Struts on a 1999 Taurus - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 18th, 2010, 02:36 PM   #1
greygoose
I'm the dude
greygoose's Avatar
Default Struts on a 1999 Taurus
Has anyone done it? How hard is it? I must admit, I have done a lot on cars but I've never changed struts.
Any tips of tricks would be much appreciated.
Old November 18th, 2010, 02:39 PM   #2
xj97sport
atv rider
xj97sport's Avatar
get qwick struts there more money but will make your life alot easier and the ride will be awsome, not only that im shure ur springs are broke on it ... you just dont know yet.
Old November 18th, 2010, 02:45 PM   #3
B
NINJA DEALER
B's Avatar
x2 on the quick struts. That is the only way to go! I had to do them on a 2000 once. Took me about 2 1/2 hours, had to take the back seat out, and my swaybar links were also broken, as well as the springs. All in all not a bad job. Makes it look like you put a 3" lift on the rear when your done if yours are as bad as mine were
B is offline   Reply With Quote
Old November 18th, 2010, 02:45 PM   #4
greygoose
I'm the dude
greygoose's Avatar
Yup, the passenger side rear spring is broken.
Old November 18th, 2010, 02:50 PM   #5
durango77
durango77's Avatar
tryed to do them a hour into it spring clamps broke spent 4 hours in er after 15 stiches took car to muffler man go with quick struts
durango77 is offline   Reply With Quote
Old November 18th, 2010, 02:51 PM   #6
greygoose
I'm the dude
greygoose's Avatar
I was planning on going with quick struts. I was told they just bolt right in, is this correct??
Old November 18th, 2010, 02:56 PM   #7
liftedandgifted
liftedandgifted's Avatar
Yep you don't have to take the old ones apart with quick struts. they come with mounts and springs. Like people say by links it will save you time. Also you need the car pretty high off the ground. If I remember right on Taurus's the bottom of the strut slides into the knuckle and you have to pry down on the knuckle.
liftedandgifted is offline   Reply With Quote
Old November 18th, 2010, 02:57 PM   #8
durango77
durango77's Avatar
The one's i got were.
Old November 18th, 2010, 03:01 PM   #9
greygoose
I'm the dude
greygoose's Avatar
Maybe I don't want to do this.
Old November 18th, 2010, 03:12 PM   #10
littletrucker
I'd hit that
littletrucker's Avatar
I did the rear strut on my gf's car.. it was pretty easy, ran into some trouble with the pinch bolt on the bottom... heat it up with a torch so it comes out without breaking....
i just replaced the strut, and used the old spring (it was OK)
And the sway bar links where broken.. id just get new ones, because if they are not broke, they will be shortly..
Old November 18th, 2010, 03:29 PM   #11
Bishop
Bishop's Avatar
Their easy. But Ive done quite a few. if you have an air hammer and a good impact its all cake. just buy new sway bar links and the rest should be trouble free.
Old November 18th, 2010, 03:35 PM   #12
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
With quick struts, it's easy. The biggest PITA of doing struts is if you are swapping out springs.
You may want to get new stabilizer bar links as you will probably fukc them up when removing them off the strut.
You have the strut to knuckle bolt at the bottom, the stabilizer link, and then the top three mounting bolts. Remove the top three mounting bolts, jack up the car, remove the stabilizer bar link and the lower bolt and it's out. Repeat for reassembly.
That's on the front, rear will be very similar except accessing the top three mounting bolts can be a PITA.
Old November 18th, 2010, 03:37 PM   #13
greygoose
I'm the dude
greygoose's Avatar
So sway bar links all the way around is a good idea?
Old November 18th, 2010, 03:41 PM   #14
GreaseMonkey
Pew pew!
I would buy the parts just in case to have them there, because sway bar links are really easy to fukc up when you're removing them especially on an 11 year old car. Trying to keep the allen head from getting stripped out when removing the nut is common. Then you're stuck using vice grips to hold on to the shaft and you can screw up the threads.
Old November 18th, 2010, 03:59 PM   #15
xj97sport
atv rider
xj97sport's Avatar
torch the sway bar links off if you got one
Old November 18th, 2010, 04:00 PM   #16
xj97sport
atv rider
xj97sport's Avatar
oh ... and get monroes ... if you get a cheap knock off you will have fitment issues and it will sit like a monster truck.
Old November 18th, 2010, 04:01 PM   #17
GreaseMonkey
Pew pew!
Yes, applying heat to a gas charged strut is an EXCELLENT idea.
Old November 18th, 2010, 04:17 PM   #18
xj97sport
atv rider
xj97sport's Avatar
did i say strut? ... nope i said sway bar link. k thx bye
Old November 18th, 2010, 04:18 PM   #19
GreaseMonkey
Pew pew!
What does one end of the sway bar link attach to that you'll be removing and taking a torch to?
The strut.
K thx bye moron.
Old November 18th, 2010, 04:22 PM   #20
liftedandgifted
DO NOT DO IT THIS WAY. Leave the bolts in the top so they hold the strut up when you pry down on the knuckle. Undo/remove link first. Then remove bottom pinch bolt. Pry/hammer knuckle down and pivot out of the way when strut comes out. remove three upper nuts.
Page generated in 0.29984 seconds with 83 queries
