Project Blurple - Page 12 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 30th, 2013, 10:29 AM   #221
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
Looks great Sean....
NitzPixs is offline   Reply With Quote
Old September 5th, 2013, 04:28 PM   #222
91 k1500
Big Belly Customs
91 k1500's Avatar
Send a message via AIM to 91 k1500
Done yet?
91 k1500 is offline   Reply With Quote
Old September 6th, 2013, 09:01 AM   #223
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by 91 k1500 View Post
Done yet?
More done then your big dumb mud garage storage shelf
Old September 6th, 2013, 09:24 PM   #224
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Done yet?
Old September 8th, 2013, 11:21 AM   #225
bbaXJ
Yooper In Training
bbaXJ's Avatar
Yep. Wanna go wheelin?
Old September 9th, 2013, 05:14 PM   #226
91 k1500
Big Belly Customs
91 k1500's Avatar
Yup! When and where?
Old September 9th, 2013, 05:46 PM   #227
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Tomorrow my place
H.o.r.e
Old September 11th, 2013, 12:42 PM   #228
TOPTRUK
Never Ending....
TOPTRUK's Avatar
Haha. I see what Thomas did there....
Scott's got a good point!
Good to see some progress on it, keep it up! Then maybe you can wheel at Scott's next year?
TOPTRUK is online now   Reply With Quote
Old September 17th, 2013, 11:34 AM   #229
bbaXJ
Yooper In Training
bbaXJ's Avatar
So there I was, standing there with my plasma cutter, minding my own business, when I sneezed.....
Old September 17th, 2013, 11:39 AM   #230
mschaffer66
mschaffer66's Avatar
I don't know much about suspensions...but I think that those bars you have welded in there are going to make it ride like shit
Old September 17th, 2013, 12:03 PM   #231
bbaXJ
Yooper In Training
bbaXJ's Avatar
No way man, it's ductile iron
Old September 17th, 2013, 10:40 PM   #232
bbaXJ
Yooper In Training
bbaXJ's Avatar
Got the new frame in place:
Obviously it won't stay that long when it's finished, but I left extra for now.
Now I'm trying to decide how to do the steering. I'm only running about 4.5" of lift so am not doing high steer. It's unnecessary and would compromise uptravel big time. Original plan was to move the tie rod on top of the knuckles and mount the draglink to the outer end of the tie rod for an inverted T setup. Undecided if I wanted to go heims or TREs, but leaning towards heims.
I'm now considering leaving the tie rod on the bottom of the knuckles and run full crossover with the end of the draglink on the top of the passenger knuckle hole. Like this:
This would require heims and when I plate the knuckles I'd put the mounts in double sheer. The draglink angle will be about the same as if I moved the tie rod up, it'll just be longer. I'll lose about 3" of clearance under the tie rod but it'll make packaging everything much nicer, I can keep the steering box back a couple inches further, and I just kinda like it better. If I keep the tie rod where it is and run full crossover I can keep the box back further with the pitman arm directly over the tie rod. If I move the tie rod to the top of the knuckles I need to push the box further forward to clear the tie rod at full bump.
Think I'll hate having the tie rod that low? It'd be just above the bottom of the axle tube just like you see here. I'm open to opinions, just give me some good reasoning for your thoughts!
I plan on running hydro assist. I considered full hydro, but chose not to because of cost and because I plan on driving on the street quite a bit.
Panhard clearance to the lower radiator hose is gonna be tight but I'll find a way to make it work:
Old September 18th, 2013, 06:27 AM   #233
Coming along nice.
Old September 18th, 2013, 06:29 AM   #234
bigbchevy
missmrgreenagain
bigbchevy's Avatar
so will it be ready for mine and jims bday party in December?
H.o.r.e
Old September 18th, 2013, 08:18 AM   #235
bbaXJ
Yooper In Training
bbaXJ's Avatar
Coming along nice.
Thanks. Any thoughts on my steering options?
Pretty unlikely. I've still got a ton to do, I'll be working crazy hours through most of November and December, still need to order a bunch of parts, and I owe a buddy some fabrication time for work he's done for me. Still shooting for spring though.
Old September 18th, 2013, 09:00 AM   #236
bigbchevy
missmrgreenagain
bigbchevy's Avatar
ok then you can just have a beer and maybe ill let you drive mine
H.o.r.e
Old September 18th, 2013, 09:06 AM   #237
bbaXJ
Yooper In Training
bbaXJ's Avatar
Deal!
Old September 19th, 2013, 07:18 AM   #238
TOPTRUK
Never Ending....
TOPTRUK's Avatar
I agree with your thoughts. Keep lower link as is and place the steering from the box on top as your nice level shows . This would be both easier and keep it safe for street use. what would be the max angle of the steering at full droop?
Old September 19th, 2013, 08:31 AM   #239
Longjeep
Awesome build... I have a super dumb question but way back when you started this build in one of the pics there is a set of aluminum 5 spoke rims in the pic. I just picked up a tj for my gf and the guy through in 3 of those rims extra. Any chance you still have them and that they are 5 on 4.5???? Sorry to get off topic that's a frickin bad ass cage!!!
Longjeep is offline   Reply With Quote
Old September 19th, 2013, 08:33 AM   #240
bbaXJ
Yooper In Training
bbaXJ's Avatar
Not sure what the max angle would be, but it's nothing extreme. If I go that route I'll probably use a 7/8" heim with misalignment spacer so I can run a 3/4" bolt all the way thru. When I plate the knuckles I'll also add a tab to put the bolt in double sheer for a little extra strength and less likely to wallow out the knuckle hole.
Really the only reason I haven't pulled the trigger on that design is because it has less clearance, but I still think I'll be alright.
Page generated in 0.59495 seconds with 84 queries
