Project Tiny TJ *37 krawlers-5.13's-Dana 60-14 bolt* *5.3 th400 np205* - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 30th, 2011, 09:26 PM   #81
littletrucker
I'd hit that
littletrucker's Avatar
I'm pretty sure they are just the "blues"
And got these in the mail today.. Managed to get the right side fabbed onto the frame and a pad on the axle for it to hit.. Looks like im basically gonna be able to clear the 37's with no additional lift. sitting at the same height I was before looks like 7ish inches of up travel, about 9 inchs of droop (16 inch travel coilover)
My old 285/70r17's standing next to the 37's... Mounted and balanced the Krawlers today (not yet cut) and dang... They balanced up better than the 33 tsl's I was running before. If anyone is interested, tire 1 took 8oz of weight tire 2 took 5oz, the 3rd was 2.5oz... and the 4th didn't require any weight! And they all looked like they rolled smooth as glass. (that 285 had about 6 oz on it )
Old December 2nd, 2011, 10:14 PM   #82
2fst4you
2fst4you's Avatar
Never seen uncut krawlers but if you cut them anything like the normal ones I bet they will work fine! Sounds like a good way to save some coin
Old December 24th, 2011, 06:39 PM   #83
littletrucker
I'd hit that
I think the uncut version is just as much to buy new as the regular ones, but I did get a pretty good deal on the ones I got.
Almost got the shocks in, cycled the suspension.. Everything looks good but ran out of welding wire... Wheel base is 95 inches ask if you want to know any more info. Ill try to get a few more measurements posted up in a few days
Old December 25th, 2011, 09:05 AM   #84
littletrucker
I'd hit that
Got this for Christmas 15,000 KG snatch strap
Old December 25th, 2011, 08:21 PM   #85
hardwateraddict
hardwateraddict's Avatar
Looking good! I was expecting to see that thing at work tomorrow, but you probably couldn't find any welding wire on Xmas day.
hardwateraddict is offline   Reply With Quote
Old December 26th, 2011, 07:56 AM   #86
knixon804
THE GENERAL
knixon804's Avatar
Looks sweet
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JK 3" BDS LIFT, 33" DURATRACS, STEELIES, WARN
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old December 28th, 2011, 10:47 PM   #87
littletrucker
I'd hit that
Making good progress.. Having trouble getting the engine to run right now.
The steering and track bar are exactly the same length (they could be swapped back and forth)
Old December 29th, 2011, 12:30 AM   #88
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Good job on having the steering angle match the track bar I know that's easier said than done.
Are you planing on running the tires uncut, or just for mock up?
Old December 29th, 2011, 12:37 AM   #89
wally431
wally431's Avatar
Coming along very nice, I really need to get moving on my and seeing this makes me want to go out there now and start working on it.
wally431 is offline   Reply With Quote
Old December 29th, 2011, 06:59 AM   #90
littletrucker
I'd hit that
Im gonna cut the tires as soon as I drive it to work
Old January 4th, 2012, 06:42 PM   #91
littletrucker
I'd hit that
well Im having a lot trouble with the motor (reason i started the front axle swap in the first place)
Cant seem to get the 2.5 to run right, My old dist was whipped out, replaced it and a few other things.. doesnt seem to run any better. Might just have to swap it for an 5.3/th350/np205 combo or something along those lines
Old January 4th, 2012, 06:48 PM   #92
boggin-machine
boggin-machine's Avatar
moving alot pretty nice. what size shocks did you go with?
Old January 4th, 2012, 06:54 PM   #93
littletrucker
I'd hit that
They are 16" travel foa's, Any longer and I dont think I could have kept them under the hood and the jeep as low as I wanted.
Old January 4th, 2012, 07:20 PM   #94
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Originally Posted by littletrucker View Post
well Im having a lot trouble with the motor Cant seem to get the 2.5 to run right, My old dist was whipped out, replaced it and a few other things.. doesnt seem to run any better. Might just have to swap it for an 5.3/th350/np205 combo or something along those lines
Do a compression check...TJ 2.5's are prone to piston cracking.
Old January 4th, 2012, 07:24 PM   #95
boggin-machine
post a few pics of where you mounted everything on the front axle.
Old January 4th, 2012, 08:36 PM   #96
littletrucker
I'd hit that
Had a compression tester, couldnt get it to thread into the holes, seems like im gonna have to make some custom adapter. The threads are recessed to far into the head for the one I had. seems like its firing on all cylinders tho
I know you were interested in front 3 links, I'll try to get some specs+pictures for you
Old January 4th, 2012, 09:01 PM   #97
littletrucker
I'd hit that
no build thread is complete without crappy quality picture of welds
Link separation at frame about 5 inches, separation at axle about 9 inches had to modify the exhaust, cut off the old upper link brackets (the upper link really didnt have alot of side to side wiggle room, the starter and motor mount bracket really had to split down the middle to get it to tuck up there. Tucked the exhaust up as high as possible for a new skid plate coming soon
Didnt show in pictures but for the rear mounts of the hoops I used the thru hole in the frame that you put a socket thru for the original short arms. Had some tube that fit inside a 1.75x.120 wall, made both holes fit that, slid it thru, welded it, slid the 1.75 over welded that to the frame, welded it on the end to the inside tube, need to cap the ends still, but I like how that part came out. Notched the hoop tube to sit on that.
Old January 4th, 2012, 09:19 PM   #98
littletrucker
I'd hit that
I "had" inspirations of making a lightweight box and sealing it to the hood with some louvers to draw in actual cold air.
more weak ass weld pictures
Old January 4th, 2012, 09:20 PM   #99
It's looking good.
Old January 5th, 2012, 12:00 PM   #100
wally431
wally431's Avatar
Coming along nicely, I'd like to know if you made ur shock hoops or if you bought em and where from? I need a set and I like the look of those. You'll have to stop by sometime or give me ur number and I'll swing down sometime
Page generated in 0.61920 seconds with 83 queries
