Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 74 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 1st, 2012, 09:19 PM   #1461
liv2mx
i like jungle gym's.
liv2mx's Avatar
he just wanted to stop and talk to me. think he definetly had the fastest time going.
Old July 1st, 2012, 10:35 PM   #1462
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I had fun! Next time I'll finish...
Maybe someone should orchestrate a GL4X4 comp someplace....that would be fun.
Old July 3rd, 2012, 08:14 PM   #1463
robn69
robn69's Avatar
Originally Posted by hamsmotorsports View Post
cage looks sweet. Love the look of this truck.
x2
robn69 is offline   Reply With Quote
Old July 3rd, 2012, 09:12 PM   #1464
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Thanks!
Got a new fuel pump today, also may have found an automatic mustang ecu to get me all straightened out
Old July 6th, 2012, 10:33 PM   #1465
Ford rules
Ford rules's Avatar
I really like the way they mounted this radiator, wish i would have seen this before i mounted mine. Just figured id post it up for ya.
http://www.pirate4x4.com/forum/showt...822939&page=19
Old July 7th, 2012, 09:49 AM   #1466
Been busy? you've been quiet, or have you been hiding in the ac like the rest of us
Old July 7th, 2012, 01:42 PM   #1467
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I'll have to check that out when I get to a computer...there is a lot going on.
Yup, family time the past few days, but I did get a new to me set of GT40 heads, ordered a automatic ecu and put that new fuel pump in. The heat has been brutal, maybe ill get something more substantial done in the next few days.
Old July 7th, 2012, 01:43 PM   #1468
tonka toy
It's got a HEMI!
tonka toy's Avatar
He is selling it and buying a golfcart
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Old July 7th, 2012, 02:54 PM   #1469
Ford rules
Ford rules's Avatar
Think you could grab a pic of your throttle body/cable bracket? Thanks
Old July 7th, 2012, 04:34 PM   #1470
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
When I get home I will.
Old July 7th, 2012, 04:42 PM   #1471
Ford rules
Ford rules's Avatar
Awesome thanks!!
Old July 7th, 2012, 07:06 PM   #1472
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Throttle cable mount, pretty much stock mustang, even the cable.
Got my new ecu today, put it in and its running rough. I gotta bring it to Adam to check it all out. It runs great cold, but when it switches into open loop it starts running bad, erratic. I can feel it switch over, gotta be something I'm missing.
Old July 7th, 2012, 07:13 PM   #1473
GOtta be something simple like a ground or bad connection or something simple just hidden. Not sure if this will help at all but what the hell it never hurts.
http://77cj.littlekeylime.com/5_0l_wiring.html
Old July 7th, 2012, 08:58 PM   #1474
Ford rules
Ford rules's Avatar
Sweet thanks for that pic.
Sucks that ECU didnt take care of it.
Old July 9th, 2012, 02:29 PM   #1475
deathbypsi
Brian R.
deathbypsi's Avatar
If you can actually feel it running rough as it warms up I would look at your Temp sensor for the ecm. Maybe replace it or double check that the wiring is good. That is the only sensor the ecm goes by to switch over to closed loop.
Old July 9th, 2012, 04:36 PM   #1476
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Yeah, I'm gonna have to look st that one. I went out this morning, reset the timing, adjusted my idle and reset the tps and it ran great. Took it down the road and it was good for a little, then started missing a bucking, got so bad I could barley park it was stalling and running so rough. Went and started it back up about an hour later and it ran good again. Gonna pull the codes, maybe swap some parts around.
I'm pretty sure my old ecu was bad, my tps wouldn't work as is so I jumped a ground to make it work. With the new ecu I removed the jumper and it still works. I'm sure I have a bad sensor at this point.
Old July 9th, 2012, 09:40 PM   #1477
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Pulled codes, got one for the ect sensor. Checked resistance on it at different temps and to me it looked all in range. Got a maf code too, cleaned it but I don't know if it helped or not. I have always had the maf code, guess ill start there.
Old July 9th, 2012, 09:52 PM   #1478
Ford rules
Ford rules's Avatar
Ever try to clock the MAF in a different spot, I've heard sometimes they won't pickup the right reading if not clocked different.
Probably not the issue but worth a try.
Old July 9th, 2012, 10:20 PM   #1479
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I have done it in the past, but not lately, I'll give it a shot.
Old July 28th, 2012, 09:17 PM   #1480
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Exo is on, new bed cage started
Page generated in 0.47168 seconds with 84 queries
