Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 37 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 1st, 2011, 06:22 PM   #721
Tacker
Tacker's Avatar
Fuck Yeah
Old November 4th, 2011, 07:36 PM   #722
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Motor is in its home, tranny is in. Next is to make a crossmember then mount the t case.
I gutted the core support for radiator clearance, should have lots of room. Just need to figure out what radiator I am gonna use.
Old November 4th, 2011, 08:29 PM   #723
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Nice Kyle.
Old November 4th, 2011, 09:20 PM   #724
bluminade
Bluminade Has Arrived
bluminade's Avatar
is the pump and bracket going to work for you?
bluminade is offline   Reply With Quote
Old November 4th, 2011, 09:35 PM   #725
Grassman
2jz specialist
Grassman's Avatar
is the crossmember for your shocks going to fit still?
Old November 5th, 2011, 03:57 AM   #726
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Not sure yet, haven't messed with it, but I am planning on it.
With plenty of room. This motor sits lower than the 4.0.
Old November 5th, 2011, 09:50 PM   #727
Grassman
2jz specialist
Grassman's Avatar
i got some parts for you
Old November 6th, 2011, 06:57 AM   #728
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
You da man
Old November 6th, 2011, 04:02 PM   #729
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Made some progress today, fabbed a new crossmemeber. INstead of using a tranny mount I used a couple bushings at the frame. I had some shock tabs laying around and so tube so I got building. Heres the crossmember
Then after that I finished all my welding on the front axle, moved my bump stops so they do something, started building anti wrap bar, put my 35 spline spicer shafts on with new U joints and tacked the caps, then I put the knuckles on......wont be long till it is a roller.
Next I am gonna finish the radiator, maybe work on exhaust, then maybe some drive shafts and steering. Debating if I am gonna rework my rear frame now and add my fuel cell or wait and do it when I feel like it.
I am ready to go wheel, tired of building already lol
Old November 6th, 2011, 04:07 PM   #730
Shotgun
I only wheel with boats.
Shotgun's Avatar
pile of shit!
Wished I could of helped today.
Old November 6th, 2011, 04:10 PM   #731
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Told ya I was gonna be out there for sure today lol
Old November 6th, 2011, 04:27 PM   #732
bluminade
bluminade's Avatar
are you running full circle clips on your axle joints?
Old November 6th, 2011, 04:42 PM   #733
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I have em but did feel like machining out the inside of the shafts so they fit. I just put a healthy tack on them all, with the stock clip I think I will be alright....what do you think?
Old November 6th, 2011, 04:48 PM   #734
Worked for me. I have found running full circle clips on non-chromo shafts eggs the hole by allowing the cap to spin, eventually making a very loose fit on the cap.
Old November 6th, 2011, 07:13 PM   #735
bluminade
bluminade's Avatar
i have done both. i have found that its alot easier to change them or work on them on the trail. i would weld them if i did not have any clips and was in a hurry. i have cut out the shafts to take the full circle clips with cut off wheel, or sawzaw it does not take that long and for easiness later i would take the time now while your not wheeling or dont have plans to in the near future.
what shafts and what joints are you running?
Old November 6th, 2011, 07:14 PM   #736
He has stock inners, dana 70 35 spline stubs and the non-greasable spicer joints. I believe.
Old November 6th, 2011, 07:41 PM   #737
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Yup, that is what I have
As far as putting the clips in, I already welded the caps, and I would have anyway, but when I break something I will upgrade and use them then.
Old November 6th, 2011, 07:44 PM   #738
Shotgun
Shotgun's Avatar
I was a bit busy sleeping today since I actually start my work week tonight.
Old November 16th, 2011, 07:53 PM   #739
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Well, I guess I have a couple pictures
My new yokes, 1310 for the 60 and a 1350 for the 205
The truck is a roller, sitting on bumps in the front.
Thinking about moving my lower stock mounts out to the c's, anyone have any input on welding to the 87,60 king pin c?
Old November 16th, 2011, 07:57 PM   #740
Ill let you know how it worked out on Saturday lol.
Page generated in 0.43592 seconds with 84 queries
