Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 121 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2013, 08:23 PM   #2401
liv2mx
i like jungle gym's.
liv2mx's Avatar
crack the lines on the orbital one at a time while on jackstands.turn it a little each way then tighten.
Old October 21st, 2013, 08:25 PM   #2402
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
While it's running? And just the lines that go-to the ram?
Old October 21st, 2013, 08:26 PM   #2403
liv2mx
liv2mx's Avatar
no not running.just push tires or turn wheel a little.
Old October 21st, 2013, 08:53 PM   #2404
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I'll try that, thanks!
Old October 21st, 2013, 09:08 PM   #2405
bluminade
Bluminade Has Arrived
bluminade's Avatar
may need to drive it some to get the rest of the air out, or maybe a smaller power steering pump pulley to spin the pump faster
bluminade is offline   Reply With Quote
Old October 21st, 2013, 09:27 PM   #2406
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Wouldn't it need to be a bigger pulley since it is a driven pulley? The belt speed stays the same, a larger pulley will spin faster won't it?
Old October 22nd, 2013, 07:28 PM   #2407
bluminade
bluminade's Avatar
the pulley on mine is smaller than the stock one and it turns better at an idle than it did with the stock pulley. mine would steer a little hard at idle until i touched the gas to bring it just off idle and then it would work good. mine also is 4.25 turns lock to lock so it is a little slower than yours.
Old October 22nd, 2013, 07:34 PM   #2408
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Originally Posted by Kyle M. View Post
No, not yet. I turned it block to lock about 20 times tonight on jackstands, put it down, steered good for one cycle then got hard, so maybe more air.
Sounds like air....mine was a bitch to bleed, i ended up just taking mine for a shake down run and it eventually bled its self out over the course of the day
Old October 22nd, 2013, 07:39 PM   #2409
Strangler
Strangler's Avatar
Nope. Smaller = faster.
Old October 22nd, 2013, 07:40 PM   #2410
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Good thing shake down will be with lil tires
Old October 22nd, 2013, 07:42 PM   #2411
bluminade
bluminade's Avatar
i would run it for while and make sure all the air is out before changing anything.
Old October 22nd, 2013, 07:47 PM   #2412
firehawk
Live Action!
firehawk's Avatar
Don't tell him that, tell him it needs a bigger one. He will lose for sure hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahaha
Old October 27th, 2013, 04:49 PM   #2413
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Ok, cracked the lines and got some air out of the ram, locked to lock not running like 20 times, lock to lock running 30 times, all seems to be good. Still might go with a smaller pulley (Ok, Ok, you guys are right) gonna run it next weekend and see how it works.
Still feels weird being able to steer so easy
Old October 27th, 2013, 04:51 PM   #2414
Old October 27th, 2013, 05:22 PM   #2415
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Still might go with a smaller pulley (Ok, Ok, you guys are right).
I spent a lot of time on that text
Old October 27th, 2013, 06:02 PM   #2416
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Thank you... Lol
Old November 4th, 2013, 09:26 PM   #2417
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Ok, hydro worked great last weekend, truck took a beating and still drove on the trailer. Only issue I had is the hydro line fitting came in contact with the oil pan a couple times and tweaked it and made it leak pretty bad but I was able to tighten it and keep going.
So Ok, in the next month or so I'm 4 linking the rear, need to decide on springs. Also gonna truss the front axle and do a 3 or 4 link. The front frame is in need of repair so I think I will cut it off and rebuild it for more clearance and strength. Thinkingof moving my motor up and back for mmore axle room, but the will involve floor and firewall removal and modification, still on the fence about that. The rear will get cut off in front of the axle and some tube work will replace the factory frame.
I'm also picking up a parts ranger this weekend for the body parts, so ill have parts for sale if anyone needs anything. 4.0, auto, 4x4, regular cab.
Old November 4th, 2013, 09:36 PM   #2418
firehawk
Live Action!
firehawk's Avatar
Just build a tube buggy, seems that is what everyone wants. But I do like the Booger flinger
Old November 4th, 2013, 09:38 PM   #2419
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I am gonna keep the ranger, but it might be a new frame with with a ranger shell. Lol
Old November 4th, 2013, 09:44 PM   #2420
firehawk
Live Action!
firehawk's Avatar
That could be cool.
I do like Johns buggy too.
I might have one some day if I can trade up to one.
Page generated in 0.36727 seconds with 84 queries
