samurai spoa driveshafts? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2010, 11:29 AM   #1
bdd1469
bdd
bdd1469's Avatar
Default samurai spoa driveshafts?
Hey im helping a freind do a spoa on his sammy with stock springs.do we need longer driveshafts? Also, doing a 1.6 efi swap from 93 tracker to the sammy which is carbed ,any sugestions on using the tracker wire harness would be great. THANKS
Old November 16th, 2010, 12:36 PM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Yes, I'd look at lowrangeoffroad.com for the driveshaft spacers. They are cheap and easy. You may also need longer brake lines, also found on that site.
Old November 16th, 2010, 07:15 PM   #3
bdd1469
bdd
bdd1469's Avatar
Thanks, i was hoping they were available so we dont need new shafts.
Old November 16th, 2010, 09:13 PM   #4
scottie
Eye candy
scottie's Avatar
I put 1.6 FI on my 1.3. I removed all unnecessary wires from both harnesses.
Old November 17th, 2010, 08:16 AM   #5
A4X4SPIT
A4X4SPIT's Avatar
the spacers are the easy way to go cant really mess up. a backyard cheep fix is this
if your not going too long you can use the drive shaft to keep everything straight while welding
another thing I do when doing a spring over is to cheat the ft axle foward about a inch by moving the center pin hole in the perch&top plates it helps keep tires from rubbing on the rocker panels.
Ive done lifts with & without longer lines depending on the budget .you can cut off the brake line holding bracket & weld on a tab to lower it .
A4X4SPIT is offline   Reply With Quote
Page generated in 0.14239 seconds with 38 queries
