Project Blurple - Page 21 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2014, 07:15 PM   #401
chevotass
chevotass's Avatar
good idea. I need to do something with mine. either something like that or a fast fill kit
Old March 18th, 2014, 08:15 PM   #402
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
For all the sweet races you are winning?
Old March 18th, 2014, 08:32 PM   #403
chevotass
chevotass's Avatar
no, fuck nugget. so I can fill my tank without having to open my soft top and tailgate to fill my tank. and to help remove fumes from fill up inside the vehicle.
but thanks for reminding me that I did enter 1 race last year. which I won.
Old March 18th, 2014, 08:58 PM   #404
Christmas Cookie
You got a lot of never talking to me like that
Old March 18th, 2014, 09:02 PM   #405
kickstand
circling the drain
kickstand's Avatar
You can't make him never, he's not afraid of you.
Old March 18th, 2014, 09:24 PM   #406
chevotass
chevotass's Avatar
Old March 18th, 2014, 09:58 PM   #407
bbaXJ
Yooper In Training
bbaXJ's Avatar
I had originally planned on doing a cool radius "gusset" tube basically where the rear upper shock mounts wound up, with a plate with a dimple die on the passenger side and a fast fill on the driver side. I eliminated it for a few reasons. First, I didn't wanna have to unzip the window to get gas. I don't plan to run the top often, but I'm sure it'll happen enough to be annoying. Second, I decided it looks cleaner without tube and plate there so I don't wanna go that route. I was gonna run the filler in top of the cell like it comes from the get-go, but that's not ideal either. Fumes, difficult to fill with cargo back there, etc. The factory filler is too big to fit in the area I'll have behind the tube flare, so I need smaller. Fast fill kits aren't any smaller so I thought of the boat option....I think I'll go for it. I wish it weren't plastic, but the size, angle, and orientation are correct, and it'll be pretty well protected by the tube.
Old March 18th, 2014, 10:13 PM   #408
bbaXJ
Yooper In Training
bbaXJ's Avatar
Started on the front sway bar tonight:
I'm not thrilled with where I had to put it, but I didn't have any other decent options. The steering box takes up the whole frame rail, and I'll be keeping the bumper as tight as possible to the front of the box. On top would make it stick WAY up so that wasn't a good option either. It'll work, and should look better once I get the bumper in place. Good news is, the bar will help protect the steering box and will be a perfect place to mount a brace to.
Old March 23rd, 2014, 08:32 AM   #409
bbaXJ
Yooper In Training
bbaXJ's Avatar
Suspension is done now, just gotta add limit straps, various gussets, and finish weld it all. Now on to the next hundred small projects on it....
Ride height:
Droop:
Bump:
Tight clearance at full lock, but it fits:
Any higher and the links would be too short and I'd worry about inverting at full droop. Any lower and they'd be below the steering and very exposed to rocks.
Old March 23rd, 2014, 06:36 PM   #410
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
looks good. iv never had good luck with that steering setup, how do you keep it from twisting up and down?
sbcrichie is offline   Reply With Quote
Old March 23rd, 2014, 06:42 PM   #411
Mine twisted too but never seemed to hurt anything.
Old March 23rd, 2014, 06:44 PM   #412
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yea but gives sloppy feel in steering, and if you hit something real hard it will loosen the jam nut.
Old March 23rd, 2014, 07:00 PM   #413
Strangler
Strangler's Avatar
Only hit soft things.
Old March 23rd, 2014, 07:11 PM   #414
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
even medium hard things would do it
Old March 23rd, 2014, 07:19 PM   #415
That's what I did.
Old March 23rd, 2014, 08:19 PM   #416
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
You can rotate the TRE's on the tie rod in opposite directions, that helps a little bit with slop. Also could make some sort of poly or delrin "bushing" that goes between the knuckle and rubber boot to take up any slop. I just rotated mine, seems to work ok.
Old March 23rd, 2014, 09:33 PM   #417
bbaXJ
Yooper In Training
bbaXJ's Avatar
I haven't run it before either, but it was the best option at the height and geometry I'm working with. I plan on running the spacers mentioned above to eliminate/minimize rotation. If I have issues with the jam nuts loosening up I'll tack weld them....not like I'll be adjusting them regularly once it's dialed in.
Old March 23rd, 2014, 09:43 PM   #418
Lousypirate
Whoop Whoop
Lousypirate's Avatar
I only wheel pillows and mattresses
I take it a high steer arm would interfere with stuff... even if you. Had it bolt to the underside of an angled one
The Kernel (46 CJ2a)
Wow, i would lick those...
Old March 23rd, 2014, 10:20 PM   #419
snocross2xtremes
snocross2xtremes's Avatar
I had good luck with just rotating the tre's.
Old March 24th, 2014, 07:05 AM   #420
I haven't had any issues with that steering setup but I only hit soft things and cruise to the mall so that's probably the reason. No loose jam nuts either.
Page generated in 0.46332 seconds with 84 queries
