14 bolt ff questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 18th, 2010, 09:19 AM   #1
tgk4880
tgk4880's Avatar
Send a message via AIM to tgk4880
Default 14 bolt ff questions
are 14 bolt ff only posi/locker? or are they limited slip or open diff?
i am in the market for a 14 bolt ff and do not want to deal with one wheel wonders
thanks
tgk4880 is offline   Reply With Quote
Old November 18th, 2010, 09:24 AM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
posi and limited slip is the same. they came with open, gov lock (posi or limited slip whatever you prefer) or the CUCV military version came with a detroit locker and 4:56's
Old November 18th, 2010, 09:30 AM   #3
Complete Off Road
Complete Off Road's Avatar
Here's a link to aftermarket lockers and posi's for the 14T
http://completeoffroad.com/c-67267-g...-carriers.html
Complete Off Road is offline   Reply With Quote
Old November 18th, 2010, 04:14 PM   #4
tgk4880
tgk4880's Avatar
if i get a 14 bolt ff off a van or 2wd does it have the same wms?
Old November 18th, 2010, 04:51 PM   #5
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
I think the width is different in a van than what comes in a truck.
CHEVYRCKS is offline   Reply With Quote
Old November 18th, 2010, 04:58 PM   #6
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Looks like a van is 70" a SRW out of a truck is 67.5" dully are 72" and cab and chassis are 63.5"
http://www.pirate4x4.com/tech/billav...ble/index.html
Old November 20th, 2010, 10:24 AM   #7
tgk4880
tgk4880's Avatar
okay i got an axle now and im not positive but i read some where that from 73-80 4.10 gears and up have limited slip(gov lock whatever) and 81-up 4.56 gears and up have limited slip? i have a 14b ff 4.10 from January of 76 so what should it have?
also i am swapping this into my 95 k1500 so i know i have to move the spring perches from 42.5" to 46" or 47" what ever it is but when i weld the new ones on should i keep the same pinion angle or change it
last but not least the u-joint, should i get a 1350 series(which is for the 14 b) and just use two caps from my 1310 series(from my 10 bolt) so i can use my stock drive shaft?
Old November 20th, 2010, 12:06 PM   #8
tgk4880
tgk4880's Avatar
anyone know cause im putting it in today
Old November 20th, 2010, 12:13 PM   #9
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
First, pull the diff cover off and look, a govloc will have a bunch of extra parts inside.
Second, with a non-cv driveshaft match the t-case output angle with the rear diff pinion angle.
Third, they make a conversion u-joint for that application.
Old November 20th, 2010, 12:15 PM   #10
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
You're probably better off using a conversion joint of some sort. I've never dealt with them really but I don't think putting used caps on a new U-joint is a good Idea. Try calling the Auto Zone in Fenton and ask for Jim. He's a u-joint expert. He will probably know what the part number is to the U-joint you will need to make it work.
As far a pinion angle, if you don't have a cv shaft the angle of the joint on the axle and the angle of the joint on the t-case or trans should be the same for best results.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old December 10th, 2010, 07:02 PM   #11
1985fordman
hey guys i gotta question for ya. i got a 78 ford with a dana 44 straight axle up front and a gm 14 in the back both with 410 gears welded. is there any way i can make the rear 8 lug a 5 bolt 5.5 to fit my old rims?
1985fordman is offline   Reply With Quote
Old December 11th, 2010, 11:18 AM   #12
Jeepaholic
Jeepaholic's Avatar
http://www.solidaxle.com/productcart...&idcategory=11
Tags
14 bolt, full floater, posi
Page generated in 0.41720 seconds with 59 queries
