Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 64 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 16th, 2012, 07:50 PM   #1261
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Ok, since it appears my trans to shitting out on me, reverse is going bad now. I have another c6 that had a bad front seal and the torque converter was grooved causing the seal to leak I think. I am gonna just replace the seals and run it, but in the mean time I want to build a back up. What are my options? Would it be worth building something other than a c6?
Old April 16th, 2012, 07:56 PM   #1262
At this point a trans swap from a c6 will mean relocation of crossmember and new driveshafts along with possibly altering the floor of the cab more then you already have as pretty much another auto will most likely be longer.
aod, aode, 4r70w, e4od, c4......c4 would be the only option similar in length over all, the other three would give you overdrive. Ont the upside a longer trans would give you a longer front driveshaft.
Old April 16th, 2012, 08:01 PM   #1263
frdboy
frdboy's Avatar
I would stick with the C6, should be bulit proof once built right. I love C4's and run one in my almost 650+hp stang but I am not sure how they handle 40" tires and Kyle's driving
Old April 16th, 2012, 08:14 PM   #1264
big86inthestixx
big86inthestixx's Avatar
I say stick with c6 if u dont want overdrive or all the relocation work to put any other trans. C6 parts are pretty cheap, easy to find and lots and lots of aftermarket upgrades, to help handle bigger meats, higher hp..etc .
Just my .02
Would be good for kyle to have OD since he enjoys the skinny pedal from what I hear, speed is the key..Right?
Sent from my SPH-D710 using Tapatalk 2
Old April 16th, 2012, 08:34 PM   #1265
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Lol. OD would be nice haha , 3rd gear runs out quick.
Ok, c6 it is. What about a stall converter? What would be good foroff road? Seems like it will bog off idle and a stall would help that when I hoot on it. Not that I have even ever gone wot, or ever plan on it .....
Old April 16th, 2012, 08:51 PM   #1266
big86inthestixx
IF u do a stall converter..its kinda hard to rock crawl..u rock race, and slow rolling offroad I would recommend a big cooler..
My th350 has 3000 stahl converter, workz ok except..slow going. Makes it hard to feather the go pedal..
But if you choose a smaller stahl youd be pretty happy, 1500-2500 is how id do it if I did it again. Except the Coan was high $..so I wont be changing it soon..
Im racking up the pennies here..lol..
Old April 16th, 2012, 08:56 PM   #1267
x2
I like the lower stall.
Old April 16th, 2012, 08:57 PM   #1268
big86inthestixx
Dont get me wrong u can crawl with a stahl converter,stuff gets oober hot,oober fast..so higher rpm is better, but that means faster. Nothing new for u though..
Old April 16th, 2012, 09:11 PM   #1269
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
I believe that the stock stall speed of a c6 converter is around 1600-1800 rpm.
Old April 16th, 2012, 09:44 PM   #1270
frdboy
frdboy's Avatar
I would also stay lower stall, something 2000-2400 I think would be a good compromise.
Old April 16th, 2012, 09:48 PM   #1271
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I was thinking around 2200. But I guess I really don't know what I am dealing with. Think ill just run what I have for now.
Old April 16th, 2012, 09:49 PM   #1272
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
I have a stock one sitting on my bench Kyle, you are welcome to it.
Old April 16th, 2012, 09:50 PM   #1273
Ford rules
Ford rules's Avatar
Id keep the stall around stock, like said high stalls arent great for crawling and produce lots of heat real fast.
I think you would like to have an OD though going fast is fun, im glad i have OD.
If your looking for a place to have the tranny built i would give cars high performance a call they did my tranny and i was very happy with it good price good customer service and good quality work. heres the number if you wanna try em. 248 682 3840
Old April 16th, 2012, 09:53 PM   #1274
Ford rules
Ford rules's Avatar
Can always just have your stocker rebuilt also. This is what i hade done with my 4R70W cost $155 and they bumped the stall right about 1900-2000.
Old April 16th, 2012, 10:15 PM   #1275
bluminade
Bluminade Has Arrived
bluminade's Avatar
i run the c4 in mine. my converter is lower than stock, i had it built that way. it keeps the temps down and the trans shifts a little smoother.
once its in low range you can not even tell its lower than stock.
my c4 holds up prety good with 40ds, and i am not very nice to it.
bluminade is offline   Reply With Quote
Old April 17th, 2012, 12:27 AM   #1276
Sfa_Colorado
RIDGEOFFROAD.COM
Sfa_Colorado's Avatar
true story
Sfa_Colorado is offline   Reply With Quote
Old April 17th, 2012, 09:26 AM   #1277
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
C6 is one of the toughest trans out there. Stock rebuild and good converter and a good cooler and you will be fine for a long time.
Old April 17th, 2012, 05:43 PM   #1278
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I have no concerns with the c6, I was just preparing myself to build one and I wanted to be sure there wasn't a better option for me.
Thanks everyone for their input.
When I do build it, it will get a reverse manual valve body, heavy duty internals, and a stock, 1600 to 1800 stall. If I need more low end power, I will swap cams in my engine, maybe do some more head work.
Old April 17th, 2012, 06:53 PM   #1279
big86inthestixx
:thumbup:
Old April 23rd, 2012, 10:14 AM   #1280
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Get it fixed punk. Lets go to the badlands
Mr. Beefy is online now   Reply With Quote
Page generated in 0.52259 seconds with 84 queries
