Project Blurple - Page 22 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2014, 07:35 AM   #421
I had jam nuts loosen up even with the TRE's rotated. But a quick tack weld solved that problem.
Old March 24th, 2014, 07:40 AM   #422
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by Lousypirate View Post
I take it a high steer arm would interfere with stuff... even if you. Had it bolt to the underside of an angled one
Correct. It would've had a snowball effect on geometry changes and made packaging everything much more difficult. I have extremely tight clearances as it is and that would have made several of them even worse; primarily the track bar.
Old March 25th, 2014, 08:06 AM   #423
bbaXJ
Yooper In Training
bbaXJ's Avatar
Added some A-to-B and B spreader bars last night in preparation for my seat mounts.
I'm keeping the seats fairly low compared to stock. Partly for head room to the cage, partly cuz the factory ones sit obnoxiously high to begin with. Visibility will still be good, I'm not putting them on the floor or anything.
Old March 25th, 2014, 09:37 PM   #424
0Toncaddy
Big Belly Customs
0Toncaddy's Avatar
Wet fart..
0Toncaddy is offline   Reply With Quote
Old April 9th, 2014, 07:40 AM   #425
bbaXJ
Yooper In Training
bbaXJ's Avatar
Had a bit of a delay due to being sent to Cali for work, but I'm back at it now. Seats are in. I did fixed mounts, I don't see the need for sliders since I'll be the only one driving it. Not like it's hard to drill a few more holes if need be.
Rear seat bar is shown in previous post, here's the front seat bar:
Actual seat mounts are angle iron notched to fit the tubes. Simple, easy, and effective.
I debated how to do the bar(s) for shoulder belts. A simple horizontal bar works for many people, but I personally hate the look. I like multiple tubes to intersect at the same node, I hate having a random tube end in the middle of another, which is exactly what horizontal harness mounts typically do on the B pillar. Running it to the node at the top of the tub would've placed it too low. I thought of a few other ways to do it, but nothing I was very happy with..... Soooo I did it another way. I didn't really need more triangulation, but it can't hurt, looks good, adds strength, and ends up running right between the harness cutouts in the seats so will be perfect for mounting the shoulder belts to:
Bent to maximize clearance:
Headroom is pretty good, that was my biggest concern. If I contort my neck enough I can make contact with it, which offroad or in a hard roll I'm sure means I'd hit my head. I'll put a pad on it and call it good.
Typical joint at the bottom:
Overall view:
Old April 9th, 2014, 07:44 AM   #426
Strangler
Strangler's Avatar
Looks nice Sean.
Old April 9th, 2014, 08:17 AM   #427
littletrucker
I'd hit that
littletrucker's Avatar
I like how that cage looks.
Old April 9th, 2014, 09:22 AM   #428
TOPTRUK
Never Ending....
TOPTRUK's Avatar
How does your 5 points mount? Is it by tab or loop through the cage? Are you still going to have horizontal tubes to tie into B pillar for them to mount to?
TOPTRUK is offline   Reply With Quote
Old April 9th, 2014, 09:29 AM   #429
bbaXJ
Yooper In Training
bbaXJ's Avatar
They mount with tabs. I'm not running horizontal tubes for mounting, I'm gonna integrate something into the diagonal bars I just added, but I haven't decided exactly how I'm gonna do it yet. I'll probably either add some tabs to the bar(1 on each side of the bar), or I was thinking about maybe running a 1/2" ID sleeve through the diagonal tube running horizontally front-to-rear, with a 1/2" bolt through that with the harness tabs mounting to the back side of the sleeve. They'd be sharing the same mount, but I don't see the force being an issue, especially in that configuration.
Old April 9th, 2014, 08:16 PM   #430
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Looks nice!
Love the selfie, too!
*2007 Rubicon
*2006 Duramax
Old April 9th, 2014, 10:30 PM   #431
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by OnlyInMyXJ22 View Post
Looks nice!
Thanks! I expected more comments on the selfie to be honest.....the gl4x4 crew must be slacking
Old April 10th, 2014, 12:15 AM   #432
Wramblerguy
Wramblerguy's Avatar
You didn't even smile
Serous selfie
Seriously I like it though
3rd generation jeeper
Old April 10th, 2014, 06:17 AM   #433
benny87
Young Gun..!
benny87's Avatar
Looking good....!
benny87 is offline   Reply With Quote
Old April 11th, 2014, 09:36 PM   #434
knixon804
THE GENERAL
knixon804's Avatar
Killer
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JKU UD60s, 40" TRAIL GRAPPLERS, MACHETE BEADLOCKS, AEV BLOWER
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old April 13th, 2014, 06:31 PM   #435
bbaXJ
Yooper In Training
bbaXJ's Avatar
More progress. The cage is pretty much DONE! Added harness and seat belt mounts(I'll run factory belts for street and cruising, and have 5 point cam lock harnesses for "extreme" stuff), windshield bars, etc.
Simple shoulder harness mount
Seat mounts and lap/submarine belt mounts
Next up: install the fuel cell, cradle, and cover.
Old April 14th, 2014, 07:04 AM   #436
Looks great!
Old April 14th, 2014, 10:43 AM   #437
green50gt
Got rocks?
green50gt's Avatar
Looks great Sean!
I heart Jeeps
green50gt is offline   Reply With Quote
Old April 17th, 2014, 07:35 AM   #438
bbaXJ
Yooper In Training
bbaXJ's Avatar
Thanks guys.
I've been lazy and unmotivated this week, but worked on it last night anyway. Started getting the fuel cell situated.
It should sit just about here:
It's an RCI 2162, not the 2161 that most Jeep guys put back there. Instead of 12" tall and 9" wide, it's 9" tall and 12" wide.....I wanted to sink it down and minimize intrusion into the already small cargo area.
I'm glad I decided to drop it through the tub. Very little clearance loss, and in an area that shouldn't be an issue since it's forward of the tires. Still, it'll be surrounded/suspended by a 1/4" angle iron frame and will have a 3/16" skidplate underneath just to be safe.
The tub lost a surprising amount of structure by cutting that section out, but I'll be building new wheelwells and a cover for the fuel cell and will make sure to add the necessary support back in at that point. Most of the problem is probably that the C pillar mounts are also acting as body mounts, rather than the original floor crossmembers....I may add something down there too.
Old April 17th, 2014, 07:42 AM   #439
In hindsight, I wish I would have kept mine up in the tub and moved the rear axle back another 3-4".
Old April 17th, 2014, 07:45 AM   #440
bbaXJ
Yooper In Training
bbaXJ's Avatar
I don't want to move my axle back anymore, I hate comp cut. It's not exactly difficult to move the cell back up if needed though, especially compared to the other aspects of building these damn projects.
Page generated in 0.34477 seconds with 84 queries
