Project Tiny TJ *37 krawlers-5.13's-Dana 60-14 bolt* *5.3 th400 np205* - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 18th, 2011, 04:48 PM   #41
2fst4you
2fst4you's Avatar
Nice work what welded you using for all this?
Old June 18th, 2011, 04:52 PM   #42
littletrucker
I'd hit that
littletrucker's Avatar
Hobart 125 mig welder
Old June 19th, 2011, 08:51 PM   #43
2fst4you
2fst4you's Avatar
What those run?
Old June 20th, 2011, 08:35 PM   #44
littletrucker
I'd hit that
not sure- havent had any trouble with it for several years now, just keeps welding and welding
Old June 25th, 2011, 12:18 PM   #45
littletrucker
I'd hit that
Ordered everything I need for rear discs on the 14bolt, have all the brackets I need, deciding on link material and what kind of ends I want to run. Gears and a locker next week maybe... pretty much decided on a 14 bolt after I broke the dana 35 (has me scared it went so easily) Might sacrifice some ground clearance on smaller tires for a while, but if im gonna do it.. Im only gonna do it once and do it right
I have rims/tires to run on it that really should only be 1 ish inch wider than the front- so I'll prolly run a 14 bolt/ dana 30 for awhile
Old June 28th, 2011, 08:52 PM   #46
littletrucker
I'd hit that
Got the rear discs getting calipers, should have brackets in the mail
Was out abusing the d35 in my sand pile
Old August 26th, 2011, 10:21 PM   #47
littletrucker
I'd hit that
some new pictures from this week.. Almost have it back to driving (pulled it apart on Monday8/22)
Old August 27th, 2011, 11:31 AM   #48
Michigan-Roost
Looks good :)
Michigan-Roost is offline   Reply With Quote
Old August 28th, 2011, 04:26 PM   #49
littletrucker
I'd hit that
From a few days ago, its back sitting on all 4 tires now, should be driving it this week. Ill try to grab some more pictures this week
Old September 1st, 2011, 01:10 PM   #50
littlemuddy
do it
littlemuddy's Avatar
looks pretty good. :) can see better now what you were showing me with your hands. :) gonna go beat on it now? and sweet that it has a detroit locker already. Now on to the front!?
littlemuddy is offline   Reply With Quote
Old September 1st, 2011, 02:10 PM   #51
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Shouldn't the calipers be behind the the axle? They look funny where they are at, maybe it is just me seeing I haven't done mine yet.
I guess just make sure bleaders are up and you are all set.
Old September 2nd, 2011, 04:53 PM   #52
littletrucker
I'd hit that
I guess you could run them either way, and yea the bleeders are to the upside
On a side note I did drive it on the 29th, Made the exhaust last night. Ordered a longer rear brake flex line and I need to hook the shocks up/possibly do some kind of limiting strap. this setup will droop out alot farther than the stock, and more than enough to bind the rear driveshaft
AND the 14 bolt I have has a detroit locker in it WOOT!
Old September 2nd, 2011, 09:29 PM   #53
littletrucker
I'd hit that
Here is a crappy picture of what I got going- took today (9/2)
3 link with trackbar no stretch
currently 9 inches seperation at axle 6 inches at frame (I have adjustable brackets could go 7-10ish if I notch the floor pan.. I may make an upper link tunnel) 32 inch links
I moved the stock spring mounts on the frame so they sit directly above the axle I ended up using the stock front springs and it matches the front 4 inch springs nicely
The shocks are not mounted- they will need to be ran outside the frame to get them close to all the way compressed when the suspension is on the bump stop.
I did order a longer rear brake line, My rear discs seem to work pretty nicely (I just gutted my stock proportioning valve and I think that will be sufficient)
5.13s and and a bearing kit are waiting for the axle I plan on getting a front dana 60 for my birthday
Super happy with how the width turned out compared to the front no more than 1 inch wider and barely noticeable
Old September 3rd, 2011, 04:04 PM   #54
littletrucker
I'd hit that
for a dana 30/ 14 bolt the width is pretty close (67 inch wide 14 bolt)
Old September 4th, 2011, 07:54 PM   #55
wally431
wally431's Avatar
Nice job man I'm in the process of doing the same but I have a front 60 to put in as well, just pulled the 8.8 tonight gettin rdy to slap in the rear 60 but I'm going to triangulate the uppers to get rid of the track bar. Gunna be a long process but it'll be sweet man
get ahold of me if you still have my number man
wally
wally431 is offline   Reply With Quote
Old September 4th, 2011, 10:45 PM   #56
littletrucker
I'd hit that
Im gonna be swapping in a 60 to the front here shortly
Old September 5th, 2011, 12:16 PM   #57
wally431
wally431's Avatar
Well stop by and take a look at mine see if you can give me any hints I'm doing the rear first then the front plus full hydro steering so that'll be nice
Old September 5th, 2011, 07:12 PM   #58
littletrucker
I'd hit that
Some poser flex shots, still need to mount the shocks. I think that my shock travel will be more of a limiting factor than a 3 link w/trackbar
I managed to pop the spring out on that side (I still need to bolt them down) and caved the steering backing the front tires over that same rock... Dam weak ass stock stuff
Old September 8th, 2011, 08:54 AM   #59
wally431
wally431's Avatar
In the one pix it looks like u moved the track bar to the other side? How is that working out? I'm thinking of moving my front track bar to the other side cuz ill have full hydro steering so it doesn't need to match up with my draglink cuz I wont have one
Sent from my SAMSUNG-SGH-I897 using Tapatalk
Old September 9th, 2011, 12:41 PM   #60
littletrucker
I'd hit that
I have seen front tracbars ran from the other side (I believe Jimmy's little ugly is like that) and yes I ran it from the other side and I havent noticed anything weird from it (including onroad driving)
Ill try to grab some more pictures of how it is tonight
Page generated in 0.54328 seconds with 83 queries
