Project Tiny TJ *37 krawlers-5.13's-Dana 60-14 bolt* *5.3 th400 np205* - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 21st, 2013, 11:28 PM   #121
dreezy
Haggard Fab
dreezy's Avatar
So what are you going to do about your fenders?
dreezy is online now   Reply With Quote
Old June 22nd, 2013, 06:52 AM   #122
littletrucker
I'd hit that
littletrucker's Avatar
Front or back?
Old June 22nd, 2013, 07:25 AM   #123
dreezy
Haggard Fab
dreezy's Avatar
Originally Posted by littletrucker View Post
Front or back?
Yes
Old June 22nd, 2013, 08:01 AM   #124
littletrucker
I'd hit that
I like how the front look, maybe some corner guards for the rear.. Not sure low on the list of things to do.
Old June 27th, 2013, 07:53 PM   #125
hardwateraddict
hardwateraddict's Avatar
Why is this not being beat on yet? I want to hear this thing at 8 grand!
hardwateraddict is offline   Reply With Quote
Old June 30th, 2013, 05:27 PM   #126
2fst4you
2fst4you's Avatar
Looks good. Did you stretch the wb at all?
Old July 2nd, 2013, 10:24 PM   #127
littletrucker
I'd hit that
Its 96 97 ISH
Old August 25th, 2013, 11:44 AM   #128
littletrucker
I'd hit that
Been working on this really slowly but making good progress. Runs and drives good, working on getting something to pull it around to take it places.
Twin stick T case shifters
Bent the steering. Was thinking about an alum link to redo this.
Picked up a Air compressor with a blown pump. Got a new pump for it (Not an Ingersoll- im cheap) I have $150 bucks into it with a new pump.
Old December 14th, 2013, 10:39 PM   #129
littletrucker
I'd hit that
Ive been running this around quite a bit lately.. .
At the shop before heading out. I got a new truck too!
earlier in the year at twisted trails
Stuck in the yard...
The 5.3 is running quite well. Im quite happy with the whole drivetrain. Its a whole different animal compared to the 4 cyl...
Old December 15th, 2013, 05:57 AM   #130
Looking good. I'm a little skeptical of the aluminum tie rod.
Old December 15th, 2013, 07:35 AM   #131
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Just out of curiosity, what's the issue with an aluminum tie rod?
Old December 15th, 2013, 08:02 AM   #132
Unless he goes with 7071 (expensive) it's about 1/3 the strength of steel for the same diameter. Dollar for dollar, DOM is cheaper & there is negligible weight saving.
Old December 15th, 2013, 08:06 AM   #133
chadcooper55
Aaahhhh, I figured he was talking about the good stuff.
Old December 15th, 2013, 08:21 AM   #134
GMKLR50
Broke wheeler
GMKLR50's Avatar
7071 holds threads better than steel but nothing anyone is ever going to notice unless your a fastener engineer and look in depth to the material properties... other than not having to worry about rust its about the only thing your going to gain.
GMKLR50 is offline   Reply With Quote
Old December 15th, 2013, 08:54 AM   #135
Just curious why it holds threads better? I had never heard that.
I'm no racer so a few extra pounds doesn't bother me. Plus I like the idea that in a pinch trail repair, you can weld the steel tie rod to the rod ends. Aluminum, not so much.
Old December 15th, 2013, 07:19 PM   #136
bbaXJ
Yooper In Training
bbaXJ's Avatar
Any issues with driveline vibes with the standard u-joint rather than the double cardan that most people run?
Old December 16th, 2013, 08:22 PM   #137
littletrucker
I'd hit that
I thought alum links were all the rage?
*Edit* I was looking at links like this. http://www.rocksolidperformance.com/...luminum-links/
I figured Id be into something I wouldn't have to worry about for less than $150
I ran it down the road a few times and have noticed a slight vibration, but its pretty minimal. The several times I had it out for wheeling I have not noticed it.
Old December 16th, 2013, 08:39 PM   #138
Not my rage. LOL Nothing wrong with them. Didn't mean to say there was.
Old December 18th, 2013, 09:31 PM   #139
littletrucker
I'd hit that
I was only thinking of replacing the knuckle to knuckle tie rod.The drag link and track bar should both be high enough to avoid most damage. Since they both are the same length I could salvage the straight piece of tie rod i would be replacing and makea spare. But for now the bent tie rod will have to suffice..
Old December 22nd, 2013, 01:18 PM   #140
littletrucker
I'd hit that
Playing out in the back 40
Page generated in 0.36997 seconds with 83 queries
