classes and dates for dads and jasons mudruns - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old November 15th, 2010, 12:50 PM   #1
dirty addiction
dirty addiction's Avatar
Default classes and dates for dads and jasons mudruns
classes as followed will be
35 street
38.5 pro street
38.5 mod
44 mod
open
dates for dadsmudrun
june 16 2011
sept 17 2011
dates for racing jasons
may 26
june 23
sept 22
Street 35 rules-
-Must be able to pull vacuum
-All lights,wipers interior and body parts must be able to drive down road
-Full exhaust ,lift kit, headers ok, solid hook point motor and suspension in stock location.no cut tires
-Motor in stock location
-No traction devices other than stock the specific vehicle
38.5 DOWN PRO STREET-
-no cut tires dot only
-no four link suspension unless factory
-motor and suspension in stock location for frame
-must have full oem frame
-radiator in stock location
-motor mods ok
-fuel cells ok
-body changes ok but motor and suspension must stay in stock location
traction bars ok as long as they are not adjustable
-open header and up-rights ok
-lights and wipers must be on rig
-minor stripping and gutting aloud.
-must have solid hook point in rear.
-No power adders
-No alcohol
-No aluminum blocks
38.5 MOD 44 MOD
-ANY SUSPENSION
-ANY BODY
-ANY MOTOR AND SUSPENSION LOCATION OK
-RADIATOR FUEL CELL AND BATTERY OK BEHIND CAB
-NO POWER ADDERS
-NO NOS
-CUT DOT TIRES ALOUD
-No alcohol
-50% of OE frame.. No full tube chassis
No paddle or tractor tires
OPEN CLASS
ANYTHING GOES
48'' TALL TRACTOR TIRE CLASS?
MORE INFO TO COME
dirty addiction is offline   Reply With Quote
Old November 15th, 2010, 01:13 PM   #2
FORD FLARESIDE
6'-1" 185lb 14YO Griffin
FORD FLARESIDE's Avatar
Are fuel cells okay in the 35 Street?
Old November 15th, 2010, 01:18 PM   #3
IDIeselman
IDIeselman's Avatar
Very good. Will flatbeds be allowed in pro street?
Old November 15th, 2010, 01:24 PM   #4
FORD FLARESIDE
Not if its red and you are behind the drivers seat.
Old November 15th, 2010, 03:06 PM   #5
IDIeselman
IDIeselman's Avatar
Then..... NO fuel cells in street
Old November 15th, 2010, 09:17 PM   #6
dirty addiction
We will let fuel cells in street but it will need to have a sending unit and flat beds will be aloud in pro street as long as it looks like it will function on. The street finished look with light
Old November 16th, 2010, 06:45 AM   #7
FORD FLARESIDE
Awesome , I should be good to go.
Old November 16th, 2010, 01:59 PM   #8
MANSEIL P
MANSEIL P's Avatar
35 street
38.5 pro street
38.5 mod
44 mod
open
june 16 2011
sept 17 2011
may 26
june 23
sept 22
Street 35 rules-
-motor mods ok
-fuel cells ok
-No power adders
-No alcohol
-No aluminum blocks
38.5 MOD 44 MOD
-ANY SUSPENSION
-ANY BODY
-NO POWER ADDERS
-NO NOS
-No alcohol
OPEN CLASS
ANYTHING GOES
MORE INFO TO COME
so i can run my 4cyl diesel with the bottle turned off in the 44 mod class and turn the bottle back on for the open class?
MANSEIL P is offline   Reply With Quote
Old November 16th, 2010, 04:05 PM   #9
dirty addiction
sorry no power adders in mod pro chargers ,turbos super chargers, ect.
Old November 16th, 2010, 04:27 PM   #10
redneckenginreeri
let's play
redneckenginreeri's Avatar
so mod 38.5 class one big class or are you going to spilt tires????
redneckenginreeri is offline   Reply With Quote
Old November 17th, 2010, 02:22 PM   #11
dirty addiction
the plain with doing the classes this way will give everyone a equal chance in a class before having to jump up to a bigger class if the 35 street guys jump to 38.5 pro street and the pro street guys jump to 38.5 mod and mod guys only have two classes before open this should alow for larger classes in all areas not just one class. also we are plaining on 4 trophies per class this next season .
Old November 18th, 2010, 11:41 AM   #12
dmcjeep
dmcjeep's Avatar
Looks good to me. Thanks for getting the rules out early so we can plan for the next season.
dmcjeep is offline   Reply With Quote
Old November 21st, 2010, 12:57 PM   #13
bigmud44
bigmud44's Avatar
WOW you just out lawed alot of trucks !!!!!!!!!! what does that do to jeeps with gm ford engines ? matt h s toyota chevy engine ?
bigmud44 is offline   Reply With Quote
Old November 21st, 2010, 01:18 PM   #14
Mudstang
Mudstang's Avatar
Boy, all these changes put me from on a low budget 35 class to now running in the class with guys using 38 tires, that is if I want to put my front axel in it's stock position rather than even with the harmonic balancer. Meaning, I'll either have to up grade tires, motor and sespension or plow throw 38 rutts which is again at a disadvatage. I thought this attempt to change the rules was meant to be fair and be more competitive in classes. I have another issue. What about jeeps or other vehicle using different brand engines? How can anyone claim their enginge are in the stock position? They can't because no matter what drive train combination used does not and is not in STOCK position as it came from the manufacture
Mudstang is offline   Reply With Quote
Old November 21st, 2010, 01:18 PM   #15
dirty addiction
what do you mean?????? we made it so a rig like yours can run in are mod classes now and not be stuck in open because of motor location . jeeps and toys will be able to fit in pro street if they fall into the rules for that class they can run a different motor.
Old November 21st, 2010, 01:21 PM   #16
bigmud44
bigmud44's Avatar
is there 2 35 classes ?
Old November 21st, 2010, 01:26 PM   #17
Mudstang
Mudstang's Avatar
My Motor location is stock ford bronco location. My front axel is moved in line with balancer. But I still have to run 35s in 38 ruts and trust me it matters if its sticky mud
Old November 21st, 2010, 01:36 PM   #18
dirty addiction
if you put a 35 and a 38.5 side by side theres only a few '' difference if that . for pro street class engine and axle have to be in stock location of the frame beening used and by making the classes this way brakes the rigs up into three classes of rules but everyone has two classes they can run before open and that should make every class a good size instead of having two big classes and the rest only a few trucks . it will allow for better pay out all around and tophies to fourth place . an i under stand some guys feeling that it's at a unfair advantage running 35's to a 38'5 tire but if we start doing this an you see actually how many trucks run 35's than 38's you'll see that it's not going to be that big of a problem and look at a 38.5 to a 39.5 thats a bigger jump between the two and we ran them together last year?? if it don't work this way we can always make a extra class. but i think once everyone see how it goes everyone will like it.
Old November 21st, 2010, 01:37 PM   #19
Mudstang
Mudstang's Avatar
What about Lane's wife using a stock LS1 corvette aluminum motor in her jeep running in the prior 35 class. Now what do Lane and his wife do change engines or make highly modifications to run in the unlimited? Sounds like it's gonna be costly for everyone.
Old November 21st, 2010, 01:42 PM   #20
Mudstang
Mudstang's Avatar
So after seeing my mudstang last year and now that I move the axel ahead where do you say I fit in? What changes need to be made? Also I have no headlights nor wipers? Does that mean I should inslall them to compete or move up in class?
Page generated in 0.38912 seconds with 84 queries
