Poop Pipe Info! - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2007, 09:38 PM   #41
Originally Posted by free2blaze View Post
I bought my 12 ton bender at harbour freight for $69.00, I have built tube fenders for my jeep project so far, it works great.
If you don't have the springs on it (mine doesn't), keep it upright, don't lay it on its side. Otherwise, it'll take 1 million pumps to make a bend..
Old March 9th, 2007, 11:32 PM   #42
MayhemInc
I hate people
MayhemInc's Avatar
• Pipe is generally more rigid than tube, and is usually produced in heavier wall thicknesses.
• Pipe is specified by a nominal dimension which bears little or no resemblance to the actual dimensions of the pipe. 1" Schedule 40 pipe, for instance, has an actual OD of 1.32", a wall of 0.133", and an inner diameter of 1.049". Tube dimensions are actual dimensions.
• Pipe fittings are sized to meet pipe sizes, but not tube sizes. A 1" schedule 40 nipple will fit correctly on a 1" schedule 40 pipe, but not on a 1" OD tube.
Tube refers to round, square, rectangular or any shape of hollow material of uniform thickness which is defined by the outside diameter and wall thickness dimensions. It is the grade of the metals and how tube is produced and processed that is important.
• Structural Tube is generally produced using the ERW (Electric Resistance Welded) process. Identified under the Circular Hollow Section (CHS) or Hollow Structural Sections (HSS) class. Some steel mills specifically develop structural tube for roll over protective structures.
• Mechanical Tubing is usually produced as seamless, as-welded or DOM (Drawn Over Mandrel) tube.
Types of Tube and Pipe
Structural Tube - high strength welded steel tubing
Mechanical Tube - seamless, as-welded and drawn over mandrel
Stainless Tubing and Pipe - several seamless and welding processes requiring resistance to corrosive materials
Standard Pipe - several seamless or electric weld process, carries liquid or gas
What the acronyms mean:
Electric Resistance Welded (ERW)
Cold Drawn Welded (CDW)
Drawn Over Mandrel (DOM)
Cold Drawn Seamless (CDS)
Cold Rolled Electric Welded (CREW)
Hot Rolled Electric Welded (HREW)
Thier descriptions:
Cold formed, electric resistance welded tubing can be produced in round, square or rectangle shapes. ERW tube is produced by processing a flat rolled steel into strips which are cold-formed, welded and seam annealed or normalized (depending on the manufacturer). You can usually identify ERW tube by the blue strip down one side of the tube (which is the welded area). The ERW process can guarantee the weld to be as strong or stronger than the rest of the tube body. The origin from a flat strip results in a more concentric product than Cold Drawn Seamless (CDS). ERW can also be known as CREW (Cold Rolled Electric Welded).
Typical Applications:
Structural columns, beams, supports, heavy equipment frames with 58,000 PSI tensile.
Produced from a steel strip by cold forming, electric resistance welding (ERW) and cold drawing to finished dimensions, CDW is the most versatile and widely sold mechanical tubing grade. A variety of thermal treatments can be applied to alter the mechanical properties and machinability. CDW is used for a tremendous variety of machine parts where close tolerances and higher mechanical properties are needed.
Automotive components, shock absorbers, hydraulic cylinders, sleeves, bushings, axles and shafting.
DOM is formed from strip and Electric Resistance Welded (ERW) then cold drawn through a die and over a mandrel resulting in improved inner surfaces and dimensional quality. This process, called cold drawing, may be repeated more than once to reach the planned OD, ID, or wall dimension. Multiple draws can also be used to increase the strength or improve the surface finish of the tubes. During the drawing operation, the tubes may be process annealed to increase the ductility of the material. Lower cost alternative to CDS with equal or superior physical properties.
Machined parts, rollers, shafts, sleeves, steering columns, axle tubes, drive shafts, bushings and is most readily adaptable in cylinder applications with a 80,000 PSI tensile.
General purpose seamless tubing, which is a solid bar of carbon steel drawn over a mandrel to form the tube section. CDS allows selection of chemistry and rough tube size. Cold drawing produces higher physical properties without heat treating. Offers widest range of sizes and chemistries in mechanical tubing. Better tolerances and reduced machining allowances over Hot Finished Seamless (HFS).
Machined parts, bushings, spacers, bearings, rollers, shafts, sleeves and cylinders with a 75,000 PSI tensile.
Cold rolled steels are steels that are shaped by high pressure rollers at normal temperature in the steel mill. Cold rolling work hardens the material substantially. The steel is then welded by the electric weld process. A cold rolled steel can be either a mild steel or a high carbon steel. Can also be termed as ERW (Electric Resistance Welded). See » ERW
Hot rolled steel is steel that is rolled to size in the mill while red hot. Hot rolling steel does not work harden it as much as cold rolling. For this reason, hot rolled steel is more easily machined than cold rolled.
What's the difference between Tube and Pipe?
The general term for pipe was that it was primarily used for carrying gas or liquid. It was not intended for structural use because the dimensions used in describing pipe was not dimensionally accurate. Measurement was referred to its inside diameter and wall thickness. The inside diameter was a true dimension, but over the years had become "nominal" (in name only) so that when pipe size was referred to, it was an approximate inside diameter measurement with the thickness described by the term "schedule".
MayhemInc is offline   Reply With Quote
Old March 9th, 2007, 11:38 PM   #43
MayhemInc
I hate people
MayhemInc's Avatar
and that being said... here's whut u can do with sked 40 poop pipe:
everything is totally symetrical and strong as nails
Old March 11th, 2007, 04:16 PM   #44
groundhog
groundhog's Avatar
Nice work It looks real good.
groundhog is offline   Reply With Quote
Old March 13th, 2007, 08:15 PM   #45
groundhog
groundhog's Avatar
Hey did you bend all that with a tube bender or something along the lines of a HF pipe bender?
Old March 19th, 2007, 12:39 PM   #46
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
Vary nice looking work, Same ?? as above, what type of bender did you use
nick_n_ii is offline   Reply With Quote
Old March 19th, 2007, 01:13 PM   #47
9 times out of 10, someone using pipe is using the HF type bender in my first post.
Old March 19th, 2007, 01:16 PM   #48
nick_n_ii
nick_n_ii's Avatar
If that is the case it's the same one I just bought. Hope to start buying pipe in the next few weeks to start some Learning projects..
Old July 25th, 2007, 03:32 PM   #49
rockrat
rockrat's Avatar
I have a 16ton harbor freight bender; it'll be used to make our exocage on our grand.
rockrat is offline   Reply With Quote
Old March 19th, 2008, 05:23 PM   #50
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
Just wondering if 56 dollars for a 20 foot stick of pipe sounds about right these days.
I called Macomb Pipe in Burton just wondering about a general figure, and thats what they told me.
And its been around 2 years since most of you were talking in this thread. Any regrets using pipe instead of tube?
Old March 26th, 2008, 06:35 PM   #51
i called pontiac steel two weeks ago the 21 ft stick was 38.00
Old March 27th, 2008, 06:38 AM   #52
95geo
newbie
95geo's Avatar
it is about 4.80 a foot for 1.75 .120 DOM right now
Old March 27th, 2008, 06:46 AM   #53
phittie1100
phittie1100's Avatar
Some of the guys in our club use Hill Steel on Hill Rd @ US23
Paul - 2005 Wrangler Unlimited
KD8PAV
phittie1100 is offline   Reply With Quote
Old April 5th, 2008, 12:24 AM   #54
Nuggets
I fix stuff!
Nuggets's Avatar
I'm confused. I'm just going to build a roll cage out of wood.
Old May 29th, 2008, 09:47 PM   #55
Mclovin
"The Situation"
Mclovin's Avatar
theyre great for small stuff but if you're anything over 2 sticks id go to pontiac steel..
Old December 10th, 2008, 12:40 PM   #56
DUNE JUMP
DUNE JUMP's Avatar
Up until last week all we had to talk about was poop pipe, tube, harbor freight kinkers, etc. Thanks to nite crawler, we now have a new cage material to discuss: tramp tube
Thanks buddy.
(trampoline parts)
Old December 27th, 2008, 07:08 AM   #57
nite crawler
Scout II
nite crawler's Avatar
If you use an old kids Trampoline for part's, the 90's are bent already. On one of my mud drag Runs ,the motor shut down 50 feet in. A 625 draged me 150' thru 3 foot deep MUD hooked to the passenger front tube.
nite crawler is offline   Reply With Quote
Old December 27th, 2008, 01:49 PM   #58
Are you Fing serious?
Old December 28th, 2008, 06:31 AM   #59
jhnyquest
goof ball
jhnyquest's Avatar
Just becuase something worked doesn't mean that its a good idea.
Old December 28th, 2008, 06:37 AM   #60
Nuggets
I fix stuff!
Nuggets's Avatar
Wood roll cages are better.
Tags
acid shit pipe
Page generated in 1.00316 seconds with 83 queries
