tube benders? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2005, 12:54 AM   #1
Chop
Mischievous Badger
Chop's Avatar
Default tube benders?
who has what and how do you like them? im looking for a decent priced bender to bend DOM tubing from 2 inch to 1.5, basically roll cages, bumpers, etc...
Old December 6th, 2005, 08:09 AM   #2
I don't have a tube bender myself, I have a pipe bender. Cheap and dirty but it gets me through, for now.
Classic $70 harbor freight model, with various pipe dies.
I have done my bed/roll bar with it, and will be doing my sliders and front brushguard/winch bumper with it over the break.
Review:
First, its for pipe, not tube. If you don't know the different, tubing is measured by OD, pipe is actually sized by OD as well, but is listed by a nominal ID that doesn't really mean anything..
By this, I mean a piece of 1-1/4" pipe will always have a 1.66" OD. the 1-1/4" is supposed to be the nominal ID, but it will vary based on the schedule you used. Schedule 40 1-1/4" has a wall thickness of 0.140". Wall thickness isn't the same for different pipe diameters. A 2-1/2" schedule 40 pipe is a 0.204" wall thickness..
Anyway, so, this type is just a hydraulic press with curved dies which force the pipe onto rollers to bend it. So, inherently, there's more pipe disortion than a tube bender.
I find for bends up to about 60 degrees, its pretty good, I can usually get about 70 degrees OK. Beyond that, you'll kink the pipe. I'm going to try a few different techniques to get a bit more than that, but I won't count on it.
For me, its cheap and works pretty well. Pipe is also cheap and always in stock for the sizes I use at the steel yard.
Due to limitations, I try to create my designs to not need sharp angles. Or use compound angles say a 30 and a 60 a little past it, to make a 90. Workks very well/natural for most bumper designs which aren't flat across the truck but stick out more in the middle anyway. The roll bar didn't need any bends beyond 70, and came out pretty good. I had one pipe with 6 bends in it to make the main hoop.
One thing thats a little easier with a pipe bender, is the center of the bend is always the center of the die. So layout can be easier for the non-trained.
I'll definately move up to a real bender once I have my new house/pole barn built in a year or two, but until then, it works..
Old December 6th, 2005, 09:02 AM   #3
Chop
Mischievous Badger
Chop's Avatar
cool i was wondering how those benders at HF work thanks for that input
Old December 6th, 2005, 09:20 AM   #4
Liek I said, not great, but they do work.
Try bending something too big in them, and I've seen them break. I wouldn't try something 0.250 wall.
You get a good arm workout with it, it can take 50-100 pumps on that jack handle to bend something strong to 70 degrees..
I'll Defiantely step up to a rear pro-tools bender in a few years, but I'm saving pennies for building a new house with a 1500 sq ft auto shop. Once I have that done, I'll get the new bender.
Here's my main hoop: 1-1/4" A500b structural tubing (1.66" OD, 0.140" wall)
Old December 6th, 2005, 09:50 AM   #5
Chop
Mischievous Badger
Chop's Avatar
what is the strengh of the tube you used compared to DOM tube ? isnt there a seam in most pipes?
Old December 6th, 2005, 10:22 AM   #6
DOM is another term, like 'pipe' that is tossed around.
You'd need to specify a specific type of DOM tube with a ASTM standard to really get specifications. A lot can depend on the various processes..
Plain steel 1018 tubing is 50,000psi yield strength.
4130N chrome-moly is 63,100psi
4130T(tempered) is 110,000psi
4340N chrome moly is 114,000psi
Chrome moly requires preheating before welding.
Maybe the JCR guys will chime in, I'm sure they know more than I do.
Old December 6th, 2005, 02:05 PM   #7
Chop
Mischievous Badger
Chop's Avatar
yeah i know what you mean with all that.
Old December 6th, 2005, 02:16 PM   #8
BMFmike
meh.
BMFmike's Avatar
Fill the pipe with sand, duct tape both sides, heat where you want to put the bend with a propane torch, bend around an object that wont move, WOOHOO, and you have some exhaust pipes:tonka:
Old December 6th, 2005, 02:24 PM   #9
Chop
Mischievous Badger
Chop's Avatar
haha yeah
Old December 6th, 2005, 02:35 PM   #10
BMFmike
meh.
BMFmike's Avatar
No joke I am going to try that for the pipes on my harley, I am going exhaust wrap them anyway so I will give it a shot.
Old December 6th, 2005, 02:47 PM   #11
I actually did an exhuast pipe on my poop-pipe bender.. I needed to just put a 10 - 15 degree bend in it. Worked ok, but any more than that woud crush the pipe. Just needed a little clearance.
I've been meaning to buy some play sand and pipe caps to see if sand makes any difference..
Old December 7th, 2005, 08:08 AM   #12
noodles
give 'er sh*t ay?
noodles's Avatar
i used the hf bender on my front bull bar, i tryed to do 90 and it kinked the pipe, i think i know how to fix it becasue of the design in the bender. I didnt really like it. I have used a differnent bender that I belive will go up to a 2 inch od this can make 90's good. i belive it was only like $100-200 but then you have to buy the dies. thats the expensive part.... I might try to make one, the hf is very simple design. but who knows.
Old December 7th, 2005, 09:38 AM   #13
Medic8
You call, we haul.
Medic8's Avatar
If you're interested in doing some serious bending, and would like to do 90 degree bends and beyond, you should look into the Model 3. Just do a google search for "Model 3 bender" and you'll find it. About 5 different companies all make their own version of the same thing. It runs $295 usually for JUST the bender. A handle, degree ring, stand, and dies are extra. Usually, you can find a combo deal with all of the above for around $895-950 depending on the die. 1.75 or 2" seems to be a good general all around die, if you're only planning on getting one. Otherwise, they usually cost another $300 or so each.
Old December 7th, 2005, 10:09 AM   #14
Yeah, thats what I'll be stepping up to in a few years.
I've seen some interesting ones homebuilt. I believe plans are out there for a model 3 type bender.
Saw some guys on the discovery channel with a total redneck homebuilt one. They had a 15ft piece of 2x2 steel tube with 3 guys pushing it as the lever to bend the tube. Guys were building souped up electric golf carts that'd go 60+ mph...
Old December 7th, 2005, 11:02 AM   #15
Chop
Mischievous Badger
Chop's Avatar
good info thanks i will look into that more also
Old December 11th, 2005, 03:52 PM   #16
Dirty Turtle
Dirty Turtle's Avatar
HF also sells a bigger model that will do up to 2 1/2" . I think it runs about $150ish Search opn their website.
Dirty Turtle is offline   Reply With Quote
Old December 24th, 2005, 12:36 PM   #17
raelayotte
Send a message via Yahoo to raelayotte
Default hi
heres a good plan go with the hd plan http://www.gottrikes.com/
raelayotte is offline   Reply With Quote
Old December 24th, 2005, 01:24 PM   #18
Chop
Mischievous Badger
Chop's Avatar
thats a nice site good find i will probably order plans soon
Old January 18th, 2006, 06:35 PM   #19
Dirty Turtle
just an fyi....I bought the cheap harbor freight bender. I can easily get it to bend 90 degree angles (or more)
I learned a trick from a buddy. Get your size tubing, and use one size smaller die. Ive been bender 1.75" and 3/4" without any problems.
The only thing I have noticed, is you need to make sure the tubing stays the way you want it when you begin your bend. Smaller tubing seems to want to move itself around until it has some pressure on it, which caused some twisting, resulting in a U shaped bend being slightly distorted. A pair of vice gripswith the angle finder stuck on the end, until it was pretty tight seemed to fix the problm.
Ill post a couple pics of my bumper in this forum.
Page generated in 0.58816 seconds with 80 queries
