Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 14 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2011, 12:09 PM   #261
rangerluc
rangerluc's Avatar
Originally Posted by Kyle M. View Post
Should I?? That would limit flex right? lol What about the shocks, those should do it, limit straps and bumps all in one
Maybe one day, we will see how it flexes, need to bring it to work and use the highlow to find out.
i would reccommend it lol. it wont limit flex if you get the right ones. youve seen mine up front, they look HUGE, but they compress to about an inch. and you would want to hit your stops before you blow out a shock lol. and its not so much for when your just flexing, its for when you come down hard and your springs cycle up fast and your axle or something else plows into your frame
rangerluc is offline   Reply With Quote
Old March 14th, 2011, 02:42 PM   #262
cushion101990
cushion101990's Avatar
Whats the point of runing the springs inboard?
cushion101990 is offline   Reply With Quote
Old March 14th, 2011, 03:07 PM   #263
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
It gives the axle more leverage on the spring, making it work better and flex more without changing the spring rate.
Old March 15th, 2011, 12:43 AM   #264
cushion101990
kinda what i figured how well does it flex now? better than before?
Old March 15th, 2011, 07:54 PM   #265
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
IDK, haven't flexed it yet!
Got started on my bead locks, 2 welded so far
I overlapped my weld starts and stops, I think they are turning out great so far
one ground smooth
Old March 15th, 2011, 08:12 PM   #266
Fun stuff isn't it
I think I have done like 6 sets. All but my last set I ground flat. The current set I left weld as I had a small even ridge from the weld all the way around. I got lazy, but hey it works .
Are you going to put a anti-coning ring on them?
Old March 15th, 2011, 08:27 PM   #267
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I feel lazy too, but I am gonna grind...sucks balls! Even the welding isn't fun!
Yeah, I am gonna make some rings, just not sure how soon I am gonna do it. For now I think I am going to stack washers about .5" thick and put em on like every 4th bolt to give me something to tighten down too. See a problem with that? Are your rings 2 pieces or did you weld them back together?
Old March 15th, 2011, 08:31 PM   #268
Weld the rings back together? I wouldn't put washers under the bolts. That will disrupt the clamping force on the beads. All I did for a anti-coning was take a strip of either 1/16 or 1/8 thick strip by 1/2 and tack weld it on the inner most circumference of the inside ring.
If you tack weld the strip to the very inside (smallest circumference part) of a 15" rim and then bend the strip all the way around it makes a real nice curve in the strip and fits nicely and smooth.
Old March 15th, 2011, 08:40 PM   #269
SoupCan
SoupCan's Avatar
kyle, what model welder are you using? it a 220 or 110?
SoupCan is offline   Reply With Quote
Old March 15th, 2011, 08:45 PM   #270
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Lol. I was thinking you told me to use square stock not flat stock strips. If that is all you used I will do it instead of washers. Guess I was confused but I got it now!
Old March 15th, 2011, 08:47 PM   #271
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
It is a Hobart Handler 187, 220v
Love it
Old March 15th, 2011, 08:49 PM   #272
Did you have issues with valve stem clearance?
Anti coning ring for Weld on beadlocks - Pirate4x4.Com Bulletin Board
Old March 15th, 2011, 09:01 PM   #273
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Thanks for the links
No, seems like the valve stems will clear just fine. I was debating on moving them or getting angle valve stems but I might just run them as is. You ever have issues?
Old March 15th, 2011, 09:05 PM   #274
On my rims I relocated them. But I had no choice. I welded in the hole and drilled a new one in a better location.
Old March 17th, 2011, 01:43 PM   #275
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Nice beadlocks !
Old March 17th, 2011, 08:40 PM   #276
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Alright, got the rest of the rings welded into the rims, took a few pictures of the process.
Ground the paint off the inside lip of the rim
Positioned the ring inside the rim, rotated it so the valve stem was between the bolts.
Here is the gap that gets filled in with weld
Tacked in place
first set of welds, I do 8 separate welds
finished welding
all of them welded up
Now I just need to get someone who owes me some grinder time to work on these while I set up his gears......
Then I started on my anticoaning rings, they are .125" thick by .5" wide
Then, last of all, I painted my rings booger green. I know I will teased for it, but F it, it's mine and I like it
More to come, like maybe some 38x12.50x15 Swamper TSL SX tires....
Old March 17th, 2011, 08:44 PM   #277
Grassman
2jz specialist
Grassman's Avatar
rings look nice, next time i have my tires off the rims, my rings are changing colors too
you gonna do the bolt heads black?
Old March 17th, 2011, 08:51 PM   #278
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
LOL, I don't think I will get that carried away, I think the bolts are greenish right now, should look just fine haha
Old March 17th, 2011, 08:56 PM   #279
rangerluc
rangerluc's Avatar
jealous! they look good. and ya, that sob that owes you better grind those clean!! that little bastard...
Old March 17th, 2011, 09:01 PM   #280
Pokerob
hug life
Pokerob's Avatar
nice work! keep motivated.
Page generated in 0.34614 seconds with 85 queries
