96 explorer head gasket - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 1st, 2010, 09:13 AM   #1
camoII
camoII's Avatar
Default 96 explorer head gasket
My brother just noticed his head gasket is leaking on his explorer. Is this a common problem? It only has 100k miles on the engine and was extremely well cared for. I know the 2.9s had head problems but wasn't sure about the 4.0s. Any input on this would be appreciated. Thanks
camoII is offline   Reply With Quote
Old November 1st, 2010, 09:25 AM   #2
lepp1892
WebWheeling1KeyAtaTime
lepp1892's Avatar
The tend to crack between the valves on occaision... Not extremely common but it happens. It happened to my 4.0. But my engine led a rough life.
lepp1892 is online now   Reply With Quote
Old November 1st, 2010, 10:36 AM   #3
prozak1986
prozak1986's Avatar
the lower intake manifold gasket gave out on my friends 96 exploder , he was told by 2 mechanic shops that it was a headgasket , when we got around to fixing it we noticed the LIM gasket was bad ,., this may or may not be your problem
prozak1986 is offline   Reply With Quote
Old November 1st, 2010, 10:53 AM   #4
camoII
camoII's Avatar
He looked from under the truck and noticed it leaking under the exhaust manifold on the drivers side from under the head. so it's gotta be a head gasket just hoping the head isn't cracked. It had an easy life but you never know crazy things happen. Thanks for the replys.
Old November 6th, 2010, 06:33 PM   #5
L4CX
Out for the Summer!
L4CX's Avatar
I had a 96 that needed the gaskets replaced. I was under the assumption that it was VERY common. At least for them to leak. Good luck!
L4CX is offline   Reply With Quote
Old November 9th, 2010, 10:40 AM   #6
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
from what i've heard it's just better to find a good used engine than try and fix that. like i said, from what i've heard it's alot of work to tear it down to fix and not much more time you can just swap in an engine. jsut a thought, i know you can good engine's fairly cheap.
big_ol_bronco78 is offline   Reply With Quote
Old November 9th, 2010, 12:33 PM   #7
camoII
camoII's Avatar
I started tearing into today. Not all that hard just time consuming. Stated at about 10 this morning and I'm already taking off the intake as we speak. Just gotta get the heads off and have em checked. Thanks for the replys though everybody.
Page generated in 0.15859 seconds with 44 queries
