302 bad throttle response - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 3rd, 2010, 04:50 PM   #1
84mudder
84mudder's Avatar
Send a message via AIM to 84mudder
Default 302 bad throttle response
I have a late 70's 302 in my Ranger. Lately it has been having bad throttle response off the line. 2,000-6,000 rpm it runs perfect but down low 1,000-2,000 rpm it cuts out for a second then goes. Engine has always ran perfect. Recently replaced the points because the old ones were shot.
Any ideas on what to check next? Could my carb need rejetting due to the colder weather?
84mudder is offline   Reply With Quote
Old November 3rd, 2010, 05:07 PM   #2
IDIeselman
IDIeselman's Avatar
There are many things that could cause this but, Did you accidently bump the timing back when you replaced the points or was the replacement because of the condition? And why are you running points when the duraspark is such an easy swap?
Old November 3rd, 2010, 05:08 PM   #3
84mudder
84mudder's Avatar
replaced due to burnt out points
Old November 3rd, 2010, 05:09 PM   #4
IDIeselman
IDIeselman's Avatar
If you have a timing light double check the timing, If not bump the timing ahead a few degrees and road test.
Old November 3rd, 2010, 05:13 PM   #5
84mudder
84mudder's Avatar
will try bumping the timing , thanks
Old November 3rd, 2010, 06:46 PM   #6
84mudder
84mudder's Avatar
got the bogging to go away. now time to change the alternator..
Page generated in 0.20027 seconds with 41 queries
