Anybody into the older Kaw dirtbikes? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 31st, 2010, 06:42 PM   #1
Fraser
Fraser's Avatar
Default Anybody into the older Kaw dirtbikes?
I just picked up a KDX175 and was just wondering where I could find the serial # on the bike so i can find out what exact year it is for parts and stuff. i got the # off of the motor but google didnt bring me anything
Old November 1st, 2010, 12:05 PM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
No decal or plate or VIN stamping on the headtube?
@clarkstoncracker
Old November 1st, 2010, 12:09 PM   #3
GMKLR50
Broke wheeler
GMKLR50's Avatar
sometimes they are stamped under the engine on the frame tubes, sometimes you can see them with out removing the engine sometimes not. the numbers would be on the 10:30 (right tube while sitting on bike) 1:30 (left tube while sitting on the bike)or area if the bottom of the tube is 6. there should also be one on the engine that should be the same as the one on the frame. check over the lower half of each side of the cases.
GMKLR50 is offline   Reply With Quote
Old November 2nd, 2010, 12:50 PM   #4
Fraser
Fraser's Avatar
yes. i ended up finding it, had to scrape some crap off of it. it is a 81
Old November 8th, 2010, 12:59 AM   #5
Fraser
Fraser's Avatar
what kind of fuel/oil ratio should i run in this thing? I havent found too much besides having to drop $ on a manual. hoping to have it running this week tho
Old November 8th, 2010, 06:36 AM   #6
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
http://www.dansmc.com/shopmanual2.htm
Yetti
Old November 10th, 2010, 01:30 PM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
LOL, probably 32:1 - the older two-smokes sometimes were recommended to run 20:1.
@clarkstoncracker
Old November 10th, 2010, 01:31 PM   #8
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Wait, doesn't that thing have oil injection?
@clarkstoncracker
Old November 10th, 2010, 01:50 PM   #9
Fraser
Fraser's Avatar
negative, its a pre-mix. I'm not getting any spark tho
Old November 10th, 2010, 03:45 PM   #10
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
81 - "should" be cdi. that isn't good, but not a done deal. Check all the grounds, try to check under the ignition cover and check the resistance across the coil.
@clarkstoncracker
Old November 11th, 2010, 03:13 AM   #11
Fraser
Fraser's Avatar
it is. what kind of range am i looking for out of the coil? it did sit outside for awhile... eh. i was told it ran before, so i hope its not too involved
Old November 11th, 2010, 07:29 AM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
That's a good question! I'd check to make sure it's not open or 100% short. Perhaps you can find some general info on the site Yetti listed (for coil resistance).
@clarkstoncracker
Old November 11th, 2010, 11:58 AM   #13
Fraser
Fraser's Avatar
what i found on that site was just generic mechanical specs, nothing in depth. and it was for an '83 200. did find this tho- http://www.dansmc.com/electricaltesting.htm
Old November 12th, 2010, 10:54 AM   #14
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
good find
I'm not too far from you, so I could always stop by and give it some dumb looks.
@clarkstoncracker
Old November 12th, 2010, 11:18 AM   #15
Fraser
Fraser's Avatar
good find
I printed off that page so im prob gonna go through it later today and see if i can find something. you can shoot me your # and ill give you a shout
Old November 15th, 2010, 03:56 AM   #16
Fraser
Fraser's Avatar
It now runs and rides, coil was shot and the flywheel was loose enough so you would get power for a couple kicks and then nothing . got the flywheel on there tight and a new coil and was out in the dark b/c the headlight was workin
Old February 15th, 2011, 11:32 AM   #17
Fraser
Fraser's Avatar
what would be a good torque to put on my flywheel bolt? the stock one broke so i tapped it out to run a 3/8" grade 8. flywheel kept coming loose on me >:/
Page generated in 0.28284 seconds with 74 queries
