MJ: Sway Bar on lifted 88 Comanche - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 13th, 2010, 12:06 AM   #1
arbor153
Question Sway Bar on lifted 88 Comanche
I'm a newbie, and I have a question about an '88 Comanche I'm looking into buying. The ad says the sway bar mounts need to be welded to the axle, but in the pictures I cannot tell where these mounts would weld to or how to mount and connect them. OR if i can even run a sway bar?
Here's what the ad says about steering components: Steering - Teraflex knuckle, 1 3/8" DOM with 3/8" wall, very heavy duty, 3/4x5/8" ruffstuff heims all around. Over the axle trackbar mount.
AND pictures of the area in question:
http://img36.imageshack.us/img36/6348/dsc02579g.jpg
http://img693.imageshack.us/img693/9...1008311747.jpg
http://img832.imageshack.us/img832/4...1008311747.jpg
http://img828.imageshack.us/img828/1...1008311747.jpg
I appreciate any comments or advice!
Thanks for reading!
arbor153 is offline   Reply With Quote
Old November 13th, 2010, 07:53 AM   #2
littletrucker
I'd hit that
littletrucker's Avatar
only the first picture works so its hard to see the axle where the sway bar would mount
Old November 13th, 2010, 08:04 AM   #3
tj84
tj84's Avatar
are those the stock axles under it? i'm only getting one of your pics. it looks like it ,i would think they would weld in the same place as a ckerokee axle.i take it you are going to drive it on and off road ? if it's going to be driven off road only get rid of it .
tj84 is offline   Reply With Quote
Old November 13th, 2010, 08:33 AM   #4
Jeep_Shaun
Don't Fear The Jeeper
Jeep_Shaun's Avatar
I daily drive my Cherokee, and I completely removed my sway bar.. You don't really need one, I know a lot of other people that removed theirs also.
Jeep_Shaun is offline   Reply With Quote
Old November 13th, 2010, 11:48 AM   #5
arbor153
Yes I plan on using this as as a daily driver as well. The axle is a Dana 30 which i believe is the stock axle?
Here are a couple different links, hopefully they work:
I have heard of people completely tossing out the sway bar, but wouldn't it be better for freeway driving to have one on?
Thanks for the replies!
Old November 13th, 2010, 01:12 PM   #6
littletrucker
I'd hit that
its doesnt look like you have a very good track bar to steering bar angle- you want to try to have them exactly the same- you'll like this at freeway speed
the sway bar links were prolly removed when the highsteer arm was installed, the sway bar link probably would hit the newer steering arm- if you wanted to keep the sway bar, you'd prolly have to move it back on the frame an inch or so and try to get it to run up between the coils and the steering
could be easily done- but it depends on what you want to use it for- i have quick disconnects on my front sway bar, and i have drove it around on the road disconnected a lil more sway but its not that bad
Old November 13th, 2010, 02:54 PM   #7
arbor153
I'd like to be able to use this truck on the road as well as off road, including freeway driving. It has quick disconnects and the links, the mounts just need to be welded on. I guess to me it just looks like there's no room to even mount the sway bar links.
But what you're suggesting is to move back the sway bar itself and remount it on the frame?
And with the track bar to steering bar angle, do I want them to be parallel with each other? or as close as i can get?
I've heard mixed reviews on running no sway bar, some people say it's not a big problem and others say their trucks are all over the road.
Old November 13th, 2010, 02:58 PM   #8
go1lum
I never had a problem DDing my cherokee with no sways. I didn't like them. Just make sure you have a good HD trac bar should be fine.
go1lum is offline   Reply With Quote
Old November 13th, 2010, 03:43 PM   #9
arbor153
Even driving on the highway?
I need to be able to make a 420 mile trip every once in a while, so I have to be sure this thing will handle pretty well.
Old November 13th, 2010, 03:52 PM   #10
go1lum
Drove mine down the highway all the time.
Old November 13th, 2010, 05:17 PM   #11
littletrucker
I'd hit that
you might not have to remount the sway bar i guess, you could run the sway bar links from where its at to the top of the axle it they wont hit the steering arm
Old November 13th, 2010, 06:42 PM   #12
Jeep_Shaun
Jeep_Shaun's Avatar
I can run my jeep down the highway all day at 70mph with no sway bar and not have any issues with it at all.
Old November 13th, 2010, 07:04 PM   #13
Bishop
Bishop's Avatar
My personal and honest opinion is that if you daily drive the vehicle keep it on and invest in disco's.
ANY car can drive 70mph down the freeway with no sway bar with no problems at all.
but that's not where your sway bar comes into play.
At any given moment ANYTHING can happen to where you may need to maneuver your vehicle in a quick fashion. That will not be safe with out a sway bar. even worse at faster speeds. and worse yet on lifted or modified vehicles.
Bottom line is that's it is not safe for a vehicle that is used primarily for transportation. Compromising your vehicles handling for small gains once a month off road just simply isn't worth it. The price of quality disco's is well worth it. You got to pay to play man.
Here's where i say "just my .02" but I wont because this is just common sense.
Old November 13th, 2010, 09:29 PM   #14
arbor153
It does have quick disconnects, my only issue is finding where or how to mount them because the high steer gets in the way.
thanks for the help! any more advice or comments would be appreciated!
Tags
mj, mount, steering, sway bar, xj
Page generated in 0.29372 seconds with 65 queries
