FE 360 Trans. Option - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 1st, 2010, 10:10 AM   #1
snocross2xtremes
snocross2xtremes's Avatar
Default FE 360 Trans. Option
I have a 72 F250 with what i believe is a FE 360? and has 4 speed 2wd manual trans. I would like swap in a 3 speed non OD trans. like a C6? First what year trans. do i need to look at? I'm looking for a new or re-manufactured one with a warranty. My second question is what Torque convert will i use? My Concern is being a 72 and a manual will i be able to get a convert that pilot bearing hole is the correct size.
Thanks in advance for any info you have!
Old November 2nd, 2010, 06:48 AM   #2
Quiefinator
go'til itsounds expensive
You look like you are questioning the fact that it is a 360. 352, 360 and 390's are all cast from the same block. So engine size wont make a difference.
As for the automatic trans I dont have a clue, they drive me nuts. you will have to find one that will bolt to an FE because the small and non FE big blocks are different. If the trans you have is an NP435, then you have my favorite Ford trans. Why would you want to swap?
Old November 2nd, 2010, 08:22 AM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
Any C6 that will bolt to an FE motor will work
Buy a torque converter to match the trans
Pilot bearing is a non issue, you will need to dump the flywheel and buy a flexplate that fits the motor and matches the trans/converter type.
Page generated in 0.21501 seconds with 32 queries
