Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 119 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 10th, 2013, 09:04 PM   #2361
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Steel
Old October 10th, 2013, 09:10 PM   #2362
ReiKo
Community Smart Ass.....
ReiKo's Avatar
Originally Posted by Kyle M. View Post
Steel
Think I might have a few from my race car... I'll go through my stash tom at work...
ReiKo is offline   Reply With Quote
Old October 10th, 2013, 09:21 PM   #2363
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Awesome! Thanks!
Old October 10th, 2013, 09:29 PM   #2364
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Ill be on the east side tomorrow if you need transport
Old October 10th, 2013, 09:30 PM   #2365
Trail Junkie
iamfawkinwithyou
Old October 10th, 2013, 09:43 PM   #2366
GREASYHANDS
GREASYHANDS's Avatar
Did some say meow?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 10th, 2013, 09:45 PM   #2367
firehawk
Live Action!
firehawk's Avatar
Originally Posted by Trail Junkie View Post
Old October 10th, 2013, 09:47 PM   #2368
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Unless you plan on cutting out some of of the core support, the tanks and part of the core of the 31" rad will be covered up. On both V8 rangers I built I used the next size narrower summit rad, the tanks were slightly covered but none of the core was. If air can't pass over most of the radiator, a larger size could actually be worse.
Its a little pricey, but this fan is a beast. http://www.summitracing.com/parts/der-16217/overview/ Use a Derale 2 spd controller along with it and you'll be set. Otherwise you only need two switched power sources to activate both speeds. The first activated switch ALWAYS turns on Low speed and high is activated whenever a second switch is turned on. On my friends car we used a screw in temp switch preset for 180*-ON and a derale single fan adjustable control. The adjustable control gives you the ability to use the preset switch as the high or low temp switch depending on how you set it up. The controller also has an override feed to manually turn the fan on.
Preset temp switch - http://www.summitracing.com/parts/der-16730/overview/
Single Fan Controller - http://www.summitracing.com/parts/der-16759/overview/ (it says single/dual fan, but the max amperage limits its use to singe with most fans)
Dual Fan Controller - http://www.summitracing.com/parts/der-16789/overview/
Both controllers are available with push in or thread in options (different part numbers). I currently run 2 of the 16759's on my rig (dual 25A fans), but now that they have the 16789 available I will be switching to that.
Not the best photo, but you can see the issue I am referring to. I would have to check my receipts to be sure, but I believe I used this radiator http://www.summitracing.com/parts/sum-380425/overview/
Old October 10th, 2013, 09:51 PM   #2369
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I will be doing something like that, but my battery is behind my fuel cell so it has to but up higher. The fan in the picture is opposite of what you are describing right?
We have a puller fan on it, so it brings air from under the rig and blows it away from the cell.
Reiko - The paint drawing is not to scale. lol
Yeah, either him or hose jockey.
After having serious discussion about it tonight, I may try to mount it in the front still. Winter project.
It was AlumCJ having issues, but part of it was that he had using a street rod fan that did not like dust/dirt/mud, as well as not liking the angle. He talked to a guy that either worked for spal, or knew a lot about them and he gave him some info on the right fan. When he changed the fan, he also change the mount, so he never ran the good fan at the original angle.
Old October 10th, 2013, 10:22 PM   #2370
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I believe summit now has triple pass radiators in the universal Ford style.
I'm removing my core support and building one out of tube. Then I will build a fan Shroud to fit it so I am pulling air across the whole thing. The core is 27x19. Not huge but lots better than I have now.
Old October 10th, 2013, 10:23 PM   #2371
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Sweet, I'll let you know!
Old October 10th, 2013, 10:36 PM   #2372
bigblockford79
Big Block Ranger
It will for sure do the job, I have the exact same rad in my truggy and haven't had any cooling issues yet. The fans/shroud will make/break the setup though. These are the fans I went with - http://www.summitracing.com/parts/der-16837/overview/
They fit the radiator perfectly.
Old October 11th, 2013, 11:23 AM   #2373
ReiKo
ReiKo's Avatar
Don't have steel... Tons of alum...
Old October 11th, 2013, 12:30 PM   #2374
catman
done haulin
catman's Avatar
Working on your list when I get back to the shop... You should see a quote by 3pm.
When its all said and done I really don't care what people think about me...
catman is offline   Reply With Quote
Old October 12th, 2013, 08:07 PM   #2375
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I picked up a contour fan today, seems pretty nice, pita to remove from the car! Looks like it will fit my new radiator great, just have to figure out a simple way to mount it.
Started my hydro swap today, yanked out all the old, made a new tie rod, mounted the orbital, and figured out my ram mounts, just gotta make em at work next week.
My orbital is kinda close to my exhaust manifold, probably gonna put a heat shield between them. This set up will only be temporary. My frame is kinda messed up so I'm gonna rebuild it when I put the new radiator in.
Now I just need to figure out a reservoir for my Saginaw pump, lines, and which ports are which so I can start plumbing.
Gonna be ready for mustache run.
Old October 12th, 2013, 08:08 PM   #2376
Four alum tapped round pucks welded to the tanks.
Old October 12th, 2013, 08:12 PM   #2377
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Radiator mount?
Old October 12th, 2013, 08:13 PM   #2378
Fan to radiator. Rad should be trapped
Old October 12th, 2013, 09:18 PM   #2379
Kinda like we did mine kyle.
Old October 12th, 2013, 09:25 PM   #2380
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
What should I use as bait?
Ok, seems easy enough. I think I'm gonna have to move the lower hose hookup anyway so good time to weld the whole thing up.
Page generated in 0.38591 seconds with 84 queries
