Kyle M. Ranger Truggy, rebuilt again - Revision 4 - Page 112 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2013, 11:23 PM   #2221
Shotgun
I only wheel with boats.
Shotgun's Avatar
Originally Posted by Shotgun View Post
This may work.
I lied, schedule coordinator had a trip planned to Michigan Adventures before the kids go back to school.
Old August 18th, 2013, 08:20 PM   #2222
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
So can I take your ex to jeep night? I promise I'll be nice....
Side not, just build related stuff...
I pulled the axle apart, and it's a mess. A combination of things went wrong. My locker quit working about a month ago, so we 'fixed' it by welding angle iron to the carrier and having part of the angle stuck in between the locker keeping it apart and from ratcheting. Worked good for the most part. Then this last weekend my pinion bearings went bad, allowing my pinion to move around and rub on the angle iron, which made it break off and run thru the gears. Good part, the bearings were bad so there was room for it to pass and not damage the gears.
So to fix it I will replace the bearings, and install the spiders and weld them until I get a grizzly.
Damage pics
Old August 18th, 2013, 08:29 PM   #2223
I think the angle came off and tried to pass through the pinion and ring gear causing the bearing to fail...thats my thoughts anyways .
Get this pig back together for the club comp......
Maybe we can get a group buy on the grizzlies . Nothing wrong with my spartan but I wanna change it out to.
Old August 18th, 2013, 08:33 PM   #2224
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Only reason I think different is because I noticed the pinion was loose and making noise on our way to the bump and hustle.
Could be that way too, who knows. I'll have it all fixed up this week. Gotta change leaf springs too, mine are all messed up.
Old August 25th, 2013, 08:31 PM   #2225
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
All fixed and ready to go, for now. Front is welded spiders now and new pinion bearings and seals.
Also, I put on shorter rear leafs to replace my destroyed leafs... No more shackle hanging way out
Old
New
Old August 25th, 2013, 08:42 PM   #2226
1 ton tj on 40's
1 ton tj on 40's's Avatar
looks better.
Old August 25th, 2013, 10:37 PM   #2227
Mr. Beefy
BFT!
Mr. Beefy's Avatar
New shock mounts? Haha
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
Old August 25th, 2013, 10:59 PM   #2228
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Welded the old one back on... Might brace it more eventually haha
Old September 1st, 2013, 10:44 AM   #2229
holshotracer
Its not mine
holshotracer's Avatar
https://www.youtube.com/watch?v=5wX9...VArkzRQz2eoE7A
holshotracer is offline   Reply With Quote
Old September 1st, 2013, 05:19 PM   #2230
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Strangler... That ones for you!
Only damage I got was a bent antenna, broke out my back Window and busted marker light.
Old September 2nd, 2013, 12:25 PM   #2231
crunchedtj99
Cage works!!! lol
crunchedtj99 is offline   Reply With Quote
Old September 2nd, 2013, 12:44 PM   #2232
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Yes it did! Better than I expected for such a hard landing.
Old September 3rd, 2013, 07:59 AM   #2233
302sploder
302sploder's Avatar
we must have barely missed that. looked like you were about to get winched over when we went past.
looks like it was a rough ride..lol
302sploder is offline   Reply With Quote
Old September 3rd, 2013, 07:26 PM   #2234
Mr.Green
I can levitate!
Mr.Green's Avatar
Looks like your shackles could flip reverse now.
Old September 19th, 2013, 08:34 PM   #2235
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
No problems yet with the shackles
Got a new 13.5" led light bar
Then I modded my door hinges so I don't need to pull pins any more. I cut the top of the hinge off the cab, then welded a bolt into the door so it just drops in like a jeep door.
I did that because I got a set of tube doors I'm gonna put on and need a quick way of swapping them... Works pretty well!
Old September 19th, 2013, 10:21 PM   #2236
Shotgun
Shotgun's Avatar
Looks like a great idea for the ex.
Old September 19th, 2013, 10:52 PM   #2237
big86inthestixx
big86inthestixx's Avatar
Howd the doors feel with half the hinge gone?
Like the light n doors!
Did u cut ur grill up to see if u like it with tue grill?
sended frum dis stoopid fone
Old September 20th, 2013, 05:34 AM   #2238
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Doors feel good, same or better then they were. I cut the shit out of the grill, lol. Basically just left the surround.
Thanks for the idea andy
Old September 20th, 2013, 09:27 AM   #2239
Strangler
Strangler's Avatar
How did I miss this???
We're gonna have to figure that one out at this years MR.
Old September 20th, 2013, 09:28 AM   #2240
Move 15 degrees to the left when attempting it
Page generated in 0.32306 seconds with 84 queries
