Fj 60 axles and a dana 18 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 13th, 2010, 12:09 PM   #1
cerial
Direct Drive FTW
cerial's Avatar
Default Fj 60 axles and a dana 18
Crawled a couple threads and am impressed by the yoda axles. The plan was to run a 225/t-18/ Dana 18 with Saturn overdrive to 8" Mini (Hilux) 79-85 axles. Then swap in a Hp reverse cut with the stock 4.11's. Running 33's's to start. Then I got the idea of running fj 60's instead.
I am hoping you can crush a couple of myths I have heard.
The Dana 18 will not work with the 8" front. Why not it is ps drop to ps drop?
I really want to run a Saturn overdrive to save the engine. If I can not use the 18 with the 8" axles I want to know.
Can I simply use fj 60 axles they are ps drop and have the reverse cut gears and hp.
They are 60" and 58" so a bit wider then the 55" Mini's. But would gladly give up the space for the strength.
Thanks in advance
Tags
axle swap, cj5, dana, toyota
Page generated in 0.16520 seconds with 26 queries
