hi-steer help! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 1st, 2010, 09:11 PM   #1
rangerluc
rangerluc's Avatar
Exclamation hi-steer help!
ive got a dana 44 with 78-79 outers from an early bronco. i was going to run hi steer on my passenger knuckle but i just realized yesterday that its not a flat top knuckle and its rounded at the top. how can i mount my hi steer arm? or any reccomendations on how to make a hi steer work is much appreciated
-Luc
rangerluc is offline   Reply With Quote
Old November 1st, 2010, 09:13 PM   #2
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Have to have them milled and drilled... Cost me about $80
Old November 1st, 2010, 09:19 PM   #3
rangerluc
rangerluc's Avatar
is there enough material on the knuckle to have it milled?
Old November 1st, 2010, 09:23 PM   #4
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I'm not familiar with Bronco knuckles but I had 78 ford F-250 knuckles and there was plenty
Old November 1st, 2010, 09:24 PM   #5
rangerluc
rangerluc's Avatar
ok thanks!
Old November 1st, 2010, 09:26 PM   #6
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Not with the knuckles you have. You'll need f150 supercab knuckles or 8 lug 44 knuckles to go high steer and keep ford parts.
Here is a good source of info for you to read: http://77cj.littlekeylime.com/flatop_knucles.html
Old November 1st, 2010, 09:27 PM   #7
Mr. Beefy
BFT!
Mr. Beefy's Avatar
If you want to keep it 5 lug get 84ish dodge 1/2 ton knuckles.
(keeps it 5 on 5.5 also)
Old November 1st, 2010, 10:02 PM   #8
rangerluc
rangerluc's Avatar
ok, im going to start looking for the supercab knuckle, it says its all bolt on. any ideas on where i should start looking?
thanks
Old November 1st, 2010, 11:41 PM   #9
bigblockford79
Big Block Ranger
thanks
Good Luck, not a lot of SC trucks were built and most are long gone. Those that are left are most likely someones pride and joy.
Old November 3rd, 2010, 09:30 AM   #10
John D
John D's Avatar
1976 K5 Blazer knuckles, the right side needs to be drilled and tapped. There are not too hard to find and you can still run the Ford hub/rotor. make sure you get the Chevy calipers, caliper mounts and spindles. I found the complete Chevy LP D44 for 50 bucks, but then again I had time to sit and wait for it.
Right
Left
Page generated in 0.28010 seconds with 53 queries
