2001 Xj 4.0 **SOLD** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 23rd, 2006, 01:44 PM   #1
PavementPounder
PavementPounder's Avatar
Default 2001 Xj 4.0 **SOLD**
Bracketry, but no accessories. Injectors, TB, manifolds, and fuel system intact, I have the ignition rail on the shelf. Has been robbed of its water pump (Shift) and TPS (Skooter). Was pulled at Dealership after numerous complaints of slight "ticking" sound by annoying owner. Some kind of small triangular pad-like parts in the valvetrain are suspected to be the culprits. Apparently happens a lot and some people just live with it? Bought it because it only needed little bullshit repairs. Was to be the platform for my stroker. The coil rail is sitting on the shelf in the 3rd pic.
$300.
PavementPounder is offline
Old August 23rd, 2006, 08:33 PM   #2
Icemanii
GLFWDA Land Use Committee
Icemanii's Avatar
MudnYJ's girlfriend might need this engine. Can let you know on Thursday.
Icemanii is offline
Old August 24th, 2006, 07:22 AM   #3
2001v10
Mileage?
Will it bolt into my friend's 89 Cherokee?
What type of repairs does it need and how long has it been sitting?
We're looking at pricing to rebuild his 4.0L and your route would be cheaper!
2001v10 is offline
Old August 24th, 2006, 07:51 AM   #4
PavementPounder
I know nothing about your friend's 89 XJ, so I can't answer that question.
I don't know the miles.
I don't know how long it has been sitting. I've had it for a few months. Already listed what it needs to the best of my knowledge in the first post.
Old August 24th, 2006, 10:51 AM   #5
dfreeman616@gmail
dfreeman616@gmail's Avatar
Send a message via AIM to dfreeman616@gmail
2000v10:
The 89 4.0 is differant than the 2000 in some important features. They use differant intake and exhaust manifolds, have differant accessories, and use an entirelly differant computer/electrical system. You could put this engine in an 89, but it would probably be much more work (and cost) than just rebuilding the one you have. If you find a differant engine, you'll need an 87-90 4.0 for direct bolt-in application.
dfreeman616@gmail is offline
Old August 24th, 2006, 01:59 PM   #6
2001v10
Anyone know if the long block is the same for '89 and '00?
His intake, exhaust, electrical, etc is all good. He just needs a good bottom end.
2001v10 is offline
Old August 24th, 2006, 03:19 PM   #7
94lt1
If you put his head on the new bottom end everything will work. The heads can go on either block. I did it the other way around with my old MJ I put my HO head on a non-HO block.
94lt1 is offline
Old August 25th, 2006, 11:48 PM   #8
SS
Bananarama!
SS's Avatar
How much do you want for just the TB with MAP and IAC?
-Jer
SS is offline
Old August 26th, 2006, 10:11 AM   #9
PavementPounder
I don't want to part it out. That will just make it harder to sell.
Old August 27th, 2006, 01:34 AM   #10
dfreeman616@gmail
i should have thought of that, putting the 89 head on the 01 block should be fine.
Old October 23rd, 2006, 09:40 AM   #11
PavementPounder
Bump.
Old October 24th, 2006, 10:32 PM   #12
PavementPounder
Sold.
Page generated in 0.29245 seconds with 59 queries
