Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 122 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2013, 09:27 PM   #2421
liv2mx
i like jungle gym's.
liv2mx's Avatar
Coilovers please.
Old November 4th, 2013, 09:37 PM   #2422
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Not in the budget yet, going coil springs in the rear for now.
Old November 4th, 2013, 10:10 PM   #2423
liv2mx
liv2mx's Avatar
I have a bunch of different tj coils. if any will work u can have them.
Old November 5th, 2013, 02:21 AM   #2424
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Woot get some Kyle
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Old November 5th, 2013, 05:06 AM   #2425
Don't move the motor back into the firewall. I did that years ago when I did my first SBC into a CJ5. It sucked working on the back of the engine, getting to bellhousing bolts, changing gas pedal location, heater core & heat ducts, etc. If you want more uptravel in the front and are planning to redo your links, now is the time to stretch it forward.
Old November 5th, 2013, 06:49 AM   #2426
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I agree with the axle forward... it has worked out well on mine
Old November 5th, 2013, 08:13 AM   #2427
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Thanks guys, I'll consider that. I just like the stance of the truck now and the wheel base, so if I push the front axle forward the 6"- 8" I'd need to to fit the 4 link, the rear axle will have to move too and I'm not too keen on that look, the tires will be into the extended cab or close to it. We will see, maybe I'll just 3 link it and keep it where it all is.
Erin, I'd like to borrow them at the very least to see what I need. I haven't searched anything yet.
Old November 5th, 2013, 08:23 AM   #2428
trailrail302
Im going FAST!!!
trailrail302's Avatar
I think your rig works really well as it is, but im sure thats mostly driver...
trailrail302 is offline   Reply With Quote
Old November 5th, 2013, 08:46 AM   #2429
When you get to that point set it on a set of springs with a known spring rate and use this:
Moog Spring Excel Sheet for Coil Spring Selection - Great Lakes 4x4. The largest offroad forum in the Midwest
Or just call me like everyone else does
Old November 5th, 2013, 09:15 AM   #2430
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Could you split the difference? Push the engine back as far as what is practical without getting into the firewall then move the axle forward some as well?
What is your wheel base now?
Old November 5th, 2013, 09:23 AM   #2431
Old November 5th, 2013, 10:38 AM   #2432
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
My engine is about 2" at most from the firewall now, and in reality, without modifying it, I probably can't even move it back at all. Currently my axle sits directly under the 2nd Cylinders ish and to fit anything one or the other will need to move.
A little back story on why I want to do new front suspension last summer I bent my front axle when I bent my knuckle at the Sand lake comp. The best way to repair and keep it fixed is to truss it. With the radius arms, I don't have room to do a proper truss. That is the reason for the 3 or 4 link. I will also be able to gain more up travel during the process. Just gotta decide how I wanna go about it.
And yes my will base is somewhere around 118" and I don't want to go any longer.
Old November 5th, 2013, 10:58 AM   #2433
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I shot for 116-118 and ended up at 121...i was less than excited but it works great.
I know what your saying about things being tight.....my truss and oil pan almost touch at full compression....i am not looking forward to trying to cram a bigger motor in there lol
Old November 28th, 2013, 07:14 PM   #2434
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
What are you running for rear leafs? How do they hold up?
Old November 28th, 2013, 10:57 PM   #2435
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I am running stock 4 door explorer springs now, they are bent and didn't hold up more than
a couple runs. My previous set were Chevy 1/2 ton springs, 63" leafs, they held up very well and if I were keeping leafs I would run them still.
Old December 2nd, 2013, 10:04 PM   #2436
Grassman
2jz specialist
Grassman's Avatar
Chop Cut Buzz
Old December 3rd, 2013, 06:13 AM   #2437
KKKKKKKKKKKChhhhhhhhh meow over!
Old December 3rd, 2013, 06:17 AM   #2438
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Aluminum!
Old December 3rd, 2013, 08:05 AM   #2439
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
I miss all the fun... When are you guys coming back?
Kkkkkkkkcccchhchchhchchc.:.... Meow, over...
Cheap Thrills Off Road
Old December 3rd, 2013, 08:19 PM   #2440
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Rubber
Perfect!
Page generated in 0.35589 seconds with 85 queries
