Project Blurple - Page 18 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2014, 01:20 PM   #341
bbaXJ
Yooper In Training
bbaXJ's Avatar
Agreed on both counts. And LP, it's not IF I back into a rock, it's WHEN.....I just hope I don't take out the shock in the process!
Old February 2nd, 2014, 02:39 PM   #342
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Calculated risk.
The Kernel (46 CJ2a)
Wow, i would lick those...
Old February 2nd, 2014, 03:28 PM   #343
bbaXJ
Yooper In Training
bbaXJ's Avatar
Yep!
Old February 2nd, 2014, 03:40 PM   #344
And at final assembly put the head of the bolt on the back side or you're sure to fubar the threads.
Old February 2nd, 2014, 05:12 PM   #345
bbaXJ
Yooper In Training
bbaXJ's Avatar
And don't let you spot for me or I'm sure to FUBAR the coilover
Old February 2nd, 2014, 05:54 PM   #346
TOPTRUK
Never Ending....
TOPTRUK's Avatar
Looking good Sean. I have a similar tie in with my front shock mounts... I've seen it done before! Hehe
TOPTRUK is offline   Reply With Quote
Old February 2nd, 2014, 06:46 PM   #347
TOPTRUK
Never Ending....
TOPTRUK's Avatar
Ah yes, the bud light case cardboard is by far the superior material for templates. That's who sponsors my builds as well... Lower mounts look great. I do agree; symmetric brackets would add a nice touch and wouldn't be a big hit in weight.
Old February 7th, 2014, 08:15 AM   #348
bbaXJ
Yooper In Training
bbaXJ's Avatar
These showed up Monday but I haven't had time to go work on the rig yet
Rear swaybar also showed up Wednesday. It's gonna be a tight fit for everything back there, I'll either have to bend the arms outboard of the airbumps or shorten them a couple inches. I'm thinking shortening them a bit won't hurt much since the 42" bar in the back is gonna have a bit more twist to it than the 36" bar up front.
Old February 7th, 2014, 08:04 PM   #349
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
2" or 4" travel?
sbcrichie is offline   Reply With Quote
Old February 7th, 2014, 08:26 PM   #350
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by sbcrichie View Post
2" or 4" travel?
3" front, 4" rear. I would've preferred 4" all around, but with only 5" or so front uptravel 4" seems overkill.
...But the 3" can easily be converted to 4" later, which is a big part of the reason I chose them. If I eventually go to a V8, triangulated 4 link, and full hydro I can gain some uptravel. Trying to keep it pretty street friendly for now. I work 40 miles from home and *really* want to be able to drive it there regularly in nice weather. If it sucks on the street it's not gonna stick around for long...I've already been dreaming of a small lift(not that the current 4" lift I'm running is very tall...), moderate 33-35" tires, and a souped up LS motor.
Old February 7th, 2014, 08:28 PM   #351
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
best thing I did on mine was shim the 4" travel bumps to 2" travel. you will be riding the bumps all the time.
Old February 7th, 2014, 08:56 PM   #352
bbaXJ
Yooper In Training
bbaXJ's Avatar
Yeah that's definitely an option if I need to. I'll probably crank the coilovers up an inch or two for dune running, but we'll see. I wanna keep it low, but it's not like going to 6" of lift is gonna make it unstable with the setup I'm running.
Old February 7th, 2014, 09:24 PM   #353
chevotass
chevotass's Avatar
eh gawd damned it!!
Old February 7th, 2014, 09:52 PM   #354
bbaXJ
Yooper In Training
bbaXJ's Avatar
You're a little late to the party!
Old February 9th, 2014, 12:07 AM   #355
bbaXJ
Yooper In Training
bbaXJ's Avatar
After being a lazy ass all day I finally went out this evening and started on the rear airbumps. Made good progress.
Brackets:
Approximate ride height:
sbcrichie is probably right and I'll reduce the travel....we'll see. Easy mod to make later.
Full bump. About 1" from the truss/UCA mounts to the floor, .75" from truss to frame, 1.5" from fully compressed shocks.
Just shy of full flex:
I should've made the bump pads a little longer for better contact under flex. I'll fix that when I gusset them later.
Old February 9th, 2014, 08:09 AM   #356
TOPTRUK
Never Ending....
TOPTRUK's Avatar
Looking good! You may not need to change the travel as my front bumps are about like that. All depends what pressure you will need to run in them for your vehicle and driving conditions. Dunes obviously will need higher pressure while street you will have little in them.
Old February 9th, 2014, 08:31 AM   #357
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Does fox have two different models of air bumps? ive seen a couple sets were they have a shock mount on the top.
Old February 9th, 2014, 08:47 AM   #358
bbaXJ
Yooper In Training
bbaXJ's Avatar
What do you mean a shock mount? Like a heim style? I've never seen those, only 2" body or 2.5" body in varying lengths. Only difference I've seen is the Schrader caps. These just have the plain silver steel ones, my front bumps came with nice black aluminum caps.
Old February 9th, 2014, 08:49 AM   #359
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
This thing should float quite nicely. I think your going to like it.
Old February 9th, 2014, 08:53 AM   #360
TOPTRUK
Never Ending....
TOPTRUK's Avatar
^^ agreed!
Page generated in 0.37995 seconds with 84 queries
