Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 60 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2012, 08:38 AM   #1181
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Nice work Kyle
Mr. Beefy is online now   Reply With Quote
Old March 5th, 2012, 10:51 AM   #1182
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Originally Posted by Kyle M. View Post
T case support made, added to the original tranny cross
Installed
Think that is good or should I add more?
I would think about adding a gusset on the top side of the arm going to the t-case. That rectangular tubing is going to see a lot of stress once that 165lb tcase starts trying to bounce. The poly bushings could be an issue as well since they are going to see quite a bit of twisting and side loading.
This is the mount that I made for mine - all of the load is is transferred straight down into the cross member, which doesn't allow for any twist or flex at the poly bushings.
Old March 5th, 2012, 03:15 PM   #1183
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Maybe I will add another frame side mount to my crossmember, so it mounts to the frame at 3 points to help support things.
Old March 5th, 2012, 08:38 PM   #1184
Ford rules
Ford rules's Avatar
Those 3 holes on the driver side of the transfer case are for a torque mount. I would build a mount off those to the frame with a bushing in there and then it should be good to go. I wouldnt trust just the one side mount though.
Old March 5th, 2012, 08:44 PM   #1185
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I don't think there is enough room to use it, unless I can come up with a easy way to make more room. I don't like any ideas I come up with. Seems like the all will be impossible to install or make it really hard to put the case in.
Old March 5th, 2012, 08:46 PM   #1186
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
I got this kit for my t-case too. Still not sure if I will have room to install it or not ... I can't speak for Kyle but I don't have the kind of room you do under there ... and mine is clocked up so the mount will have to be modified to begin with ... but at least I have something to work with ...
Old March 18th, 2012, 07:22 PM   #1187
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Well, guess I should update this. Took it out wheeling last weekend and broke it again. I ended up splitting the yoke on the front output of the case, apparently you can remove too much material
When the yoke broke it took out my front twin stick shifter linkage.
Gonna run 1330 joints now and I am gonna try and fit a cv in there so I can use all my travel.
Breakage
Gotta get it ready soon, going south in a couple weeks. Need to make a skid and a drive shaft.
Oh, and it runs way better now.
Old March 18th, 2012, 07:57 PM   #1188
Problem we have with running the cv style shafts is that we have short tailshaft c6s so there isn't room for it next to the trans.
Old March 18th, 2012, 07:57 PM   #1189
What's south in a couple weeks?
Old March 18th, 2012, 08:15 PM   #1190
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Heading to the badlands with Randy and Greg to help out in the pits. Gonna bring the truck down to wheel around in when we have time.
Old March 20th, 2012, 07:38 PM   #1191
Sounds fun
Old March 20th, 2012, 09:02 PM   #1192
Shotgun
I only wheel with boats.
Shotgun's Avatar
yeah no shit, sounds like a blast.
Old March 23rd, 2012, 08:02 PM   #1193
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Alright, did some looking and found I can fit a cv in my front shaft, so that should help me get some strength. I have 3, 1310 cv ranger shafts so I ordered a np 205 1310 cv yoke so now I just need to shorten a shaft and I will be all set.
Also, I ordered my steel to build my exo today. Decided to go with ASTM A500 grade B structure steel pipe, with a 1.25 ID, .140 wall, 1.660 OD. Should be just fine and the price was right. Gonna start in 2 weeks.
Old March 23rd, 2012, 08:28 PM   #1194
Grassman
2jz specialist
Grassman's Avatar
Get your crap fixed so your ready
Old March 23rd, 2012, 08:31 PM   #1195
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I will be ready by Sunday. Just need to make a front drive shaft, adjust my limit straps and finish my skid.
Old March 24th, 2012, 01:11 AM   #1196
Mr. Beefy
BFT!
Mr. Beefy's Avatar
You should prolly get some new limit straps...
Old March 24th, 2012, 01:47 AM   #1197
Shotgun
Shotgun's Avatar
Did you order the steel from James?
Old March 24th, 2012, 05:57 AM   #1198
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Lol
No, Alro steel.
Old March 25th, 2012, 08:03 PM   #1199
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Front drive shaft made and Installed, swapped out wedge bushings for better pinion angle, fixed tcase shifter, made a skid plate frame, just need to skin it with some 3/16, and put longer shocks in the rear along with some shock hoops.
Pics
Skid
Shocks
If the longer shocks work out, ill get some new, better ones as these ones are whipped
All I have left to do is flex it out and check for bind....need to find someone close with an rti ramp.....
Old March 25th, 2012, 08:14 PM   #1200
tonka toy
It's got a HEMI!
tonka toy's Avatar
What size shocks are those? I have a set of BDS lift shocks that were on my truggy for 3 trips. I can't use them on the yota so I have no use for them, I'll make you a screaming deal if they will work and you want them.
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Page generated in 0.41183 seconds with 84 queries
