Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 86 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2012, 11:05 AM   #1701
Mines broken. Your faster .
Old September 16th, 2012, 11:45 AM   #1702
bluminade
Bluminade Has Arrived
bluminade's Avatar
the e303 is a lower end cam than the b303. the b303 is made for a stick and the e303 is made for an auto. but you can get a custom ground cam for not to much more than one of the cams i listed, and you can get alot closer to what your looking for.
jon, i think you could gain alot if you bought the gears out of my truck so i can get some new ones.
bluminade is offline   Reply With Quote
Old September 16th, 2012, 12:19 PM   #1703
deathbypsi
Brian R.
deathbypsi's Avatar
Kyle if your looking for more bottem end out of it you want to advance the cam 4º. Advancing will move the curve down about 500-700 rpm and if you retard it you would raise the curve the same amount. I use a stock cam in mine advanced 4º and it has way more power down low than the fresh 351 in my f150 tow rig.
In my opinion a stock cam would get you more torque below 4k than either of the Motorsport cams. But if you were to try a new converter with around 2500 stall that would let the motor get into its curve a little easier with the current cam.
Old September 16th, 2012, 12:32 PM   #1704
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Good info, thanks!
Old September 16th, 2012, 04:59 PM   #1705
bluminade
bluminade's Avatar
the bad thing about a stall converter is you will get your trans temp allot higher. for running trails and rock it will be slipping all the time.
Old September 16th, 2012, 05:17 PM   #1706
jhnyquest
goof ball
jhnyquest's Avatar
I have ran a stall for a long time and never had a problem.
Old September 16th, 2012, 07:50 PM   #1707
big86inthestixx
big86inthestixx's Avatar
I also have ran a 3200 stahl converter for years. They create more heat, but just get bigger better coolers. No issues.
In a rig with lower gears, you wont really even notice the stahl that much, plus a lighter rig..rangers buggies, and jeeps the Stahl is that much less noticeable.
And besides..its way more fun to skip over the rocks than crawl over them..
:D
Sent from my SPH-D710 using Tapatalk 2
Old September 16th, 2012, 08:11 PM   #1708
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I like the direction you are going with this....
Old September 16th, 2012, 08:33 PM   #1709
frdboy
frdboy's Avatar
Glad to hear its running better Kyle. I think a set of heads, (I would look for some trick flows or afr's myself) and a small converter would be a nice improvement. If you get serious about a cam lmk and we can do one that will run much better than those old school alphebet cams.
Old September 16th, 2012, 09:12 PM   #1710
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Glad its working better Kyle you really know how to drive that thing too
Old September 16th, 2012, 09:20 PM   #1711
deathbypsi
Brian R.
deathbypsi's Avatar
Here is my issue as Im running a very close combo to Kyles... Take a stock efi 5.0 and you have an easy 250hp and just over 300ftlb at very low rpm's. You add some heads,cam and intakes and you now have 100+ more HP but its all ABOVE 4500rpm and you will most likely lose torque below 3000rpm and then it will come on strong. Only way to get a bunch more power out of a small 302 cube motor is with more airflow and more RPM.
You spend 1500.00 on heads and valvetrain shit.
150-300 for a decent roller cam.
400-600 for good intakes.
200 for bigger injectors.
200+ for a bigger MAF.
Sounds like a great combo for a mud truck but I dont really see it making that much of an improvement crawling around at 1500-3000rpm.
Now the other option which I am leaning towards heavily is just leave the 5.0 stock and untouched and slap this bitch on for instant torque increase rite off idle.Most likely 100-150ftlb more.
http://www.kennebell.net/KBWebsite/S...aflowzilla.htm
After all said and done I bet the blower would end up cheaper also but havent done all the math yet.
Old September 16th, 2012, 09:27 PM   #1712
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I was thinking a small turbo, something that would spool up quick....that would be fun
Old September 16th, 2012, 09:37 PM   #1713
deathbypsi
Brian R.
deathbypsi's Avatar
Look on youtube for clips from 2011 or 2010 Ultimate Adventure...There was a guy there from Mopar in a TJ with a SRT-4 motor in it. The dude had to hit everything at full throttle, no finess due to the turbo being load sensitive.Once he got it spooled up it was just off like a rocket. I drive a turbo Ranger everyday and I couldnt imagine tryin to wheel with a motor like that.
Purely my own opinions mind everybody.
Old September 16th, 2012, 09:44 PM   #1714
frdboy
frdboy's Avatar
No doubt a blower or small turbo would be fun, not sure about less money though. Not familar with what comes with the KB Kit but you still might need bigger injectors, maf, a fmu and a better fuel pump depending on what you have now.
Most people over-cam thier engines and like you said it is a dog down low but a set of heads the right size and a matching cam will increase tq from idle up, look at the gm ls engines, bigger heads and small cams with great tq and hp.
Old September 16th, 2012, 10:00 PM   #1715
deathbypsi
Brian R.
deathbypsi's Avatar
Yeah Im not sure what all comes with the KB kit or what else is required. Might be a wash cost wise. But dam a screw blower would be hard to beat for instant grunt!
I have been into Foxbody stuff since 1989 and I know back in the day people could throw a KB on a bone stock mustang and make 350-380hp all day. 400+ was a easy goal and still safe for a factory shortblock.
Maybe Im just to big of a boost junky!
Old September 16th, 2012, 10:08 PM   #1716
frdboy
frdboy's Avatar
I am the opposite, my dumbass always stays all motor
Old September 24th, 2012, 07:14 PM   #1717
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Tossed the spare up in the bed, I like it. Gonna make a mount and screw in hold down. Not to bad to get in and out.
I also put a new battery in it, got a deep cycle since I ruined 2 batteries in in the last 2 years from winching....see how it goes.
Old September 24th, 2012, 07:17 PM   #1718
Nice car....is that your daily driver
Old September 24th, 2012, 08:27 PM   #1719
Shotgun
I only wheel with boats.
Shotgun's Avatar
:bar:
Old September 24th, 2012, 08:28 PM   #1720
Shotgun
Shotgun's Avatar
Originally Posted by Shotgun View Post
:bar:
:bdr:
Page generated in 0.42687 seconds with 84 queries
