Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 147 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 10th, 2014, 07:20 AM   #2921
Looks like my time was worth $221 - the $80 for my cables.
Old April 10th, 2014, 07:27 AM   #2922
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Old April 10th, 2014, 08:41 PM   #2923
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Still undecided on a shifter, gotta get one soon though
Picture of my fan mounted on the shroud
T case installed, new driveshafts made, front got 10" longer, rear got 8" shorter. I use 1" of slip on both shafts with full travel. Also, no bind. Only thing I have to do is modify my exhaust to clear the last 1.5 " of my uptravel.... Or just let it self clearance
I'm happy, progress!
Old April 10th, 2014, 11:27 PM   #2924
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Any better pictures on what you did for the shroud?
Old April 11th, 2014, 09:51 PM   #2925
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
No, not right now. Basically it is a 3/4" deep box that covers the whole thing. On the top there is a lip folded over that hooks on the top lip of the radiator then hangs from it. Then a flange on the bottom that bolts thru the bottom lip of the radiator.
Old April 11th, 2014, 10:13 PM   #2926
crunchedtj99
self clearance for the ultimate fitment lol
crunchedtj99 is offline   Reply With Quote
Old April 12th, 2014, 06:48 AM   #2927
big86inthestixx
big86inthestixx's Avatar
Well..did u get all your welding done last night. Front axle back in?
Chad the shroud is a 4 sided pan, with 1 down break in the Bottom to screw to the radiator, the top is sown broke then hemed so it can hang off the top of the radiator.
sended frum dis stoopid fone
Old April 12th, 2014, 07:02 AM   #2928
chadcooper55
I'm guessing that you bent it up? If so are you interested in doing another one?
Old April 12th, 2014, 07:15 AM   #2929
big86inthestixx
Sure. I need the fin height & width, then the over all radiator height (flanges on top notch bottom)
Old April 12th, 2014, 12:03 PM   #2930
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Yup, front axle is all welded up, I'm putting it together tonight, then painting. I hope to have it back in the ranger tomorrow. Gonna pull the rear axle today also and weld that up and finish up the links.... Getting there. If things go good I might get started on brakes or fuel stuff tomorrow.
Old April 12th, 2014, 12:50 PM   #2931
chadcooper55
I'm going to order my radiator shortly, I'll hit you up when I get the measurements. Thanks!
Old April 12th, 2014, 08:33 PM   #2932
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Front axle done and painted. Just waiting on links to dry So I can put it back together.
Mounted my ram, need to decide on the orbital mount... But I have an idea.
Rear bumps/spring retainers made, shocks mounted, Battery box started, all my frame work is pretty much done. Gonna pull the rear axle in the morning after I do the limit straps, and weld it up and paint it, same with the rear links. Should be on its own weight tomorrow.
No pics yet
Old April 12th, 2014, 09:22 PM   #2933
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
How should I do my rear limit straps, one in the middle or 2 near the coils? And should I put a center strap in the front like I had before? Guessing I won't need it now, just use the winch as a suck down probably enough?
Old April 12th, 2014, 09:22 PM   #2934
Old April 13th, 2014, 07:03 AM   #2935
Limit straps by the shocks, center depends on driveshaft clearance.
Old April 13th, 2014, 07:47 PM   #2936
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Ok, done. Thanks. Now I need longer straps, but these 18" ones should do fine for now.
Radiator, coolers and fan in for good
Front axle in, everything in minus air shocks and ram. Sitting on the bumps
Rear axle in, painted and all done. On bumps
Battery mount
Old April 13th, 2014, 07:50 PM   #2937
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Looks awesome buddy
Sent from my Galaxy S4
Old April 13th, 2014, 07:51 PM   #2938
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Sitting on bumps
Old April 13th, 2014, 07:51 PM   #2939
frdboy
frdboy's Avatar
X2.....looks great!
Old April 13th, 2014, 07:55 PM   #2940
:drool:
Page generated in 0.35424 seconds with 84 queries
