Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 59 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2012, 02:10 PM   #1161
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
It did great besides my running issues. Felt really stable and I am sure with a little time a tuning, it will be way better than what it was before.
After that, I am gonna work on the looks of this thing.....it's getting kinda beat up and ugly.
Old February 27th, 2012, 02:21 PM   #1162
2fst4you
2fst4you's Avatar
So it wheeled pretty good on 42s!! Ya sounded a little rough. I thought it looked pretty nice....now that your done with the build you can help me do mine
Old February 28th, 2012, 02:45 AM   #1163
Shotgun
I only wheel with boats.
Shotgun's Avatar
Hey now, get in line. He's my bitch next.
Old February 28th, 2012, 09:07 PM   #1164
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Getting drive shaft stuff figured out, gonna change my pinion angle a little, I am machining the pinion yoke so the nut is burried in deeper, then making a shim to go under the yoke to gain some room from the pinion. Gonna do this on the t case too, should allow me to get full droop.
New tranny is installed, thinking of getting a reverse manual valve body now too......first is too far away from reverse. Getting close to being wheelable again.
Old February 28th, 2012, 09:13 PM   #1165
Grassman
2jz specialist
Grassman's Avatar
working fast again....got the wheeling bug do ya?
Old February 28th, 2012, 09:21 PM   #1166
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Something like that lol
Old February 29th, 2012, 07:09 AM   #1167
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Old March 1st, 2012, 06:37 PM   #1168
Ford rules
Ford rules's Avatar
Do you have a mount for that 205? If not thats why that tranny mount broke way to much weight to hang off aluminum, id make anothe mount for the back of it...
Looks awesome though!!!!
Old March 1st, 2012, 06:45 PM   #1169
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
No, I don't. CTB2 brought that up with me today too. It has moved to the top of the list.
Old March 1st, 2012, 07:07 PM   #1170
Ford rules
Ford rules's Avatar
Ya deffinatley need somethin back there!
I looked for a pic of mine but i cant find any i can grab some tmrw if youd like.
I just made a crosmember running across the fram and have a 1/4'' plate welded to the tube then bolts to the driver side of the case.
Old March 1st, 2012, 07:55 PM   #1171
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I was thinking I will remake the pto cover out of 1/4 plate, then tie it into my trans cross (it is hard mounted to the trans with bushings at the frame) Then when I make my skid, maybe I will tie it into that too with a rubber mount. I just don't see any better way to support it then that.
Old March 1st, 2012, 08:16 PM   #1172
Ford rules
Ford rules's Avatar
Sounds like that will work good!
Old March 1st, 2012, 08:18 PM   #1173
My 205 rests on my skid plate. The plate push's up ever so lightly on the tcase. Haven't had any problems yet, and I think I can say I have tried hard enough in the last 2+ years
Old March 2nd, 2012, 01:45 PM   #1174
Ford rules
Ford rules's Avatar
That's how mine was for the first year I had a 205 just sat on my radius arm cross member, I had to change it with the doubler though.
Old March 3rd, 2012, 03:48 PM   #1175
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
T case support made, added to the original tranny cross
Installed
Think that is good or should I add more?
I also made a new shifter linkage, better than the busted up one for sure! I made it out of 1/2" thick aluminum.
Old March 3rd, 2012, 03:51 PM   #1176
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Truck Looks Good and Nice on building the parts.
Old March 3rd, 2012, 04:11 PM   #1177
tonka toy
It's got a HEMI!
tonka toy's Avatar
It will work fine for everyone else but the way you drive you better make it stronger
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Old March 3rd, 2012, 04:26 PM   #1178
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Lol
Old March 3rd, 2012, 07:38 PM   #1179
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Here are my newly modified yokes. I counter bored the pinion nut holes 1/4" deeper and put spacers under the yoke when installed to gain the clearance i need. I am gonna run a 1330 yoke on my 60 (had it) and a 1310 yoke on the 205 with a conversion joint at the axle for now. If I have no issues I may buy another 1310 yoke. Might just step up to 1350 too, who knows....
Old March 4th, 2012, 03:07 PM   #1180
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Pulled codes, checked timing on the ranger. Only codes I got were for the VSS that I dont have installed and low voltage to my MAF. Base timing was set at 10, but I bumped it up to 13. I turned the fuel pressure back down to 39psi since it seemed rich. I put new plugs in too.
Seems like it runs fine, no bucking so far. Maybe I need a new maf if I still have problems.
The tranny pump whines, but seems to hold first just fine. Did a whole bunch of hole shots in the road and it took right off and reved up pretty good. Guess we will see next time out how it does.
I also cut my gate out from 1st to 3rd, and angled the others so I can go reverse to drive and drive to reverse easier, much better.
Page generated in 0.40161 seconds with 84 queries
