Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 35 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 25th, 2011, 09:17 PM   #681
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Originally Posted by Kyle M. View Post
That could work, or I can leave mine with John and you can drop yours there when you get time?
I know where he works, I could always swing by when I get out.
This will work, I can bring it with me tomorrow. What time will you get out of work John? I don't start until 6pm, but I could get there a little bit earlier if you wanted.
Old October 25th, 2011, 09:19 PM   #682
Ill stop by thurs. I'm out @ 5 tomorrow, but 5:30-6 thurs.
Old October 25th, 2011, 09:36 PM   #683
bigblockford79
Big Block Ranger
Sounds good, I will toss it in the car when I get home in the AM just to make sure I have it. I will see you Thursday.
Old October 26th, 2011, 04:19 AM   #684
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Thanks guys
Old October 26th, 2011, 03:57 PM   #685
deathbypsi
Brian R.
deathbypsi's Avatar
I bought a set of 289 manifolds from somebody on this site that used them in a Ranger like yours. They were to close to my firewall in my 90 Bronco2 so I didnt use em. LMK if you wanna see em.
Also, I used a Canton 90 adapter for my oil filter relocation. Its a way nicer part than those others.
Old October 26th, 2011, 04:00 PM   #686
We realized today at lunch, was that his frame is a 2wd 4cyl ranger frame. 2wd ranger frames use a different engine cross member then a 4wd ranger.
Old October 26th, 2011, 05:35 PM   #687
Ford rules
Ford rules's Avatar
Originally Posted by bigblockford79 View Post
What part of the filter kit isn't correct?? I have a block adapter if that is what you need, swap for the one you have?
I used early 60's car manifolds on my 302 swap into my 4x4, and I now have 97-98 Ex. manifolds on my 2WD with the 5.0. Big thing about the EX manifolds is making sure they didn't come off the GT40P heads.
Did you have to do much cutting to make these fit?? The problem with using a 2wd header (especially a 3/4 or full length) is the engine on a 4x4 is offset to the passenger side. This usually creates clearance issues with the frame. Also, the steering gear box location on a 4X4 tends to get very much in the way of certain header designs.
I had to cut maybe 1/4'' at the most on the passengger side upper frames rail to allow a little more room for the motor to torque back and forth. Othere then that i had no clerance issues gear box is no where close to them the steering shaft has about 3/8'' clerance.
http://www.landlproducts.com/details...=0&ItemID=1024
I am using this oil filter adapter it includes everything youll need its a lil spendy but the quality is great and ive never had problems with mine in the 2 yrs ive had it.
Heres some pics of my headers and engine cross member
Crossmember bolts in so i could do a pan gasket or whatever if needed.
Old October 26th, 2011, 06:04 PM   #688
bigblockford79
Big Block Ranger
Those do fit quite nicely. How much below the frame is your exhaust tubing? From the pics it looks rather low, might be prone to mother nature re-adjusting them for you Have you thought about adding to your cross member to include oil pan protection?
Kyle & John - The block adapter is in my car ready for tomorrow
John - Give me a call when you leave work, thanks.
Old October 26th, 2011, 08:33 PM   #689
Ford rules
Ford rules's Avatar
The pass. side hangs a lil low but the upper link protects them quite nicely. The driver side is completly above the frame rail. And yes full skid plates are on my list just havent got to it yet.
Old October 27th, 2011, 08:48 AM   #690
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I like the removable crossmeber, Maybe I will look into that since I have the motor out... I am gonna run manifolds.
Brandon, thanks! John, thanks also!
Got my shifter last night, thing looks sweet, can't wait to use it.
Old October 27th, 2011, 08:49 AM   #691
Ford rules
Ford rules's Avatar
Maybe i misssed it but what kind of shifter did you get?
Old October 27th, 2011, 09:31 AM   #692
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
http://broncograveyard.com/bronco/i-...or-bronco.html
Old October 27th, 2011, 09:46 AM   #693
Ford rules
Ford rules's Avatar
Very nice!
Old October 27th, 2011, 10:01 AM   #694
So what's the first to reverse shifter mod for that?
Old October 27th, 2011, 11:20 AM   #695
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Buy different gates. Or mod these ones.
Old October 28th, 2011, 08:43 AM   #696
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I need a bit of help....
I went out and measured all my yokes for drive shafts. I have (2) 205's, ones has 1330 yokes and the other has 1310 yokes front and rear.
I measured my front 60 and that has a 1330 yoke and my 14 bolt has a 1350 yoke.
Ok, with all that done, I know I don't want to run a 1330 joint right? I hear they are junk.
I want to run a 1310 joint in the front for space reasons and I have (3) 1310 shafts, but that means I need a new yoke for the 60 to do that. I found one on JBG for $62, sound alright?
Then on the rear I was thinking of running a 1350 joint which means I need a new yoke for my 205. I also need to find a shaft or 2 I can use to make a new one for me. I found a 205 yoke for $59, resonable?
Can I run a 1310 on the rear also? Would it be strong enough? I have a couple of those shafts already too, but it looks like I can't get a 1310 yoke and would need to mod the 1350 yoke or run a conversion joint. Would that be bad?
What should I do for shafts? 1310 on the front and 1350 in the rear? Or 1310's all around with a conversion joint at the 14bolt?
Thanks
Old October 28th, 2011, 08:51 AM   #697
I did the whole conversion joint thing on my rear driveshaft. It worked at first but became a hassle and joints broke etc.
Running straight 1350 on the rear now and haven't had any issues. I found a driveshaft from 3/4 ton chevy vans and suburbans were an easy junk yard mark for 1350s.
I've been running 1310 on the front with no issues since getting the right style tcase yoke.
I would get the trail repair yoke kit from jbg vs just the yoke on the front. Couple $ more and get quite a bit more.
Old October 28th, 2011, 09:36 AM   #698
I'm running a 1310 to 1330 conversion joint on the front and a 1310 to 1350 conversion joint on the rear. Both 1310 CV's at the T-case. I carry a spare of each conversion joint as CTB2 pointed out that the conversion joints aren't usually in stock in BFE when you need them most. I also bring spare front and rear DS with me. I'm linked in the rear so I don't have nearly as much axle wrap to deal with as a leaf setup. I don't actually wheel, and when I do I rarely use the go pedal so this probably adds nothing to this conversation . I still have CTB2's box of spare driveshaft components I can bring over to him. I have to go get my limit straps from this summer anyway. The trail repair kit seemed like the most bang for the $ when I was debating on changing the D60 yoke.
Old October 28th, 2011, 09:47 AM   #699
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
The trail repair kit is $69 verse the $62 for just the yoke. Ok, gonna run a straight 1310 in the front.
I might just buy a conversion joint for the rear right now, because i don't feel like spending $100 buying new shafts to make a 1350 and the rear 205 yoke. I can spend $25 now on a 1310 to a 1350 joint and just start collecting parts to make a 1350 rear shaft.
Old October 28th, 2011, 09:49 AM   #700
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
...... I don't actually wheel, and when I do I rarely use the go pedal so this probably adds nothing to this conversation ......
LOL, right.....
Page generated in 0.49248 seconds with 84 queries
