Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 79 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 21st, 2012, 08:58 AM   #1561
I think I used elec conduit from lowes (not plastic), was easy to bend on my own to get the shapes I wanted.
you need a damn good elec fan set-up to since you won't have air flow through the rad. when driving.
Old August 21st, 2012, 09:44 PM   #1562
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
You think a Taurus fan would be good?
Old August 22nd, 2012, 02:47 AM   #1563
big86inthestixx
big86inthestixx's Avatar
I think a taurus fan has the one of the highest cfms out there. Unless you spend high $ for a dual. BUT most duals i have ever seen still only move roughly the same cfm as a Taurus..
I would think if you gave yourself about a 25% safety factor on your radiator..meaning the square inches of surface area on radiator is 35% greater than the cubic inches of your motor. Then put a good fan on it with a good shroud you should be fine. Plus dont forget all the tube running back to radiator will work like a super in efficient radiator.
But all that is just my .02, as usual you can only do what will fit in your application.
Sent from my SPH-D710 using Tapatalk 2
Old August 22nd, 2012, 02:51 AM   #1564
deathbypsi
Brian R.
deathbypsi's Avatar
are you just moving your radiator or you gonna buy a whole new one in a bigger size?
Old August 22nd, 2012, 04:53 AM   #1565
Shotgun
I only wheel with boats.
Shotgun's Avatar
RBV's are gay!
Old August 22nd, 2012, 06:05 AM   #1566
frdboy
frdboy's Avatar
A taurus fan will work great. They draw a bunch of current though, will need some good wiring. Do you have your battery in back as well? If so I would run a relay right off the battery with a maxi-fuse to keep the heavy wiring short. Do you know how big your alternator is? You find a 130A that will fit fairly easily, that is what I run on the mustang.
Old August 22nd, 2012, 06:07 AM   #1567
s.hembree
s.hembree's Avatar
The contour fan is also a good option that is a little smaller than the taurus fan. Being a dual fan setup it's a little easier on amperage draw at start up too. That is what Brandon and I are running.
Old August 22nd, 2012, 06:11 AM   #1568
frdboy
frdboy's Avatar
Yeah, the dual contour/focus fans are bad ass as well, I actually run an early single contour fan on my car but with E85 it hardly needs a fan anyways.
Old August 22nd, 2012, 06:12 AM   #1569
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Hey Kyle, I have two "Intrepid" dual fans hanging on my barn wall. I ran them on the Flaresid with the 5.0. You are welcome to them if you want. I'm going back to a mechanical with the 460.
Old August 22nd, 2012, 06:25 AM   #1570
tonka toy
It's got a HEMI!
tonka toy's Avatar
Come get the plumbing off the truggy. John ran it when he put the motor in for my.
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Old August 22nd, 2012, 06:33 AM   #1571
I ran the taurus fan on the aluminum radiator I gave you a while back with no issues on my winsdor. But I run that taurus fan controller set-up then and still.
http://www.hollisterroad.com/proddet...?prod=MarkVIII
Old August 22nd, 2012, 08:02 AM   #1572
I run that relay setup on my TJ with the taurus fan as well.
Old August 22nd, 2012, 08:05 AM   #1573
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
That radiator has 410 cubic inches, plus with all the tubing I think ill be good.
No, I have a big aluminum fan.
I'll take them, even if I just use them for my tyranny and steering.coolers, thanks!
Ok, will do when I get your motor.
So I gonna have the same set up, ill be good. I just need that.controller. My other one just took a crap anyhow.
Thanks for all the input guys, I look into the dual contour fans aswell.
Old August 22nd, 2012, 08:07 AM   #1574
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I have a 130 amp alternator, or a 3g I put on this year. And my battery is going back by the fan/radiator. Right now its in the cab.
Old August 24th, 2012, 08:15 PM   #1575
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Got a cool new upgrade, BTR aluminum beadlocks. Hope to get them on this weekend.
Old August 24th, 2012, 08:41 PM   #1576
firehawk
Live Action!
firehawk's Avatar
Those look nice!!!
Old August 25th, 2012, 07:11 AM   #1577
big86inthestixx
Nice..when'd you pick them up? I think they need a little "Green" But definitely a sweet looking rim.
Old August 25th, 2012, 07:15 AM   #1578
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Hrmmm I need new rims
Old August 25th, 2012, 07:17 AM   #1579
jhnyquest
goof ball
jhnyquest's Avatar
Old August 25th, 2012, 07:52 AM   #1580
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Wow. All of the cool kids are running them. Or did you steal Greg's when he was not looking?
JohnnyJ is online now   Reply With Quote
Page generated in 0.47628 seconds with 84 queries
