Chrysler 8.25-Center pin removal tips.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 7th, 2010, 08:47 PM   #1
0Toncaddy
Big Belly Customs
0Toncaddy's Avatar
Default Chrysler 8.25-Center pin removal tips....
I just bought a chrysler 8.25 for the open carrier because the one in my xj is welded and its my DD, i pulled the cover drained the fluid and removed the center pin retaining bolt/ piece of broken bolt, but the pin will only come out about 3/4 inch and its stuck (no its not hitting the housing or pinion) punch and hammer/ air hammer= No dice. it will rotate but it wont budge after a certain point and i ran out of time to eff with it today, so maybe a fresh perspective is in order.
So does anyone have any "tips" for removing a stubborn differential center pin?
other than what i have tried....
0Toncaddy is offline   Reply With Quote
Old November 8th, 2010, 03:49 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Are you trying to push it in or pull it out?
I ask because if you're pushing it in it may be hitting a ring gear tooth, depending what the ratio is.
Old November 8th, 2010, 07:20 PM   #3
0Toncaddy
Big Belly Customs
0Toncaddy's Avatar
Default both
I have tried it both ways and no luck, and i cant see any interference from anything, its a 3:55 gear
Page generated in 0.17053 seconds with 32 queries
