20th, 2010, 01:33 PM   #5
curbdog17
Mini Van
curbdog17's Avatar
I will have Jeff call you. He said there are no aftermarket intakes for the engine he wants to use.
???engine??? Not sure what motor. I think he said a 300 V8 Buick
Old November 20th, 2010, 02:04 PM   #6
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Does he have the stock manifold to work off of. It might actually be easier and cheaper to turn the stock one into the adapter.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old November 21st, 2010, 11:24 AM   #7
curbdog17
Mini Van
curbdog17's Avatar
here the engine/intake info
The engine is a 64 buick 300 and the manifold is a 63 buick 215
Page generated in 0.24813 seconds with 44 queries
