Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 96 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 2nd, 2013, 08:47 PM   #1901
Grassman
2jz specialist
Grassman's Avatar
good thing we called it quits
Old January 2nd, 2013, 09:01 PM   #1902
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
Pretty sure i have on as well, Just let me know.
Old January 2nd, 2013, 09:03 PM   #1903
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
5.5"s from.trans to.tcase on the short tail
Thanks
Originally Posted by crosseyed cat View Post
I think i have one . Ill check 2 morrow,call me to remind me 231-878-0588
Will do, thanks bud!
It would be fine, the case is mounted to the crossmember so it would stay together, not even sure I broke it yesterday. I think the polly bushings at the frame and hard mount on the trans might be the issue. Think I'm gonna soft mount the trans to the crossmember and just not sure how to do it yet.
Old January 2nd, 2013, 09:06 PM   #1904
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Yea the whole drivetrain needs to move as one.
Sent from Samsung galaxy S3
Old January 2nd, 2013, 09:06 PM   #1905
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Awesome
Maybe by this weekend I can get one from somebody, I have to modify it for the clocked case.
Old January 2nd, 2013, 09:10 PM   #1906
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Hmmm, still, if I soft mount the tranny I have to soft mount the case. Right now the trans and case are attached together with the trans crossmember, then bushings at the frame. Guess they don't have enough give? Wonder if I can get softer bushings?
Old January 2nd, 2013, 09:13 PM   #1907
http://www.mustangdepot.com/OnLineCa...ion/mounts.htm
http://www.summitracing.com/search/p...sion/automatic
http://www.jegs.com/p/Trans-Dapt/Tra...53378/10002/-1
Old January 3rd, 2013, 09:34 AM   #1908
Grassman
2jz specialist
Grassman's Avatar
I'm up in TC on the way home today, I could pick it up for you if you would like. Let me know
Old January 5th, 2013, 05:42 PM   #1909
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Ok, 205 out, gone thru....I don't see anything wrong. I'm putting it back together and moving on to the front axle. I just had it apart to replace axle seals too.
Old January 5th, 2013, 08:07 PM   #1910
Shotgun
I only wheel with boats.
Shotgun's Avatar
That's no good.
Old January 9th, 2013, 09:54 PM   #1911
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
205 back in, noise still there
Front axle completely tore down, no problems found yet. Getting stumped.
Old January 10th, 2013, 06:09 AM   #1912
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
To many pages to look through but you have a cv in the front driveshaft? If so check the centering ball.
Old January 10th, 2013, 06:30 AM   #1913
I don't beleive he does, with the short shaft c6 and the 205 being clocked I don't think there was room.
Old January 10th, 2013, 06:56 AM   #1914
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
No, I do have one John, I got a 1310 to fit. That is how I fixed the front yoke exploding problem.
Aside from moving the cv by hand and feeling for slop, how do you check it? I don't see any problem with it so far.
Old January 10th, 2013, 08:05 AM   #1915
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
When I've had 1310 CVs wearing out, they usually sound like birds chirping at parking lot speeds. I've heard it on tons of other TJs too.
Old January 10th, 2013, 08:48 AM   #1916
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Im going to put my spare drive shaft in just for shits and grins...never know
Old January 10th, 2013, 07:37 PM   #1917
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Back together, new pinion bearings just cus, spare shaft installed, noise gone.
Looks like the driveshaft was the problem. Gonna tear it down and rebuild it so I'll post up what I find.
Old January 10th, 2013, 07:50 PM   #1918
trailrail302
Im going FAST!!!
trailrail302's Avatar
do you have any pics of how its mounted and where on the frame etc.? Im nervous of the extension housing cracking on mine too, Im trying to figure out how to mount it. i have an idea of how to tie in the 205 to the crossmember but im curious how you did yours. 205's are too damn heavy
I've also thought about running a stock mount under the trans and the tube bushings at the frame but not sure if that will be too soft.
trailrail302 is offline   Reply With Quote
Old January 10th, 2013, 08:05 PM   #1919
I ordered a tmr 205 mount to help with support.
http://www.tmrcustoms.com/store/inde...roducts_id=732
Old January 10th, 2013, 08:12 PM   #1920
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Here are a couple old pics
Installed
I'm going to add rubber mounts between both tranny and case, make 2 new crossmembers. No more at the frame bushings.
Page generated in 0.51779 seconds with 84 queries
