how do you get the rotor off 3/4 ton - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 12th, 2010, 07:06 PM   #1
79gmcjimmy
in it to win it
79gmcjimmy's Avatar
Default how do you get the rotor off 3/4 ton
any tips for removing the hub assmbly off. trying to save rotors so they can be turned. i have gotten them apart before on differnt truck but i had to beat the shit out of the rotor to get it off.
79gmcjimmy is offline   Reply With Quote
Old November 12th, 2010, 07:13 PM   #2
in2deep
Hole tester
a little more info like model and year will help
Old November 12th, 2010, 07:14 PM   #3
Freak
Wheelin the HD
Freak's Avatar
Chevy? Ford? Toyota? Feiat? Mercadies? Dodge?
Old November 12th, 2010, 07:16 PM   #4
kj kyle
kj kyle's Avatar
well its in the dodge tech, and titled "3/4 ton" I'm going to assume dodge ram 2500. the year would help though
kj kyle is offline   Reply With Quote
Old November 12th, 2010, 11:05 PM   #5
79gmcjimmy
in it to win it
79gmcjimmy's Avatar
99 dodge 2500 cummins red extened cab long box 4x4 need to know anything else about it
Old November 13th, 2010, 11:13 AM   #6
79gmcjimmy
in it to win it
79gmcjimmy's Avatar
i know they can be a bitch i just want to get my rotors turned so i dont have to buy new
Old November 13th, 2010, 11:43 AM   #7
in2deep
Hole tester
spray some wd40 where it mounts to the hub and beat it with a dead blow hammer
Old November 13th, 2010, 01:19 PM   #8
littletrucker
I'd hit that
littletrucker's Avatar
id heat up the rotor around the hub with a torch (dont go too crazy- dont want to cook the unit bearings) as that is prolly where it has some corrosion and is getting hung up on- heat it, hose it down with lube, and wack it with something around the outside to loosen it up should slip right off
Old November 13th, 2010, 01:59 PM   #9
GREASYHANDS
GREASYHANDS's Avatar
Isnt this the design were the rotor is behind the face of the hub?
If it is then u need to remove the unit bearing and press the studs out to remove the rotor
Old November 13th, 2010, 02:01 PM   #10
GREASYHANDS
To get the hub out use a socket and extensions on the hub bolts, and beat on that, to avoid damaging the bearings and rotors.
Old November 13th, 2010, 02:04 PM   #11
GREASYHANDS
or buy something like this for an air hammer
Old November 13th, 2010, 03:13 PM   #12
79gmcjimmy
in it to win it
79gmcjimmy's Avatar
no room for a air hammer unless you take the hole knuckle apart
Old November 13th, 2010, 04:31 PM   #13
GREASYHANDS
then ur doing it wrong
Old November 27th, 2010, 05:22 PM   #14
boggin-machine
boggin-machine's Avatar
mikey on my 99 the bearing is pressed into the hub. you will need to beat the studs out of it to get the rotor off.
Old January 2nd, 2011, 10:56 PM   #15
shawnsack
dude its just like the other guy said stick the socket on an extension then thread the 2 bolts into the bearing opposite of each other from the back and put the socket on the bolt and the extension against the housing or control arm then start the truck and use the power steering to press the bearing out and work a little at a time so it doesnt get cocked in there but it dont matter because i dont think those rotors can be turned off the truck... they either need to be turned on the truck or replaced
shawnsack is offline   Reply With Quote
Old January 2nd, 2011, 10:58 PM   #16
shawnsack
and once you get the hub off you gotta pound all 8 wheel studs out and then the rotor will come off the back of the hub
Page generated in 0.24702 seconds with 71 queries
