sealing a water jacket - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2010, 02:48 PM   #1
84mudder
84mudder's Avatar
Send a message via AIM to 84mudder
Default sealing a water jacket
i have a leaky water jacket on my mid 70's 302v8. I took the bolt out and let the coolant drain out. What type of sealer is needed? I have RTV black and Grey. Thanks.
84mudder is offline   Reply With Quote
Old November 4th, 2010, 06:24 PM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
what do you mean by water jacket? and what bolt?
Normally, blue RTV is used for "water", and black for oil.
Old November 4th, 2010, 06:41 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
if your talking about a head bolt in a water passage leaking, you need a product called hylomar. its a white paste looking stuff. comes in a tube like rtv.
joe_jeep is online now   Reply With Quote
Old November 20th, 2010, 12:45 PM   #4
mprmn08
mprmn08's Avatar
if its a head bolt leaking i would just run a good block sealer in your antifreeze and it will seal it up. if its a core plug then knock it out and get a new one and put some #2 permatec around the whole before you knock in the new one. thats all we do when we install them at our shop. we do them all day long like that and they dont leak.
Old November 20th, 2010, 12:46 PM   #5
mprmn08
mprmn08's Avatar
fwiw you shouldnt use silicone on stuff like that cause it hardens and will clog where as #2 stays plyable so if it gets into the system it will just get chopped up by the water pump or pushed through a whole were silicone would normally clog.
Page generated in 0.25697 seconds with 38 queries
