Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 29 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 5th, 2011, 05:46 PM   #561
Ford rules
Ford rules's Avatar
Truck looks great!
Where at do you wheel mostly? Id like to take my ranger out there and run with you guys sometime.
Old September 5th, 2011, 06:25 PM   #562
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Thanks!
We wheel mostly at rocks and valleys and some local private property. If I remember, I can give you a heads up next time we go someplace.
Old September 5th, 2011, 06:29 PM   #563
Ford rules
Ford rules's Avatar
^That would be cool id like to start doing more rocks and technical stuff. looks like a blast.
So when are the one tons going in?
Old September 5th, 2011, 06:37 PM   #564
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Prolly in the next month or so. I have some other things to wrap up first. Hope to be back out wheeling by mid November if not sooner.
Old September 5th, 2011, 06:39 PM   #565
Ford rules
Ford rules's Avatar
Nice leaving the suspension how it is and just swapping to tons i take it?
Old September 5th, 2011, 06:49 PM   #566
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Yup, pretty much. I think it works pretty good. Only thing I plan on doing is swapping in some different leafs in the rear so I can shorten the rear a little.
Old September 5th, 2011, 07:10 PM   #567
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Kyle-I'm diggin' the new comp cuts. Looks sweet!!!!
Old September 5th, 2011, 07:14 PM   #568
Shotgun
I only wheel with boats.
Shotgun's Avatar
Gimme a call when you need a hand with the 6D. I can come over point and hold a beer like a champ.
Old September 7th, 2011, 07:31 PM   #569
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Got my wheels today.
Just gotta machine the centers to clear the 6D hubs and figure out what I am gonna do for protection. Some sort of rock ring, maybe thinking of getting some steel ones and screwing them to the rim. Guess we will see.
Old September 7th, 2011, 08:48 PM   #570
Grassman
2jz specialist
Grassman's Avatar
sexie
Old September 7th, 2011, 08:54 PM   #571
BLZR
Those look familiar - going to build/buy some beadlock rings for those puppies or going internal?
BLZR is offline   Reply With Quote
Old September 7th, 2011, 08:56 PM   #572
Tacker
Tacker's Avatar
Get some weld on rock rings so I can check them out .
Old September 7th, 2011, 09:13 PM   #573
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Think I am going with rock rings and inner air locks.
Old September 7th, 2011, 09:15 PM   #574
I was thinking about getting a set of those for the crew cab............thinking about it. Just haven't found a good deal yet.
Old September 7th, 2011, 09:21 PM   #575
Tacker
Tacker's Avatar
Hmmm.......
Old September 8th, 2011, 07:01 AM   #576
Just don't weld them.
diy beadlocks for h2\\\\\\\\\\'s - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 11th, 2011, 12:09 PM   #577
Grassman
2jz specialist
Grassman's Avatar
so you have all the major components in hand then?
cant wait to see sparks flying
Old September 11th, 2011, 02:51 PM   #578
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I have everything I need to get started. Couple of weeks and I will get on it
Old September 20th, 2011, 07:33 PM   #579
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Got my locker today
Got it from IronMan Offroad, Dale was a excellent guy to work with, great deal too
Then I skined the bottom of my 14 bolt to get it ready for gear install. I used 1/4" plate layered, so it is 1/2" thick.
Then made my very own orb-o-traction
Still need to clean it up after it cools, prolly wait till the morning.
Old September 20th, 2011, 07:49 PM   #580
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Cast aluminum wheels and rocks seem like a bad combo. Especially after I found about a 4" flat spot on the inside of my steel H1 wheels after the labor day trip to Rocks. This would most likely render the cast wheel scrap, mine still holds air and if it ever starts to leak I will grab the BFH and "fix" it.
EDIT - Instead of machining the wheels to fit over the hubs, why not machine the hubs to fit inside the wheels, that way you do it once and you're good for life unless you swap hubs.
Page generated in 0.32496 seconds with 85 queries
