Project Blurple - Page 20 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2014, 06:11 AM   #381
Originally Posted by JohnnyJ View Post
We also setup two ball valves, one per circuit. If we have a failure we can shut down the failed circuit and still have good pedal on the opposite circuit. It was a trick we picked up from AlumCJ on his racer. It also works good as a line lock for digs, or to set a 4 wheel park brake when winching.
I like this with one exception. After setting both brakes as a parking break IF YOU FORGET TO TURN THEM BACK on, you have zero brakes. I think it's smarter to only set one circuit and leave the other live. (starting to roll down outer limits with no breaks was a tad bit scary )
Old March 14th, 2014, 07:03 AM   #382
TOPTRUK
Never Ending....
TOPTRUK's Avatar
Agreed, I placed mine on the rear circuit only. Mainly for a parking aid, but also for a line lock option.
TOPTRUK is offline   Reply With Quote
Old March 14th, 2014, 07:27 AM   #383
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old March 14th, 2014, 07:42 AM   #384
bbaXJ
Yooper In Training
bbaXJ's Avatar
The parking brake setup I'm planning to run should do the job for all that stuff too, it just uses a separate master cylinder instead of a manual valve. I like that it hooks up to the factory e-brake lever. Just gotta decide it I want another valve in there to lock out the front or rear in case of a broken line.
Old March 14th, 2014, 07:42 AM   #385
Having them on front and rear is a good thing for the reasons John pointed out. I just recommend using only one for a parking brake.
If you are doing a fresh piping job, take the time to do it.
Old March 14th, 2014, 08:35 AM   #386
bbaXJ
Yooper In Training
bbaXJ's Avatar
I don't see the concern you have being an issue. If you lock the brakes with the pedal and then close the valves, the brakes will be locked. You won't be able move until you open the valves again. Once the valves are open the brakes will work like normal. If you were to close both valves when the brakes aren't applied, then you'd have no brakes....but I don't know why you'd ever do that.
And yes, I'm doing all new lines and doing it right. I don't like halfassing anything, let alone brakes.
Old March 14th, 2014, 08:50 AM   #387
In theory you are correct. But here's what happened in the real world. Going down Outer Limits @ KOH, John stripped his pitman arm. We chocked it with rocks and applied the brakes as discussed, and then welded up the pitman arm. Once finished, I jumped in to drive it down the rest of the obstacle. The chock rocks were removed and I put it in gear, forgetting to unlock the brake valves. Apparently the brakes had softened up enough that they could not hold back the torque of the motor in low range, so I started to roll down hill uncontrolled. I applied the brakes hard enough that I blew out one of the lines.
How it happened versus theory, I can't explain. I just know John needed to wipe his seat before he sat back in it.
I know it doesn't look like much of a drop but when you don't have brakes....
Old March 14th, 2014, 09:06 AM   #388
bbaXJ
Yooper In Training
bbaXJ's Avatar
Probably because ball valves under that kind of pressure won't perfectly seal and will bleed off pressure over time. I agree, not a good situation, but also not likely to happen with a competent driver
Either way, if I get the valves I don't intend to use them as a parking brake, just an emergency shutoff should I tear a line at one end or the other. I plan to get the Undercover Fab bracket to use a master cylinder hooked to the factory e-brake lever. That will be more convenient to use, easier to tell if it's left on, and will only effect the rear brakes, still allowing the front to function normally.
Old March 14th, 2014, 09:44 AM   #389
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
It was locked front and rear on 35s, nothing can stop that.
Old March 14th, 2014, 09:53 AM   #390
True dat.
Old March 14th, 2014, 10:13 AM   #391
The ball valve I bought is rated for those pressures and does not bleed off over 3-5 month period tested to date. I know because I couldn't figure out why the hell my junk kept stalling out when trying to drive on flat ground......I always forget I set it
Old March 14th, 2014, 10:15 AM   #392
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Truth..
Even stalled his fawkin winch in Canada.
Dumbass
Edit - I still love you keep helping me with the 4link numberz
Old March 14th, 2014, 10:19 AM   #393
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Some GREAT info. on brakes here!!!! I have nothing of value to add unfortunately.....
RIP FULLSIZE4LIFE
Old March 14th, 2014, 10:36 AM   #394
bbaXJ
Yooper In Training
bbaXJ's Avatar
Depends on the valve I'm sure. One of the guys in my offroad club in college was using a linelock to hold his Burbalanche stationary on a slight incline. It gave out, started rolling, ran him over when he tried to hop in to hit the brakes, and ended up on its lid at the bottom of a ravine.
Edit: Nevermind, I typed all that then realized it was a manual trans that was left in gear and either rolled through the engine compression or popped out of gear. I forget....I drank a lot in college, and drink only slightly less now....
Old March 16th, 2014, 02:58 PM   #395
bbaXJ
Yooper In Training
bbaXJ's Avatar
I'm healed up enough that I was able to start back at it yesterday. Made decent progress on front bumps.
(no the bumpstop is not fully extended)
Heading out now to get the pad on the passenger side of the axle. Clearance is tight over there between the coilover and axle end track bar mount, but I got it all to fit.
Old March 16th, 2014, 08:50 PM   #396
benny87
Young Gun..!
benny87's Avatar
Fancy looking......!
Sent from my DROID RAZR HD using Tapatalk
benny87 is offline   Reply With Quote
Old March 17th, 2014, 07:08 AM   #397
Originally Posted by Mr. Beefy View Post
Truth..
Dumbass
I was getting so pissed. I thought I was bound up between the rocks and the tree and it was my damn parking brake. Randy was as confused as I was, then gave me the "Turn your brake off jackass" salute. Damn it.
Good to see you making progress. Brace the hell out of that trackbar mount. It's going to see major forces and impacts.
Old March 17th, 2014, 07:35 AM   #398
bbaXJ
Yooper In Training
bbaXJ's Avatar
It'll get plenty. It'll be welded to the axle tube, truss, bump pad, and gusseted again on both sides to tie in at the same points all over again. It's not going anywhere. The sway bar link will probably mount to it as well.
Edit: Damnit, just realized you meant the frame end that's in the pics. Yeah, it'll be welded on the side and bottom and boxed in. That won't be going anywhere either.
Old March 18th, 2014, 01:39 PM   #399
bbaXJ
Yooper In Training
bbaXJ's Avatar
Anybody ever use boat fuel fillers on their rigs? I'm thinking about something like this:
http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
I'm recessing my fuel cell into the floor and will have it covered. I'd like to get the filler and vent out of the cab to reduce likelihood of fumes. I'm thinking about a stock style filler on the tub, but the stock one won't fit. I could put this right up against the tube flare where it'd be unlikely to get damaged.
So is there any issue with running a filler like this on a Jeep?
Old March 18th, 2014, 01:45 PM   #400
Lousypirate
Whoop Whoop
Lousypirate's Avatar
shouldn't be a problem.
The Kernel (46 CJ2a)
Wow, i would lick those...
Page generated in 0.72471 seconds with 84 queries
