Poop Pipe Info! - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2010, 12:32 PM   #81
4x4girl03
Bill's Custom Fab, Inc. in Mt. Pleasant is a great place to buy your pipe. Way cheaper than Alro. I got some 1-1/4" sch. 40 in December for $1.21/ft ($25.41 for 21'). They also have a drop rack that they sell material from for 50% off. Good place to shop for steel.
4x4girl03 is offline   Reply With Quote
Old January 13th, 2010, 01:19 PM   #82
Just make sure you are finding out what material spec it is.....
Old January 20th, 2010, 11:59 AM   #83
CPK_Jim
Powder Coater
CPK_Jim's Avatar
Originally Posted by boggin-machine View Post
any one want to set up a group buy for some tubing
hmmm. I am in bay city area and may be interested in helping out with a group buy. Ive been trying to put together a decent size order on my own, for things I will be building soon, so the more the better. I can do the pickup, I usually have to take the trailer anyways because I buy full uncut bars (somtimes 24ft) when possible.
And incase anyone is wondering, yes the more you buy the cheaper it gets.
If anyone is interested that is.
Jim
CPK_Jim is offline   Reply With Quote
Old February 17th, 2011, 05:28 AM   #84
luvitmyjeep
broken
luvitmyjeep's Avatar
it was $42 a stick yesterday.
time to go on a bender, bender
luvitmyjeep is offline   Reply With Quote
Old March 2nd, 2011, 06:00 AM   #85
Shotgun
I only wheel with boats.
Shotgun's Avatar
I need to start to stockpyle on some for a cage soon also.
Old March 3rd, 2011, 01:28 PM   #86
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
use tubing
Old April 13th, 2011, 10:23 AM   #87
wadshrp
wadshrp's Avatar
im looking at buys some where in the 100-140 ft of tube for bumpers, sliders, and tube fenders if anyone is close and wants to do a bulk order... also about to buy that tube bender from harbor freight soon to do all the work
Originally Posted by clarkstoncracker the d-bag View Post
I'll trade you my trail rig for the front wheels off your joe dirtmobile.
Originally Posted by chadcooper55 View Post
Hi steveo, this is chadcooper55. I like long walks on the beach and I can take two dicks in my butt at the same time. Want to go out some time?
wadshrp is offline   Reply With Quote
Old May 26th, 2011, 04:11 PM   #88
cerial
Direct Drive FTW
cerial's Avatar
Pipe makes great rock sliders and bumpers. It has a thicker wall then pipe making it harder to bend and easier to weld. This wall also makes it heavier then tube in most cases(depends on the grades).
A proper design is more vital then sheer strength in any cage. The tube does dent easier that's a fact. Tube has a thinner wall then pipe(in most cases) and that's why it dents easier. Because of this thicker wall pipe is heavier then tube. In many cases the fabrication process is the same.
But, if you are buying pipe because it is cheaper your not looking hard enough. A500 structural pipe will run you between $2.50 and $4 a foot. If you look around (pirate) you can find the same size tube for about a third more.
Some of you are thinking you can head down and pick up a ton at the scrap yard and clean it up. That's all well and good but you are forgetting about the grades. And there are tons of grades.
http://www.engineeringtoolbox.com/as...ing-d_469.html
For the most part though you will find grade A500. But without the stamp who knows what your buying.
My dual layer cage/body will encompass around 300 feet of tube. The sheer weight difference is causing me to use tube instead of pipe.
Old May 26th, 2011, 04:22 PM   #89
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Don't forget that you can buy a HF pipe bender that will do close to 90* bends for alot less then a Tube bender. This is why most people chose pipe for low budget projects.
Old May 28th, 2011, 10:57 AM   #90
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Originally Posted by RDK_YJ88 View Post
Don't forget that you can buy a HF pipe bender that will do close to 90* kinks for alot less then a Tube bender. This is why most people chose pipe for low budget projects.
fixed!
Old March 23rd, 2012, 09:31 AM   #91
treky67
millwright/jeepwright
treky67's Avatar
I find pipe works great. I also took the harbor freight bender and polished the cast dies, put some lubricant on them and i can make bents much more than 90* without a kink to be found. Polishing and lubricating the dies helps the pipe slide in the die much better.
All of this was made using the harbor freight bender, with no kinks even with the stinger and grill hoop, that are all over 90* bends.
treky67 is offline   Reply With Quote
Old December 18th, 2012, 09:24 AM   #92
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
So how is everyone polishing their kinker dies? Also what material would make for a good slug when using 1-1/4" schedule 40?
Old December 19th, 2012, 10:07 PM   #93
in2deep
Hole tester
dont you polish my kinker dies i like my bends all fucked up
really do what you want with it polish and lube away good luck
Old December 19th, 2012, 10:15 PM   #94
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Haha. Thanks, I was going to ask you if I could after I found out how they were polished. But I'll look around for some more info on how to do it and then polish and paint all the dies for you.
Old November 12th, 2013, 10:12 AM   #95
jeepkid984
The Violator
It makes sense to polish the dies, also putting lube on helps keep the pipe from expanding during the bend that will cause the pipe to jam and thus kink. Die builders at my shop stress Class 1 ( polished finishes) on form steel details. Most of the die parts I machine need a super slick surface and since it travel through a prog die the steel will get hotter at every hit. This is where lube sprayers come in. Helps to keep the steel from distorting.
jeepkid984 is offline   Reply With Quote
Tags
acid shit pipe
Page generated in 0.38869 seconds with 68 queries
