Project Tiny TJ *37 krawlers-5.13's-Dana 60-14 bolt* *5.3 th400 np205* - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 14th, 2012, 05:57 AM   #101
hardwateraddict
hardwateraddict's Avatar
I think you should give us an update on this.
hardwateraddict is offline   Reply With Quote
Old October 15th, 2012, 10:16 PM   #102
boggin-machine
boggin-machine's Avatar
Ya I wondered of this thing has been scrapped yet??
Old October 17th, 2012, 01:57 PM   #103
liv2mx
i like jungle gym's.
liv2mx's Avatar
i see it setting next to his house.the body is off it.
Old October 24th, 2012, 06:29 PM   #104
hardwateraddict
He has been working on it. i am sure he is going to update this soon. Has some cool shit in the works. Ive never seen it done so should be interesting. i give him shit about it all the time, hopefully motivating him to get this rig up and running. Its going to be awesome!
Old November 6th, 2012, 05:41 AM   #105
littletrucker
I'd hit that
littletrucker's Avatar
OK this is far from parted out, Been slowly chiseling away at this. Got sidetracked a few times, but pretty happy with how things are turning out.
Ill give everyone a quick rundown
Bought a WRX- blew the motor up 2.0 (probably my fault) so i built a 2.5L Hybrid
Custom tuned running about 15 psi boost- about to turn 9k miles on completed engine
The wrx is cool, but... couldn't resist picking this up since I payed off the wrx
And yes the body has been off mainly so I could do this, it came off easy enough why fight with it.... 5.3, Th400, Ford np205
Put the body back on sunday
Ive been cycling the suspension, extremely happy with that, the body engine/trans/tcase all fit together perfect. The drive shaft angles/lengths all look great. Making the front drive shaft ATM, Ill post some picture of that process.
Old November 6th, 2012, 06:01 AM   #106
boggin-machine
Woot!
Old November 6th, 2012, 09:18 AM   #107
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Very nice!
*2007 Rubicon
*2006 Duramax
Old November 6th, 2012, 01:37 PM   #108
liv2mx
liv2mx's Avatar
about time! looks good.
Old November 6th, 2012, 08:15 PM   #109
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Something bizarre about that pic....it looks photoshopped....if not nice work....maybe it's my eyes.
Old November 7th, 2012, 03:44 PM   #110
littletrucker
I'd hit that
They are just cellphone pictures. Nothing is photoshopped.
Making the front D shaft it needed to be 2 inches shorter
Carefully seperated the splines from the shaft
Cut it off and pressed it back in. Made a jig to hold it in the press- ran a dial indicator off the end to get it square
Welded it back up.. should be good
Old November 9th, 2012, 07:22 PM   #111
littletrucker
I'd hit that
Ran all new coated brake lines today.
Old November 15th, 2012, 07:33 PM   #112
littletrucker
I'd hit that
Got some small stuff ordered. Got a radiator installed. Measured for lines and hose. I'm trying to get something done on this every night. I'll add a new picture in a few
Old November 15th, 2012, 07:52 PM   #113
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Hope you plan on building a new skid plate before any wheeling. Because it doesn't take very much to bend up the center of the factory skid, right into your tranny pan.
Old November 16th, 2012, 10:49 PM   #114
littletrucker
I'd hit that
I have a piece to replace the factory skid plate. Trying to decide how to attach it, the Trans/tcase is no longer attached to the skidplate.
Old June 4th, 2013, 06:56 PM   #115
littletrucker
I'd hit that
Well its been a a while but finally this thing is running and driving...
Still have alot of little things to go yet- making the dash (thats just a rough in...)
Need to make the t case shifters, got everything for those. Just need to make them up. going to add 1 inch spacers to the rear coils, going to adjust the front up and adjust the bumpstops up 1/2 to 1 inch. also need to get my coil overs charged. I may get a small nitrogen bottle and make my own setup.
I am very happy with how the engine runs, feels real strong, WAY better than the 2.5L The trans and t case both seem to be working well.
Old June 4th, 2013, 07:03 PM   #116
littletrucker
I'd hit that
My front axle had 5.13s in it when I got it, I ended up setting up the gears in my 14 bolt myself only took 1 picture of that process. The coast and drive side looked good to me, backlash was good. It went pretty easy. Ended up just welding the rear diff. The front has posi with clutches and they seem to be grabbing very well (So Far)
Heated the ring gear up in the oven ><
Mocking up the limiting straps
Old June 4th, 2013, 07:11 PM   #117
littletrucker
I'd hit that
To do list
Finish dash- hook up gauges
Build twin stick for np205
I have the skid plate cut out, need to find way to attach it so that it is removable.
Install new shifter cable brackets.
Adjust suspension- charge shocks.
Hook up CB
Install winch
Old June 4th, 2013, 07:49 PM   #118
Nice progress.
Old June 4th, 2013, 10:28 PM   #119
liv2mx
liv2mx's Avatar
nice work! glad its all coming together.
Old June 21st, 2013, 09:36 PM   #120
littletrucker
I'd hit that
Got a good deal on a set of 4 rims 17x9 Non bead lock, but I may get some inner airlocks and put them in. I like the backspacing on the rims a lot better, the tires no longer rub on the control arms at full lock. I probably have an hour of run time on it tooling around my house trying to get the suspension dialed in, still working on a few small things. Time to get some insurance on it and run it down and get some ice cream....
It sits about 77 inches to the top of the window frame.
Page generated in 0.37884 seconds with 83 queries
