Cold is F'ing with me - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2005, 08:16 AM   #1
Lothos
KD8GKB
Lothos's Avatar
Default Cold is F'ing with me
Today and a few days ago when it got below freezing, my engine would stick at a certain RPM unless I shifted to neutral and redlined it a couple times usually until 15 to 20 minutes after it reached full warmup temp. I use a block heater in the winter which lets the temp guage say its warm inside of 10 minutes of driving, but I think the entire engine is not actually warm yet. Obviously its an electronic device thats not liking the cold, but any ideas?
Old December 6th, 2005, 11:32 AM   #2
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
this is a jeep 4.0?
GMCsonoma94 is offline   Reply With Quote
Old December 6th, 2005, 11:41 AM   #3
Lothos
KD8GKB
Lothos's Avatar
yeah, 2003 rubicon.
Old December 6th, 2005, 01:54 PM   #4
GMCsonoma94
1 wheel peel
check your idle air controler
Old December 6th, 2005, 02:59 PM   #5
Lothos
KD8GKB
Lothos's Avatar
How about MAP sensor?
"If a vehicle is started and driven to a
very different altitude than where it was at key-on,
the barometric pressure needs to be updated. Any
time the PCM sees Wide Open Throttle (WOT), based
upon Throttle Position Sensor (TPS) angle and RPM,
it will update barometric pressure in the MAP memory
cell. With periodic updates, the PCM can make
its calculations more effectively."
The condition i am seeing is the engine does not decrease in throttle upon lifting off the pedal below whatever point it decides to stick at. Typically its been about 1500 rpm.
Old December 6th, 2005, 03:07 PM   #6
blizazer
blizazer's Avatar
Send a message via AIM to blizazer
Your engine is also going to idle higher when its cold, to make it warm up faster, and meet emissions faster.
How fast is it idling?
How is it obviously electronic?
A sticking throttle cable or plate could cause this too.
blizazer is offline   Reply With Quote
Old December 6th, 2005, 03:19 PM   #7
Lothos
KD8GKB
Lothos's Avatar
It's not an idle that's happening. Because 1800rpm is not an idle for an automatic and it can sometimes stick at like 2700rpm. Since my drive to work is done between 35 and 50mph, I am rarely stomping on it over 2500rpm. When I am heavy on the brake to hold the vehicle at a stop, something's a miss. The cable is fine, first thing i checked. I've had alot of sensor problems in the past which is why i jumped on the electronic issue, but it could be the Idle Air Control Motor though.
Old December 6th, 2005, 03:44 PM   #8
The map sensor can cause funny idles up around 2000 like that. Sometimes water/dirt/mud can block the sensor hole on them.
Old December 6th, 2005, 07:48 PM   #9
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
If its hanging up while driviing and acting like cruise control its sounds like the throttle plate is holding the TPS in a frozen position. it could be you have modified air intake like air raid or some thing that is letting in way to much cold air, or you have a worn throttle plate and its creating a high spot that is freezing in place because of a high velosity air moving threw it. check everything twice you don't need to have an accident
Yetti
Old December 12th, 2005, 07:36 AM   #10
Lothos
KD8GKB
Lothos's Avatar
Update: turned out to be nice and thick frozen Mounds mud on the throttle return spring :)
On another note, my starter is misbehaving.
Old December 12th, 2005, 08:21 AM   #11
Bones
Bones's Avatar
the starter is most likely the mounds mud too
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 12th, 2005, 11:18 AM   #12
Lothos
KD8GKB
Lothos's Avatar
I suspect, but its so damn cold out I don't want to pull it.
Page generated in 0.31241 seconds with 59 queries
